Results 51 to 60 of 63
01-11-2013, 09:30 AM #51
Re: M9540 Belly Skid Plate/Brush Guard
By not buying it with the tractor I basically lost the install. If you build a tractor on Kubota website, it's a $1156 option. The kit contains the gears and shafts to do just what you described. The 540 shaft engages one set of gears and the 1000 shaft engages a different set. The shafts are changed by removing an external snap ring. Installing the kit will be a bit more complicated but I'll explain all that when I do a thread.
Richard
Kubota M9540, JD2210
01-11-2013, 07:52 PM #52
Just a thought, I'm not sure what level the 16 gal of oil is at in relation to the pto shaft (I quess that you could estimate from the dipstick) but if you did this job with the rear elevated as much as you feel safe, you might save some oil!
We need more people to WORK for a living and less people to VOTE for a living!
(proven on 11/6/12)
01-11-2013, 10:04 PM #53
I'm curious about this option as well so i checked into the parts catalog online it looks like the entire rear cover of the trans has to come off to allow the removal of the prop shaft and install the new internal gear set so that you can install the 1000 rpm shaft. Once the kit is installed i don't think you'll loose much if any fluid swapping out the shafts
Dave
01-12-2013, 09:36 AM #54
01-28-2013, 02:18 PM #55Silver Member
- Join Date
- Sep 2010
- Posts
- 128
- Location
- Mississippi
- Tractor
- Kubota M9540 HD 4x4
01-28-2013, 05:48 PM #56
01-28-2013, 05:53 PM #57Veteran Member
- Join Date
- Dec 2010
- Posts
- 1,643
- Location
- SW VA
- Tractor
- David Brown 885, Kubota RTV 900, Kubota 9540
I might actually get mine put on tomorrow! It's supposed to be in the mid/upper 60's!
Treat me good and I'll treat you better, treat me bad and I'll treat you worse.
01-28-2013, 05:56 PM #58
We were supposed to be Sunny and mid 60s today, but it didn't happen. We've been fogged in all day with temps in high 40s. I had to haul a 16K pound load of paper rolls for a friend of mine. Am storing it in my shop tonight. Tore the crap outta my driveway getting turned around and backed into the shop. We've been dry for over a year. Got a light rain yesterday and it made it extremely muddy and soft for some reason. Not complaining though, we'll take what we can get.
Richard
01-28-2013, 06:43 PM #59Veteran Member
- Join Date
- Dec 2010
- Posts
- 1,643
- Location
- SW VA
- Tractor
The weather is crazy! This past year it snowed ( <1") once before Thanksgiving and I rolled hay in December, now its going to be in the 60's tomorrow and Wednesday then snow again Friday!
01-29-2013, 04:35 PM #60Silver Member
- Join Date
- Sep 2010
- Posts
- 128
- Location
- Mississippi
- Tractor
I'm interersted b/c I damaged one of my filters just like you did. Let me talk it over with the roommate/boss/wife. I do have a few questions it and about you're other mods (which I like all your mods).
1. Is there a hole in the skid plate for the hydraulic fluid to drain when changing the filters?
2. This past weekend I was thinking how to mount an old, metal milk crate (I have a cooler that fits in perfectly). From your New M9540HD12-1 review I can't tell from the pics, is mounted to fender? Or to the light frame?
3. You have 2 open storeage boxes to the left of your seat. One is bolted near the front axle assist lever. How did you access the nut under the there? There doesn't appear to be enough room to work unless you took the tire off or lower the fuel tank. The other storeage looks to be made out of plastic that is bolted to the fender.
4. I saw someone on here modify the skid plate for the fuel tank for their 9540. Have considered modifing it? I had a stick pop a line off my tank once. I had to lower the tank to gain access to put the line back on.
Again I really like all the mods you have posted. They look factory made, but stronger.
Similar Threads
belly plate
By candyman in forum CustomizationReplies: 19Last Post: 05-25-2011, 10:13 AM -
Skid Plate and/or Fan Guard
By Gem99ultra in forum Kubota Owning/OperatingReplies: 5Last Post: 01-07-2010, 12:22 PM -
Skid plate/ filter guard for 2210
By Hydraman in forum John Deere Owning/OperatingReplies: 1Last Post: 03-14-2006, 08:22 AM -
Belly Pan or Skid Plate Kit Manufacturer
By firtol88 in forum AttachmentsReplies: 5Last Post: 05-31-2005, 12:12 PM -
Belly Armor/Skid Plate ??
By Remnant in forum John Deere Owning/OperatingReplies: 17Last Post: 08-25-2003, 04:39 PM
