Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    The telescopic stabilzers would be nice with pats. If you did not have them the lift arms will fall in and not be the right width for the implement.
  2. #12
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    6,514
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds
    Default Re: Necessary Attachments on the L3200?
    I want to SECOND above comment from Roger/94BULLITT, above.
    When backing up to an implement to attach it, without some means to hold the lift arms in a spread position about as wide as the draw pins you want to slip the lift are 'eyes' onto, arms want to snarl on some part of the implement. Before ordering telescopic stabilizers from Stabilworks I used rebar, pounded into the dirt, to stake the tractor lift arms at the appropriate width. It was a pain, but effective. Also, I often lost one or both of the hairpin clips which secure the stabilizer turnbuckles on the B3300 (but not on all Kubotas), which was also irritating.
    Telescoping stabilizers making changing equipment much easier. I have a Pat's easy change System here but once I installed telescoping stabilizers Pat's seemed redundant so I still have Pat's adapters in the packaging. I may install Pat's yet......one-of-these-days.
    Like riding a two wheel bicycle, it takes time to figure out the optimal technique for hanging each piece of equipment on the 3-pt hitch.
    You will find connecting the PTO shaft to the tractor, on PTO powered implements, ALWAYS a trial.
  3. #13
    New Member Gerold's Avatar
    Join Date
    Mar 2012
    Posts
    13
    Northfield, VT
    Kubota L3200
    Default
    I got an L 3200 last winter and love it. I don't have any problems with the turnbuckles. Get cruise control, it's handy. The quick attach bucket is good. I just bought a QA grapple and love it. Beforehand though I would take the bucket off for visibility or maneuvering in tight spaces. Ask the dealer to fill the rear tires (mine doesn't sell the front loader without filling the rear tires). $450 for rear ballast seems to be a waste. Look on Craig's list for a useful implement for that price - box blade, scraper blade, York rake, rotary cutter,... An implement + filled tires is plenty for loader work. If you buy implements new from the dealer you might get a package price and can finance as part of the tractor purchase. On the other hand buying used from Craig's list might get better quality or price. Depends what you need/want.
  4. #14
    Join Date
    Jan 2011
    Posts
    6,514
    Two further (non-dealer) options I would recommend are bucket hooks and a Ratchet Rake.
    I have Ken's bolt-on-bucket-hooks and I recommend them. Industrial art from Maryland, USA.
    Ken's Bolt on Grab Hooks
    I was out in the woods today and snapped some fresh bolt-on grab hook photos.
    Note that I have one bolt-on grab hook attached to the cross drawbar for pulling logs which might strain the FEL. Sorry third photo is not all that good......
    I have used and occasionally abused Ken's hooks but they have NEVER loosened nor deformed.
    No implement on the 3-Pt. Hitch. Tires NOT filled. With this decayed wet log on the FEL the tractor rear felt a little light.
    Payne's aluminum debris forks are visisble in photo #1 + photo #2.
    Attached Thumbnails Attached Thumbnails Necessary Attachments on the L3200?-img_0451-jpg   Necessary Attachments on the L3200?-img_0452-jpg   Necessary Attachments on the L3200?-img_0453-jpg
  5. #15
    Platinum Member bironacad's Avatar
    Join Date
    Jan 2011
    Posts
    659
    Southern Ontario, Can
    New Holland 3045/2010
    An extra set of hydraulic outlets for when you want your hydraulic top link, or tnt or grapple................
    “If at first you don't succeed, you are running about average.”
    M. H. Alderson
    New Holland 3045 with cab
  6. #16
    Member
    Join Date
    Sep 2011
    Posts
    31
    Western Washington
    Kubota L3200, 1949 & 1953 Farmall Cubs
    Quote Originally Posted by jeff9366 View Post
    " pivot pin gradually worked loose then fell completely out. "
    I'm under the impression that the B3300SU has a different quick attach than standard skid steer type.
    I wonder if the design is more susceptible to this kind of failure. The quick attach on my L3200 seems very secure. Could you post a picture of your quick attach?
    Wouldn't want the OP to get a bad impression if it's not the same type.
    Here's the SSQA I'm referring to:
    Necessary Attachments on the L3200?-cimg0412-jpg
  7. #17
    Join Date
    Jan 2011
    Posts
    6,514
    Below photos show kubota factory Quick Attach mechanism for LA504 FEL which is standard on Kubota B3300SU tractor/loader package.
    Operator should just have to remove security pins from four pivot pins, pull them, and nudge the bucket off with the joystick control.
    I had the experience where one of the lower security pins flipped out, allowing the left, lower, pivot pin to drop out. Then bucket support frame warped so replacement pivot pin could NOT be inserted.
    Offending pivot pin is also picutured, last. I found it a week/$1,200 later, where I had been working. So glad I have Kubota insurance. My out-of-pocket was $250, bad enough.
    Now the four pivot pins are secured with 6mm machine screws and nylon lock nuts. Downside is bucket is no longer Quick Attach.
    If I had it to do over I would have stayed with the standard, NON-QA, bucket as I have never removed the bucket during first year of ownership.
    The four QA pivot pins are exposed to dirt/dust. I lubricate them with graphite.
    Attached Thumbnails Attached Thumbnails Necessary Attachments on the L3200?-img_0454-jpg   Necessary Attachments on the L3200?-img_0455-jpg   Necessary Attachments on the L3200?-img_0456-jpg   Necessary Attachments on the L3200?-img_0457-jpg
  8. #18
    Member
    Join Date
    Sep 2011
    Posts
    31
    Western Washington
    Thanks for the images.
    I never paid attention when I was looking at a B3300SU, just remembered the dealer saying it was kubota's version.
  9. #19
    Super Member
    Join Date
    Apr 2000
    Posts
    8,376
    Shingle Springs California
    New Holland TC40D
    TnT! I made Tnt setup on my old kubota B series; it was the Cat's Meow. Awesome! I used it all the time.
    Since I got the newer larger tractor(used), TnT has not been in the budget. And I miss it. A lot...
    RobertN in Shingle Springs Calif
Similar Threads
  1. New L3200
    By hollnagelc in forum Kubota Buying/Pricing
    Last Post: 08-09-2012, 11:51 AM
  2. Grapple WildKat Attachments!!! Skid steer Attachments!!!
    By Farminprogress in forum Attachments
    Last Post: 05-14-2012, 11:49 AM
  3. L3200
    By L3200 in forum Kubota Owning/Operating
    Last Post: 02-21-2012, 08:29 PM
  4. New L3200
    By Joe W in forum Kubota Owning/Operating
    Last Post: 07-02-2011, 01:15 PM
  5. New L3200
    By roaf3x in forum Kubota Buying/Pricing
    Last Post: 02-14-2011, 09:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
