Results 1 to 8 of 8
  1. #1
    Gold Member beckmurph's Avatar
    Join Date
    Jul 2005
    Posts
    475
    Home/Catlettsburg Farm/Robinson Creek, Ky
    B2650 TLB
    Default That didn't take long
    Or BH77 problems
    I changed the oil, filter and the HST and Hydraulic filters on Monday. I have 52 hrs on the B3200.
    After I got everything squard away and cleaned up my mess everything was ok.
    On Tuesday I checked all the fluid levels and all was well.
    I then noticed that the BH boom was not latched in placed for storage. I use the latch when stored or traveling around the area that I am working, to take the pressure off the boom cylinder.
    I found that the boom cylinder would not fully retract to latch the bh in place. That didn't take long-2012-12-09_11-40-28_655-a As you can see, the latch does not catch the pin.
    My first thoughts were: there is air in this cylinder. Worked everything to get the air out. Didn't help.
    I discovered that I could take a 6' pry bar and lift the bucket and boom enough to get the latch to catch the pin.
    So today I took the B3200 and extended the Bh boom, dipper and bucket in all directions. Hoping that there was air trapped in the cylinder. Didn't help.
    Then I streched the boom, dipper, and bucket out and layed it out as flat as possible. I used the boom to put pressure on the different cylinders eyes and pins.
    I found movement in the lower eye and pin of the boom cylinder.
    It could be the cylinder eye, or it could be the pin.
    I have worked the bh a lot in the last several weeks digging gravel out of my cousins creek, and fill dirt out of my property.That didn't take long-2012-11-16_17-27-00_290-aThat didn't take long-2012-11-16_17-26-29_373-a
    I have been working on putting driveways into our properties.That didn't take long-2012-12-02_17-14-49_370-a
  2. #2
    Silver Member reeltime's Avatar
    Join Date
    Dec 2009
    Posts
    205
    East Freetown ma
    2014 mahindra 3016 shuttle loader and backhoe with thumb
    Default
    I had same issue same hoe recall on valves call ur dealer
  3. #3
    Join Date
    Dec 2009
    Posts
    205
    East Freetown ma
    Default
    I had mine fixed 3 times finally 4 time they found out it was a recall
  4. #4
    Join Date
    Jul 2005
    Posts
    475
    B2650 TLB
    Default Re: That didn't take long
    I had talked to the dealer Friday, and he said he would need to see it. So I will have to take it to the shop this week and let the dealer fix it.
  5. #5
    Join Date
    Jul 2005
    Posts
    475
    B2650 TLB
    Well, turns out the brass bushing in the eye of the cylinder failed. There should be two bushings, but the mechanic only found one. The second bushing was not installed from the factory. So, two bushings and new pin on order.
  6. #6
    Elite Member johnk's Avatar
    Join Date
    Jun 2003
    Posts
    2,715
    western NY
    Kubota GST Grand L3130 w/ 723 loader, Ags
    Glad it was a simple fix for you. Under warranty I presume??
    Kubota grand L 3130; 723 loader; Hinged back Box Scraper; 7' HD Back Blade; Tooth Bar; PHD w/ 9 & 12 Inch Auger; PEC; Carryall
  7. #7
    Elite Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    2,810
    W Wisc
    Kubota L5240 HSTC, (Kubota L3130 HST - sold)
    Good to hear. I was about to say - use the warranty....
    ...and then put more fill over your culvert as it is too close to the surface....
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L5240HST, QA, 824 Loader, 48" Forks, 48" Grapple, rear blade, box blade, landscape rake, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
    My house build blog: http://stighouse.blogspot.com/
  8. #8
    Join Date
    Jul 2005
    Posts
    475
    B2650 TLB
    Yes it is covered under warranty.
    And yes I need more cover on the culverts. I may have to lower the one culvert. I thought we could just drop the upper culvert in the ditch, and it would be good to cover. But, that doesn't look to be so.
Similar Threads
  1. long 5-n-1
    By freddiedene in forum Hydraulics
    Last Post: 10-13-2010, 12:31 PM
  2. How long is to long for dealer repairs?
    By hevnbnd in forum Kubota Owning/Operating
    Last Post: 07-11-2010, 05:52 PM
  3. Long enough
    By Alphahunter1 in forum New Member Introductions
    Last Post: 05-17-2010, 10:09 PM
  4. Long and extra long 90s
    By Eric_Phillips in forum Hydraulics
    Last Post: 03-13-2009, 01:46 PM
  5. How long would it take....
    By TerryinMD in forum Owning/Operating
    Last Post: 10-06-2002, 08:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
