Skintback
I have a Kubota 3240 with a question about adjusting the lower link arms. On the arms are three holes each. On the side link arms, one has three holes at the and the other has two holes, leaving out the middle hole. (This may sound a little confusing and if so I will take a picture.) The tractor came with the pins in the top holes of the side lift arms and through the rear most holes on the lower link arms. Adjusted this way, using the box blade for instance, the lift arms will not drop down enough to cut very deep. I moved the side lift arms to the middle hole on the lower links and kept the pin in the top hole on the side link arms. This allowed the box blade to cut much deeper. My question, without doing a lot of trial and error,what is the happy medium for being able to cut deeper while retaining lift height and clearance?
I'm mainly wondering if it is okay to place the links in theholes I swapped to without damage. It seems tolift as high set this way but the top link will hit the PTO shield if loweredall the way.
Man, I typed that and it sounds confusing to me. Think I'll get some pics to better explain my question.
