Results 11 to 20 of 79
11-29-2012, 08:54 PM #11
Re: BH77 - has anyone considered converting mechanical thumb to hydraulic?
I thought I'd talk to someone like WR Long to see if they could come up with an electric-over-hydraulic setup like they have for the FEL remotes. They add a hyd block to the FEL block, so maybe something similar could be added to the backhoe hyd block. I'd like a switch setup that I could add to the backhoe bucket curl joystick, like on a mini-ex.
Actually might be a nice project for them to take on, since I'd bet they'd sell quite a few kits to owners of the smaller backhoes with mechanical thumbs. Worth a phone call, I guess.
If I was a hydraulic guru, I'd design & build my own setup, but since I'm not, it would ultimately be cheaper for me to just buy someone else's properly designed system.2012 Kubota B3000, block heater, filled rears, rear wheel spacers, fender extensions, LA403 w/60" bucket, BH77 w/12" bucket & mechanical thumb, Kubota pin-type QA, Kubota forks, Caroni TM1600 flail, Buhler Allied YC6010 3pt blower, Meyer 72" FEL mounted plow, Midwest LR2072 rake
Previous machines:
2008 Kubota B3030 (Open Station), LA403, BH75, 4 - 55w halogen front & rear ROPS mounted worklights with L39 dash switches
2004 Case NH DX24E Subcompact
Kubotas from Barlow's
11-29-2012 08:54 PM # ADS
12-01-2012, 09:20 AM #12
You might want to look at the Woods documentation for their mechanical to hydraulic conversion kit. Might give you some ideas of how you want to plump the valve.
http://www.woodsequipment.com/upload...ls/MAN0815.pdf
12-01-2012, 10:19 AM #13Elite Member
- Join Date
- Jun 2008
- Posts
- 4,741
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I have a B26 with hydraulic thumb and man is it handy. I like the foot control plate as it allows you to continue with full function of the hoe will closing or opening the thumb although it is a little cramped on the operator platform with the paddle folded out. I bought it used with 68 hours last June and have 220 hours on it now. The thumb is plenty sturdy and needs same hydraulic pressue as the hoe to operate correctly. Seems to me that one could splice in an extra block on the Hoe controls and run to the thumb control valve pretty easily. You will need to weld on some clips to hold the new hydraulic lines in place. The fingers on the thumb need to match up so that they fall between the teeth on the bucket not on top of them.
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
03-25-2013, 07:16 PM #14
03-25-2013, 07:46 PM #15
03-25-2013, 07:58 PM #16Silver Member
- Join Date
- Sep 2012
- Posts
- 160
- Location
- West Chesterfield, NH
- Tractor
- 2011 Kubota B3300SU
Nice! I wish it was in my budget!
03-25-2013, 09:42 PM #17
Have a read through this thread if you haven't already. If you can do it on a BX, then I'm sure it's definitely possible on a BH77!
http://www.tractorbynet.com/forums/k...lic-thumb.html
03-25-2013, 11:09 PM #18
I hated that thumb on my BH75, and sold it within a couple months of getting it. The Kubota thumb on the BH77 is far superior. Still plan to eventually convert it to hydraulic.
Previous machines:
03-26-2013, 06:58 AM #19Silver Member
- Join Date
- Oct 2010
- Posts
- 215
- Location
- NYS--Various Parts
- Tractor
- Airens/Simplicity/Sears
wdchyd,
Can you please expand on this statement: "]Knowing the kind of damage that can happen to hyd thumbs, I elected to spare myself the trouble to modify my mechanical one....." Just never heard of any issues, other than if you try to put a thumb on a bucket where the teeth don't "mesh" between the two, then you can bend parts, I'm told. In other words, as Gary Fowler, said, above: "The fingers on the thumb need to match up so that they fall between the teeth on the bucket not on top of them."
Curious as to what issues you've run into.
Thanks,
My Hoe
03-26-2013, 08:10 AM #20
Not to poo-poo on anyones wishes to install one but realize I do cylinder rebuilding, and that includes damaged ones
Many bent rods (leading to scored barrels cuz the piston head cocked sideways internally) have been diagnosed back to the problem of induced load
Meaning a force pushing in to the thumb piston is greater than the hyd cylinder can survive from another source......the bucket curl.
The bucket curls larger displacement and leverage can put extreme forces while clamping down using the curl cyl, unless there is a relief setup to allow extra pressure to relax (ie:work port reliefs in the control valve) during curl cyl use
If the hyd thumb is properly installed, the thumb cyl should go back in when there is too much pressure.....not bend and self-destruct. Without the safety of the reliefs plumbed in to the base end of the thumb cyl, the pressure intensifies greater than the rated pressure of the cylinder (assuming the thumb cyl is smaller than the curl)
Ideally either work ports reliefs or sizing the cylinder large enough to match is my recommendation
I actually have no problem with hyd thumbs, just not on my machine, I don't make a living with it2010 Kubota B2320 FEL & BH65
If it ain't fixed don't broke it!
http://www.tractorbynet.com/content/...-month-wdchyd/
Similar Threads
Backhoe Mechanical or Hydraulic thumb?
By jchealey in forum Kubota Owning/OperatingReplies: 31Last Post: 01-05-2012, 07:01 PM -
Backhoe Converting BH76 thumb to hydraulic
By Monster5601 in forum Kubota Owning/OperatingReplies: 0Last Post: 10-21-2010, 12:04 PM -
Thumb Converting Woods BH90x thumb from mechanical to hydraulic
By IslandTractor in forum AttachmentsReplies: 10Last Post: 01-20-2010, 12:21 AM -
Mechanical Thumb
By Tompet in forum Massey Ferguson Buying/PricingReplies: 5Last Post: 03-07-2009, 09:51 PM -
BH 75/ mechanical thumb.
By swampvol in forum Kubota Owning/OperatingReplies: 6Last Post: 04-25-2008, 07:30 AM
