Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    1
    Butler, PA
    Kubota BX23
    Default BX23 muffler problem
    I have a BX23 8 years old with 950 hours. The muffler has broken out from the inlet end. I think there is too much weight for just three bolts. Has anyone come up with a home made clamp to help hold the muffler to avoid another break out?
  2. #2
    New Member
    Join Date
    Apr 2013
    Posts
    1
    Willington, CT
    Kubots bx23
    Default Re: BX23 muffler problem
    Yes, use a large diameter steel hose clamp to tie the outlet end to the frame. This stops removes the stress on the bolted end
  3. #3
    New Member
    Join Date
    Jan 2010
    Posts
    1
    I have a BX23 with under 800 hours which recently started burbling with intermittent loss of power. Seemed to be a loose connection at the muffler/manifold, but the three bolts were still tight. I removed it and this is what I found:
    BX23 muffler problem-image-jpeg
    There was no rust or erosion (My BX lives a pampered life) but the metal mounting point that mates to the manifold had crumbled badly around the top half, almost certainly from metal fatigue. This is not an example of competent engineering, and almost looks like a designed to fail part. At almost $125 for a kubota replacement, it smarts to see an otherwise sound muffler heading to recycling.
    I don't suppose Kubota has addressed this issue, but it sure has left some tarnish on my opinion of Kubota engineers. I will be taking steps to somehow support the outboard end of the replacement, as the previous poster suggested, but feel like mounting to the frame of the tractor might also create a problem. The motor is mounted on rubber mounts and the frame is rigid. Connecting the two rigidly might actually end up stressing the joint more than leaving it unsupported.
  4. #4
    Join Date
    Sep 2005
    Posts
    139
    new brunswick canada
    bx 1830 05
    i had the same trouble with my bx 1830 600hr to bad they dont put a bracket like bx 25
Similar Threads
  1. BX23 Problem...
    By ArtyB in forum Kubota Owning/Operating
    Last Post: 10-10-2011, 06:55 PM
  2. BX23 Starting Problem!
    By BSF215 in forum Kubota Owning/Operating
    Last Post: 05-23-2007, 09:34 AM
  3. BX23 seat problem
    By Stef in forum Kubota Owning/Operating
    Last Post: 03-18-2005, 11:10 PM
  4. Anyone else having this problem on a B7800 or Bx23
    By 1TMatthews in forum Kubota Buying/Pricing
    Last Post: 11-10-2004, 04:16 PM
  5. New BX23 HST problem?
    By Phrede in forum Kubota Owning/Operating
    Last Post: 02-25-2004, 02:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
