Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
  1. #31
    Banned
    Join Date
    Dec 2011
    Posts
    1,129
    L5450
    Default
    Sounds like you guys have the problem pinned down. Here is my LA1150A with ample clearance above the 6'6" high cab on this pickup. My curl cylinders are extended in this picture so the bucket edge can actually can raise higher. I have R4s so I am not as tall as those with tall ag R1 tires.
    Attached Thumbnails Attached Thumbnails L4850 with LA950a loader - does not go very high-image-2767911252.jpg
  2. #32
    Member
    Join Date
    Mar 2010
    Posts
    28
    Connecticut
    Kubota L4850
    Default Re: L4850 with LA950a loader - does not go very high
    Sorry guys! I had family in from Chicago for the holiday, including my 94 year old grandmother. We turn my office/computer room into a downstair bedroom for her...so I wasn't really able to spend any time at the computer.
    First, the loader still has a tag on the side and it is model LA950a (serial 20500), the bucket is model L1774.
    The lower lift cylinder pin to main pivot pin is 18" (center of pin to center of pin). The upper cylinder pin to main pin is 39 3/4".
    When the bucket is down and level with the ground I have 7" of piston rod still. I am not sure what that would equate to in downward travel, but I can't see why I would need to dig more than about a 12" below the front tires. Based on this it seems a longer cylinder would fit.
    My lift cylinders measure 3" OD and 2.375" at the upper pin (where its squared off). One of the brochures had different cylinder sizes.... but it still doesn't make sense becuase the brochure has the cylinder travel at 21.65" which would seem to mean that my cylinders are corrrect...?
    clint
  3. #33
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    1,797
    Canada
    B3200, L5740,
    You got er! Your lift cylinders are the wrong length. Seems strange but someone must have swapped them at some point.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    GF1800
    JD 850D Gator
    JD F935 x 2 sold
    Ford 555D TLB
    Gehl 602 excavator
  4. #34
    Member
    Join Date
    Mar 2010
    Posts
    28
    Connecticut
    Kubota L4850
    my upper lift cylinder to upper bucket cylinder is 17"
    Ok, just studied all the different pics... and yes, clearly the other LA950 loaders have longer cylinders. I scaled off of three of the pics using the steering wheel as a know 15.5" and interestingly it seems two of the 950 loaders have 32" long cylinders (from upper pin to end of orange cylinder) and the other had a 28" long cylinder. the 28" cylinder does infact end short of the 5 bolts (support bracket bolts). They probably had ooodles of identical cylinders in the factorys for different loaders and it wouldn't be too difficult to get them mixed up.
    I attached a picture of my machine again.
    So the million dollar question.... How/where do I get longer cylinders that don't cost a fortune?
  5. #35
    Super Member
    Join Date
    Sep 2000
    Posts
    6,358
    If you take the cylinders to a welding shop, you can get a 5-6" extension welded onto the butt end (non extending end). With the bucket level on the ground, you want about an inch of extended cylinder showing, not the 6-8 you seem to have! That's a "work around", the proper solution would be to get the correct cylinders, but a pair from Kubota will run you enough to cause a serious indigestion where the weld fix is probably a hundred bucks.
  6. #36
    Join Date
    Sep 2007
    Posts
    1,387
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    OK I'm starting to sway and bend a little. I thought the 950 and 1150 used 24" cyls. and when you look at JoeBuyers picture the upper anchor pin is a ways from the boom. It does make more sense that the cyds. could get mixed easer. Kuboman, I think, said maybe there are 2 models of the 950, and if so the cyls could be mixed. Longer cyls would sure do it, but they would have to be longer then a 24" strock. Most loaders the digging depth isn't much and if Clint dropped his in the ground he wouldn't have the power to go that deep.
  7. #37
    Veteran Member rbargeron's Avatar
    Join Date
    May 2000
    Posts
    2,203
    MA
    L5450 Cab, L48, L3250, L345DT
    Quote Originally Posted by clinter36 View Post
    Click image for larger version.
    Good question. I would imagine Kubota buys their cylinders and there is a master list of dimensions somewhere by part number. Assuming this was an error in manufacture the factory rep might agree to supply something with normal lift height for a reasonable price? Might have to ask nice.
    L5450, L48, L3250, L345, never enough attachments
  8. #38
    Join Date
    May 2000
    Posts
    2,203
    MA
    I was thinking that a local fab shop could make a couple extension brackets that would move the pin back a couple inches. They could lock in place using the existing pins, and have new pin locations for the cylinders.
    They'd be cheaper than new cylinders and removable in case you change your mind. (see picture markup) You would still have full thrust, just less bucket travel below grade.
    Attached Thumbnails Attached Thumbnails L4850 with LA950a loader - does not go very high-la950-extension.jpg
  9. #39
    Member
    Join Date
    Mar 2010
    Posts
    28
    Connecticut
    Kubota L4850
    I was thinking about an extension... but having longer cylinders would give me more travel as well. A 2" longer cylinder would also have a 2" longer rod, which would give me 4" more travel.... ( I think - I have to draw it out)
    Messicks sent me a parts diagram, but it didn't indicate cylinder lengths ($600 each Ouch!). So one of the guys there emailed their Kubota rep. I'll let you guys know what I find out.
    Clint
  10. #40
    Member
    Join Date
    Mar 2010
    Posts
    28
    Connecticut
    Kubota L4850
    Just got a reply from Messicks (from their Kubota rep). The stock Kubota cylinders measure 34". I assume this is a pin to pin measurement, which compares to my cylinders at 28" center pin to center pin.
    Does anyone have any contacts directly at Kubota? (rep or other) ??
Similar Threads
  1. L4850 value?
    By 2000silverz28 in forum Kubota Buying/Pricing
    Last Post: 06-07-2012, 03:24 PM
  2. L4850, BF900
    By Keltic in forum Kubota Owning/Operating
    Last Post: 01-06-2012, 10:16 AM
  3. Loader Kubota LA950A loader weak
    By ussofa in forum Kubota Owning/Operating
    Last Post: 05-12-2010, 09:28 AM
  4. Need reasonably high hp tractor w/cab & loader...
    By Dargo in forum Owning/Operating
    Last Post: 05-15-2006, 03:20 AM
  5. Skid loader pedals lock under high rpms
    By TeXXXas in forum New Holland Owning/Operating
    Last Post: 09-14-2004, 03:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
