Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Join Date
    Aug 2005
    Posts
    147
    Louisiana
    2009 L5240HST
    Default Re: Work light connectors for my L5240.
    I plan on putting 2 switches, 1 for the front and 1 for the rear.
  2. #12
    Platinum Member Notforhire's Avatar
    Join Date
    Nov 2011
    Posts
    853
    Southwestern Virginia
    JD 5055E
    Work light connectors for my L5240.-tractor-stuff-003-jpg
    Quote Originally Posted by crazyangel View Post
    I have thought of using those plugs for work lights too. If you use those plugs, do you need to add a switch between the light and the connector? It is unclear if the plug it always hot or if its tied to another switch (i.e. headlights).
    Yes you will need a switch. The plugs become hot when you turn on the key.
    I used four 27W LED lights, and two switches mounted in a plastic box attached to the ROPS.
    Best, Bill
  3. #13
    New Member
    Join Date
    Aug 2011
    Posts
    23
    Kubota l3800hst
    Default
    Thanks for the topic was in middle of installing lights when I found it. Made it much easer for me to add lights I did add a switch for each lite. Worked well and now can turn off a lite when looking behind me so I don't get blinded
Similar Threads
  1. Work light
    By oklandist in forum Kubota Owning/Operating
    Last Post: 12-21-2011, 04:06 PM
  2. Work Light
    By JCJD1 in forum Customization
    Last Post: 12-18-2011, 11:17 AM
  3. Work light connectors on L3940 ?
    By stub in forum Kubota Owning/Operating
    Last Post: 12-14-2011, 07:53 AM
  4. Work Light Help!
    By bradv42 in forum Kubota Owning/Operating
    Last Post: 04-09-2007, 03:39 PM
  5. Why do I have a work light fuse, but no work light?
    By StrangeRanger in forum Kubota Owning/Operating
    Last Post: 03-29-2007, 10:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
