Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Super Member
    Join Date
    Sep 2000
    Posts
    6,358
    Default Re: Wheel Spacers - L3400 HST
    Quote Originally Posted by Gem99ultra View Post
    Thanks for that info outoftractluck. I am going ahead with the wheel spacer project. I've order a set of 2" spacers from Bro-Tek, which also was about $300. Bro-Tek spacers simply look a lot more professionally made than any others that I've seen on the internet.
    I am taking a shortcut though - and that is having my local Kubota dealer install them for me. I don't think I have enough grunt to handle a 500# tire, even with a dolly. Cost for that is only about $50 though.
    Too bad you don't have the adjustable rims. Others mentioned the extra stress on the bearings from spacers. It's there, but not a real issue (with Kubota's anyway) as the same rear is used with rims that are adjustable further out than your spacers.
    I've moved many a loaded tire around. Never EVER never would I use a dolly. Do it on smooth cement or dead flat grass. You can easily walk the tire around. Walk one out, roll it aside to lean against a wall or the tractor front, install the spacer, roll it back, walk it in place. You can rotate the axle or even pull up and spin the loaded tire pretty easy. The only real issue is mental, you have to know when to abandon the tire and let it fall over , 'cuz even a superhero would be seriously injured letting one fall on him! That's just so you know.
    The $50 isn't a bad price at all, but should you ever need to do it yourself, it's a 30-40 minute job for me to pull both filled rears off and swap sides (needed to adjust rims to centers for some widths). Never dropped one yet (knocking wood like mad)...
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #12
    Gold Member Gem99ultra's Avatar
    Join Date
    May 2009
    Posts
    321
    Warm Springs, GA
    Kubota L3400HST
    Right John_Bud, for me a dolly would make a heavy tire unstable. The R4 should just about stand up by itself.
    I need to take the little Kubota in for a checkup anyway, so I'd just as soon that some young mechanic take care of this while it's there. The dealer has the right tools, i.e. a tire dolly and a big impact wrench. ...yeah, I've handled some heavy stuff in my time, like pulling hydramatic transmissions and re-installing them without a jack. I suspect that if I did let a tire fall over, I'd get it up and back on somehow.
    Some of us don't age so kindly though. Strength's not what it used to be. After a heart attack & stroke in recent years, I don't have the strength that I used to have. That, and perhaps, getting to be 72 might have something to do with it :-)
    You info is, however, appreciated. If I change my mind about doing it myself, I'll keep the pointers in mind.
  4. #13
    Member
    Join Date
    Oct 2011
    Posts
    40
    Kubota L3400
    John_Bud: Thanks fo the advice. You must have some muscles! I guess I was just dumb enough to use the advice others suggested in this forum and the dealer who said to try and slide it out sideways or I'd have a real problem getting it to line up again. For me the dolly worked like a charm. The wheel sat right in there. Anyway, you probably have a lot more experience with this stuff than me but if I had to do it again I'd NEVER do it any other way. Kinda glad I changed the spacers before I read your advice.
  5. #14
    Join Date
    May 2009
    Posts
    321
    Warm Springs, GA
    Kubota L3400HST
    Well - I got the 2" spacers on. Dealer only charged me ~$40; money well spent for me. Here's a pix before and after.
    Wheel Spacers - L3400 HST-before-spacers.jpgWheel Spacers - L3400 HST-after-spacers.jpg
  6. #15
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    8,006
    Branson, Mo.
    Kioti DK35se Hydrostat
    Click image for larger version.
Name:	Before Spacers.jpg
ID:	296914Click image for larger version.
Name:	After Spacers.jpg
    let us know what you think of them, after you have had a little time. Thanks.
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks.Satisfied Everlast PA160 welder owner How to add a link to a post . Best way to search TBN
  7. #16
    Member
    Join Date
    Oct 2011
    Posts
    40
    Kubota L3400
    Money well spent indeed. Good deal! My dealer wants $100 just to pick up and deliver not including any work.
  8. #17
    Join Date
    Aug 2012
    Posts
    955
    Hartford, SD
    Kubota L3400F
    I have an L3400 with R1s on the rear and adjustable rims. After nearly tipping it over, I set the wheel spacing out to the maximum with only added about 5" increased width but made a world of difference. My rear wheels were filled all through the tippy incident and widening the rears.
  9. #18
    Join Date
    May 2009
    Posts
    321
    Warm Springs, GA
    Kubota L3400HST
    I don't think the HST's with R4s had adjustable rims as an option. That would be nice though. My wheels are also filled but even with attachments like a 500# BB, I've had it in tipping mode :-( That's NOT a fun feeling. Hopefully the extra 4" will be better.
    BTW sdkubota, the $40 the dealer charged didn't include pickup and delivery. I took care of that. BUT, before I got my trailer the dealer near Houston - in Webster, TX (name of L-D, M) charged $4.00 per mile, round trip. Absurd, but that was right in line with the rest of their labor charges. City Slicker rates.
    Now we've moved to Warm Springs, GA. The dealer in nearby Waverly Hall, GA is a good ole' country boy. Charges reasonable rates, good service, and does what he says he did. Can't ask for more than that.
  10. #19
    Join Date
    Jan 2012
    Posts
    966
    Success Missouri
    Kubota L3800DT, L3750
    That 4" will make a good deference. I have loaded R-1s set out max and my L3800 is very stable.
    Rear wheel weights would help put more weight on the ground, if needed.
    Don
    Kubota L3750 Hydro Shuttle, 4wd, FEL; L3800 Gear drive, 4wd, FEL
    Huskvarna XP chainsaws 346xp X2, 357xp, 562xp, 359, 365xpw75cc
  11. #20
    Join Date
    Aug 2012
    Posts
    955
    Hartford, SD
    Kubota L3400F
    You could probably install the spacers yourself. I was nerovous about handling the fluid filled tires by myself but wasn't a big issue. I kept them upright at all times and carefully moved them by rolling.
Similar Threads
  1. L3400 HST 4 wheel drive engagement
    By KPotts in forum Kubota Owning/Operating
    Last Post: 03-17-2011, 07:05 AM
  2. Any one get wheel spacers for their L2800 / L3400?
    By canoetrpr in forum Kubota Buying/Pricing
    Last Post: 01-05-2011, 10:42 AM
  3. Traction GC Chains, Wheel Weights, Wheel Spacers
    By FDuce in forum Massey Ferguson Owning/Operating
    Last Post: 12-18-2010, 10:23 AM
  4. L3400 wheel spacers (and/or telescoping bottom arms)?
    By MikeinMich in forum Kubota Owning/Operating
    Last Post: 09-13-2010, 04:57 PM
  5. Wheel Spacers
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 07-10-2002, 11:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
