maindia is the largest tractor producer in the world (does this include their copy of jeeps?), just not the USA i guess.
I wish these monkey would spend money on "real world" comparisons;
compare speed with a full load of dirt in across some distance point a - b I don't see that as very useful, I can travel much faster than I ever would if I chose to, although I'd spill have the load and bruise my kidneys. Bucket size is more useful to look at and is simply related to FEL lift cap. ok use some creativity here, equal load climbing the same grade in the same range. To me this will demonstate hydrostatic abilities. I remember reading the bobcat brand tractors would not pull a grade empty in high range, this was a big issue to owners
compare full down to full top dump speed on the FEL The larger the cylinders, the stronger the loader and the slower it will lift. My DK45 will lift 2.5X what my CK30 would, but it's slower, I still think it's a positive. ever watch a big wheel loader operate at a construction site? scoup, run, dump, and back for another load. True larger cylinders are slower when they are being operated by a lower volume pump, this is where gpm's come into play
compare full right to full left speed on the BH
compare maintence points and how easy they are to reach
compare both units pulling a disc, pulling a brush hog, pushing a snow plow With the same tires, this will mostly come down to weight. Just look at which one is heavier, that'll tell you how well they'll pull/push. PTO hp is straight forward for a bush hog. agree but if one has to run in a say in low and the other can do it in medium range this would be good to know before you buy
compare turning radius
compare stabilty on a hill
most importantly to each of us in the saddle, compare the seat, stearing effort, and ease of operation of the controls Everybody will have their own preference, that's why you have to sit in the seat yourself if one has 1" of seat foam and the other has 4"of seat foam, diff lock location (i hate mine), reach to loader joy stick (not a big deal to most but after several hours of moving dirt this becomes important), quickness of gear changes. ect....
what good is everything else if you cant stand to be on it for 8 hours?
im not saying anything about either bota or maindia, just saying compare things that matter
