Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Gold Member Gasifier's Avatar
    Join Date
    Jan 2012
    Posts
    285
    St. Lawrence River Valley, N.Y.
    Mahindra 3550 4WD HST w/R1s
    Default Slight fluid leak at front axle joint.
    Hey guys. I own a L3710 with kubota loader and Woods backhoe. About 1200 hours on the machine now. Works great. I have a slight fluid leak at the right side of tractor(if sitting on the tractor) on the front axle. Right where the axle ends there are four bolts that connect it up to the wheel assembly. (For lack of better term.) I recently tightened these bolts up and topped off the fluid with gear oil. Is it a common thing to leak? I was told by a gentlemen at a Kubota dealership that there is one seal in this joint and that this may be bad. But he also said sometimes the bolts will loosen up with a lot of loader use. So I tightened them up and topped it off. Any experience with this. Suggestions? Thanks for your time.
  2. #2
    Elite Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    3,449
    NorthEastern, VT
    Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
    Default Re: Slight fluid leak at front axle joint.
    Can't tell from your post if tightening up the bolts fixed the leak, had no effect, or you don't know yet.
    There have been many posts on front axle leaks but they are are in the pivot joint or the seals just inside the wheels. I can't recall one leaking where yours does.
    Some have been cured or at least slowed by using gear oil in the front axle instead of hydro oil.
    "If you're not making any mistakes then you're not doing anything"
    M5640SUD, L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' & 7' Rear Blades, 7' Box Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  3. #3
    Veteran Member Deano's Avatar
    Join Date
    Oct 2008
    Posts
    1,239
    Southern Maryland
    Kubota BX24
    Take a picture please.
    I just replaced the seals on my axle where the front wheel pivots.
    Deano
    2006 BX24, 6' Modern Implements rake, Woods RB60 rear blade, Wallenstein thumb, Bro-Tek rear skid plate, home made front skid plate, W.R. Long flat tooth bar, 4' finishing mower (TPH), 4' box blade, post hole digger, New style seat!!!!!, Agri-Fab drop spreader.
  4. #4
    Join Date
    Jan 2012
    Posts
    285
    I will get a picture posted so you can see where I am talking about. I need to get to know the names for the parts on my tractor!
  5. #5
    Veteran Member theboman's Avatar
    Join Date
    Jun 2001
    Posts
    1,578
    Grayson, KY
    Kubota B7500 HST
    those wheel seals are HORRIBLE.... I've replaced them twice on the LEFT (driver if'n it was a car).
    Bo McCarty
    THE BO-MAN, er BO-DADDY
  6. #6
    Elite Member johnk's Avatar
    Join Date
    Jun 2003
    Posts
    2,714
    western NY
    Kubota GST Grand L3130 w/ 723 loader, Ags
    Mine was leaking and I replace the axle with 90/120 wgt. I had udt in there and that is pretty thin. Helped mine and no more leak.
    Kubota grand L 3130; 723 loader; Hinged back Box Scraper; 7' HD Back Blade; Tooth Bar; PHD w/ 9 & 12 Inch Auger; PEC; Carryall
  7. #7
    Join Date
    Jan 2012
    Posts
    285
    Here is a picture of the joint where the leak is. If I can post it! If you look real close you can actually see the spot on the 6x6 it is resting on. The main joint, I am not sure what it is called. There are four bolts that hold it together. I have tightened them and topped the level off with the gear oil and it seems to be better. But, a very slight leak still. Only a few drops though after it has sat there for two days like this. I am waiting for my front tires to be finished. I decided to put tubes in them because of problems with flat tires. I must have a slow leak in one of the tires so I decided to stop this from happening now before the snow hits. So I am thinking the seal must be shot in that joint. I am surprised at this though. There is only about 1200 hours on the machine. I guess at some point when I do not need it for a while I will replace both seals up front at that location.
    Slight fluid leak at front axle joint.-dscf2446-jpg
  8. #8
    Join Date
    Oct 2008
    Posts
    1,239
    Southern Maryland
    Kubota BX24
    Gasifier,
    I see what appears to be oil coming from the plug also?? The four bolts you are refering to has an o-ring behind it. It also looks like the seals where it pivots are leaking also. Order the o-ring for the spot with forur bolts, the o-ring for the axle case (where the 8 bolts are) and the pivot seal and you should be good to go after an afternoon of work. Oh, and the gasket for the plug that looks like it is seeping.
    I just did my pivot seals and all is well.
    Deano
  9. #9
    Elite Member rbargeron's Avatar
    Join Date
    May 2000
    Posts
    2,806
    MA
    L5450, L48, L3250, L345
    Gasifier,
    Sooner or later you'll be interested in threads like this one.
    L345, L3250, L48, L5450, never enough attachments
  10. #10
    Join Date
    Apr 2007
    Posts
    3,449
    NorthEastern, VT
    Quote Originally Posted by rbargeron View Post
    Gasifier,
    Great diagram and discriptoion there.
    The pivot joint looks like the most suspicious one to me. But do them all like Deano says.
Similar Threads
  1. Axle fluid leak?
    By moojamboo in forum New Holland Owning/Operating
    Last Post: 06-01-2011, 04:39 PM
  2. Fluid in the front axle and a front tire pressure w/loader? L3940
    By Grateful11 in forum Kubota Owning/Operating
    Last Post: 04-22-2010, 09:03 AM
  3. change steering box fluid/front axle fluid
    By casey lb1914 in forum Kioti Owning/Operating
    Last Post: 05-02-2009, 02:42 PM
  4. front axle pivot joint; greasing thereof
    By geish in forum Kubota Owning/Operating
    Last Post: 06-11-2006, 01:37 PM
  5. Front axle leak
    By PaulB in forum Kubota Owning/Operating
    Last Post: 08-01-2005, 08:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
