Results 101 to 110 of 130
12-17-2012, 06:38 PM #101Banned
- Join Date
- Dec 2011
- Posts
- 1,129
- Tractor
- L5450
I agree. Nice job on the grader blade. Looks sturdy.
Originally Posted by Gordon Gould
12-17-2012, 07:39 PM #102Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,661
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Dresser TD7G Dozer
Re: looking for 101 off the wall uses for my kubota
Thanks - Does a nice job too.
"If you're not making any mistakes then you're not doing anything"
L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
12-18-2012, 09:15 AM #103Elite Member
- Join Date
- Dec 2007
- Posts
- 3,515
- Location
- Ohio
- Tractor
- JD 5520, 790 TLB-- Kub L4300, B7800, MX5100
12-18-2012, 10:03 AM #104Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,661
- Location
- NorthEastern, VT
- Tractor
12-18-2012, 10:35 AM #105
12-18-2012, 06:49 PM #106Banned
- Join Date
- Dec 2011
- Posts
- 1,129
- Tractor
- L5450
If you don't mind me asking was your cost less than buying a comparable unit? The price of steel seems so high I only build out of scrap which ends up that I can only make odds and ends.
12-18-2012, 07:36 PM #107Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,661
- Location
- NorthEastern, VT
- Tractor
Grader 4'-6" long, 5' wide ( inside) 575 lbs
Notes
Lift Arm Braces 28" center to center. Alter to fit quick hitch if necessary.
Upper Cross Braces 2' apart
Blade Mounts 2' apart, first blade mounted 10" back, front of Blade Mounts are 3/4" below runners
3" X 3" triangles cut from bottom corners of sides for runner angles
1/2" Grade 8 bolts and extra long nuts for tail gate stop pins
swinging tailgate up and forward to hang insde against stops is like box blade ( sort of )
swinging tailgate up and back to hang behind stops allows use like push blade in reverse
Steel
Standard lengths - Bought and picked up at steel supply house, They make one cut at no charge
3/8" X 12" steel plate 20' (2/10') $210
2 sides, 6pcs 6" X 3" for hitch clevises, tail gate
3/8" X 2" steel bar 10' $25
2 runners
2 1/2" X 1/4" Square tube 24' (2/12') $115
2 upper cross members, top link verticle and angle braces, 2 lift arm braces
4" X 4" X 3/8" angle 10' $69
2 cutting blade mounts
1 1/2" schedule 80 blk iron pipe 10' $46
hinge pin for tail gate ( used 3 short pieces of 2" sched 40 I had for hinges )
Total Steel $465
Then add for the cutting edges.
Edit: Would save $100 if I left tail gate off."If you're not making any mistakes then you're not doing anything"
12-18-2012, 09:52 PM #108Banned
- Join Date
- Dec 2011
- Posts
- 1,129
- Tractor
- L5450
Impressed. You should start up a company doing this.
12-24-2012, 01:33 PM #109Member
- Join Date
- Nov 2012
- Posts
- 26
- Location
- St. Helens, Oregon
- Tractor
- L4300
It is snow season, are there any pics out there of building and super sizing a snowman using your "bota"
12-24-2012, 02:27 PM #110Silver Member
- Join Date
- Oct 2011
- Posts
- 166
- Location
- North East PA
- Tractor
- Kubota BX2230 & B2320
Similar Threads
Kubota m7040 / Ford 101 with the shear bolt trip beams
By tprpicscom in forum AttachmentsReplies: 3Last Post: 04-02-2012, 10:38 PM -
Brushhogging 101
By bxowner in forum Kubota Owning/OperatingReplies: 15Last Post: 03-07-2010, 01:24 PM -
Hydraulics 101
By Jw5875 in forum Kubota Owning/OperatingReplies: 0Last Post: 12-13-2006, 09:18 PM -
101 Fork uses
By Phred in forum PhotosReplies: 3Last Post: 01-27-2003, 09:47 PM
