Results 11 to 20 of 27
12-14-2012, 10:03 PM #11
Re: Valve Stem Protectors
They put them on the industrial tires but not the ag tires.
L5740 LA854 loader
L3130 LA723 loader sold
B3200 LA504 loader
B1550 sold
B2620 sold
B4200 sold
F2680E
GF1800
JD 850D Gator
JD F935 x 2 sold
Ford 555D TLB
Gehl 602 excavator
12-14-2012, 10:33 PM #12Elite Member
- Join Date
- Feb 2011
- Posts
- 3,854
- Location
- Frederick County, VA
- Tractor
- Kubota BX2360 & L4240 HSTC
My Bobcat CT235 had them on all 4 tires the L4240 just has the on the front but the rear valve stem does not stick out that bad.
12-14-2012, 10:49 PM #13Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
If I were to weld on the stem protectors, I would let out the air pressure but leave the water in to keep the rim cooler so it doesnt damage the tire bead. Put the stem on bottom dead center and weld away. Water wont boil and make steam to increase pressure till all of it gets hot which its not going to do with the small amount of welding to be done. I have welded on pressurizes pipe, vessels, tanks etc with fluid in them and high pressures without a problem but you do have to not overheat the metal to the point of weakening it enough for the pressure to blow a hole in the hot metal which is why I suggested that you reduce the pressure. A professional welder would not even need to let the air out to weld those on.
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
12-15-2012, 12:05 AM #14
LD1 - glad you posted those vids. I was about to do it otherwise...
Gary - there is a slightly different issue here. The heat from welding heats up the air in the tire which then can cause the rubber in the tire to start a chemical reaction that runs away creating ever more heat until it all blows up. It isn't about weakening the metal so much as the unintended side effect nobody thinks about.-Dave
"Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
Trailer - 10k/16' twin axle w/elec brakes
2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
12-15-2012, 07:58 AM #15Silver Member
- Join Date
- Oct 2010
- Posts
- 215
- Location
- NYS--Various Parts
- Tractor
- Airens/Simplicity/Sears
12-15-2012, 08:25 AM #16
From another website:
The most common cause of tire explosion involves pyrolysis of a section of rubber compound, usually the tire’s inner liner, due to a heat/energy source. The most common sources of heat/energy are:
• Equipment contact with high voltage power lines
• Tire or equipment fires
• Application of heat to tire components, such as welding and heating with a blow torch or overheated brakes
• Lightning strike
Pyrolysis of rubber produces flammable gases such as methane, styrene, butadiene, hydrogen, and other hydrocarbons. An explosion will occur if all of the following conditions exist concurrently:
• There is an explosive concentration of flammable gases.
• There is an adequate concentration of oxygen to support combustion of the flammable gases.
• There is an ignition source.
• There is sufficient molecular energy to sustain the explosive reaction..".........there is only one way to find out."
"Ok, hold my beer and watch this.........."
Ford 5500 Backhoe
Kubota L3400GST W/LA463 FEL
2005 Dodge 3500 4x4 Diesel
8N Rebuilt and restored
Bushhog 105 and 306 cutters
JD 261 3PH mower
3 Homemade wood hauling trailers
Dolmar 7900
Dolmar 6400 84cc ported BB kit and Muffler Modded
Sachs-Dolmar 120SI Ported
(4) Sachs-Dolmar 116SI Ported
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
12-15-2012, 08:31 AM #17
More:
Pyrolysis is defined as the irreversible chemical decomposition of a material under the sole action of heat.
In the case of a tire, degradation of the rubber takes place. This phenomenon occurs:
n when the temperature inside the tire reaches 185°C
n in the absence of oxygen (inflation with nitrogen does not eliminate the phenomenon of pyrolysis)
n in a few seconds.
Also, this phenomenon leads to a degradation of the tire’s chemical and mechanical properties, which
can occur gradually and whose effects can be cumulative following several overheating events.".........there is only one way to find out."
Ford 5500 Backhoe
JD 261 3PH mower
Dolmar 7900
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
12-15-2012, 09:06 AM #18Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,664
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Dresser TD7G Dozer
Thanks LD1 - That explains things very well. A lot more than than just hot air. Isn't it.
"If you're not making any mistakes then you're not doing anything"
L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
12-15-2012, 09:42 AM #19Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
That is why I suggested leaving the water in the tire to keep everything cool. You dont need a lot of welding to hold these on just a couple of tacks which isnt going to heat up the air to any higher temp than running down the road. If no water in the tire, put some wet rags as close to the weld area as possible to keep it cool and just run a 1/4" weld at a time and cool in between passes.
You will burn off all the paint inside if not immersed in water which could cause some rusting around the area from inside out. Best thing would be to break the bead on that side and compress the tire enough so you can brush off the old burned paint and repaint it after welding.
I forget a lot of times that some of the welders on TBN dont always have my welding skills, but it is still a pretty simple tack weld job to do and with water in the tire, in my case I would just weld it on without depressurizing and clean the slag, paint and call it good. Rims look to be about 1/8" thick so burn thru is not going to be a problem for a welder with stick and Mig would be super easy.2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
12-15-2012, 12:32 PM #20
My plan was to lay the tire on it's side and debead the tire on one side so I could just use a board or something to keep the tire away from the steel. I figure it'll be a good time to replace the stem anyway if you don't have tubes.
Kubota L4240,Case 580K backhoe, Case 450 Dozer
Similar Threads
Valve stem protection
By General Lee in forum Kubota Owning/OperatingReplies: 4Last Post: 10-21-2012, 09:38 PM -
Is this Valve Stem Tubeless?
By SandburRanch in forum New Holland Ag TractorsReplies: 6Last Post: 04-04-2011, 04:51 PM -
Valve stem protectors
By cptdave in forum Kioti Owning/OperatingReplies: 45Last Post: 02-13-2011, 02:00 AM -
Tire stem protectors
By George in Spokane in forum CustomizationReplies: 25Last Post: 09-30-2008, 12:56 PM -
Valve stem "got me"
By Phils in forum Power TracReplies: 11Last Post: 06-21-2005, 08:55 PM
