Results 1 to 10 of 10
  1. #1
    Platinum Member Tollster's Avatar
    Join Date
    Feb 2005
    Posts
    974
    Benton, Pennsylvania
    Kubota, BX23
    Default ROPS Light brackets
    Any idea on how I could mount the light posts to the ROPS? I recall seeing a thread here using what I think where trailer bed brackets a while back, but could not find it. I wish I could save some threads here under my name, there are some great ideas and if I search, its either to broad or too specific..I try...I really do.
    I have a BX 23 and plan on putting a set of rectangular Hella 550 Halogens on, I did the alternator upgrade already.
    Kubota BX-23, BH, FEL, MMM, Various Bro-tek attachments, Exmark Lazermark.
    ASME Certified welding inspector specializing in Visual, Mag Particle, Dye Penetrant, and Ultrasonics
  2. #2
    Silver Member copperhead1967's Avatar
    Join Date
    Jun 2005
    Posts
    215
    greensburg PA
    kubota BX22
    Default Re: ROPS Light brackets
    I used aluminum clamps were used to hold a truck cap on a pickup bed. I had to buy a longer bolt and used the hardwae that came with the light to mount IT to the clamp. No drilling in ROPS and can move the lights later on if you want. I did drill a hole in the plastic cup holder for a toggle switch. I ran the wire up the inboard side of the ROPS thru some automotive wiring harness tubing and used Zip Ties to secure the tubing from getting snagged. I posted a pix a long time ago but can't seem to find it now. Been doing fine for 5 or 6 years now.
    STAY away from dealer on RT30 in Western PA. IM me to find out why !
  3. #3
    Silver Member jambx's Avatar
    Join Date
    May 2007
    Posts
    228
    Southern CT area
    B2920 TLB, ZD21-60P
    Here it is - still working like a champ - out of the way and solid as a rock.
    http://www.tractorbynet.com/forums/k...t-project.html
    B2920 TLB, Thumb, 48" Box Blade, 48" Bush-Hog, 48" Culivator and Hiller, 15" Potato Plow, 60" Blade, 60" Landscape Rake, 48" Tooth-bar, 3pt Trailer Hitch, Z21-60P
  4. #4
    Platinum Member chipsndust's Avatar
    Join Date
    Mar 2006
    Posts
    506
    central NY and Adirondacks
    JD2305 w/R4 tires
    A couple of spacers between the pipe and the ROPS allow space to thread wires through existing holes in the underside of the ROPS. Twisting the pipe raises/lowers the beam; the light can be twised left or right. I added a switch on the instrument panel.
    Attached Thumbnails Attached Thumbnails ROPS Light brackets-rear-worklight.jpg   ROPS Light brackets-rear-worklight-switch.jpg
    No man is prejudiced in favor of a thing knowing it to be wrong. He is attached to it on the belief of it being right.. ~Thomas Paine, Rights of Man, 1791
  5. #5
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,804
    NOT HERE
    Get some u bolts a the hardware store. I took a scrap piece of aluminum and made a piece for the light to clamp to.
  6. #6
    Elite Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    4,383
    Nova Scotia
    BX 25
    I just made a simple T out of angle and flat. Made a swivel magnetic mount, but you dont have to add the magnets.http://www.tractorbynet.com/forums/c...t-upgrade.html
  7. #7
    Join Date
    Feb 2005
    Posts
    974
    Kubota, BX23
    Thank ya'll, I knew there would be some great ideas here, as I followed them for years before I got my light package , or santa got my light package I should say.
    Have a Merry Christmas!
    Tol
  8. #8
    Join Date
    Mar 2006
    Posts
    506
    JD2305 w/R4 tires
    Quote Originally Posted by Tollster View Post
    Tol
    Yeah Tol, pick one or a combination of a couple, get it done and post some pictures.
    Merry Christmas to you, too.
  9. #9
    Platinum Member amigauser's Avatar
    Join Date
    Oct 2005
    Posts
    948
    Unionville, Connecticut USA
    Kubota Grand L 3240HST
    Kubota Grand L3240HST, LA724 FEL with QA, 72" QA bucket, Turf Tires, QA snow plow, QA Loader Buddy, Bradco Pallet Forks, 72" Ratchet Rake. Leinbach 72" pine straw rake, GroundWorks brush forks and Kubota L series ballast box.
    Kubota Orange RTV 500
    Stihl stuff
  10. #10
    New Member
    Join Date
    Oct 2011
    Posts
    4
    Binbrook Ont. Canada
    Kubota BX23
    I mounted a pair of amber 4 way flashers on my rops by utilizing the 3/8" holes that were already pre drilled by the previous owner. Using this mounting scheme will certainly hide any exposed wiring because the hollow rops is used as the wire raceway. The amber lamps are in fact identical to the origional ones that came with the tractor. They have threaded mounting studs, you can probably make your own mounting studs if your quartz lamps came without them. You can either thread the drilled holes with a threading tap or use the mounting nuts that come with the lamps. Locating the wiring for the hookup should be easy, you will find exposed tractor wiring under the rear right fender. Only thing you might want to consider is the wiring gauge and fusing. I dont know how much current your new lamps may draw. Good Luck
Similar Threads
  1. No-Weld Trick Work Light Brackets
    By JoeL4330 in forum Customization
    Last Post: 01-12-2013, 12:12 AM
  2. RTV ROPS Mounting Brackets
    By Misfire in forum ATVs & Utility Vehicles
    Last Post: 09-02-2012, 03:25 PM
  3. Brackets to convert ROPS to Folding
    By npalen in forum Build-It Yourself
    Last Post: 04-24-2012, 11:58 PM
  4. B3030 Alternator Kit? ROPS brackets? Lights?
    By BandDcabinet in forum Kubota Owning/Operating
    Last Post: 01-30-2008, 10:42 AM
  5. Grapples and Work Light Brackets
    By Rory_Rhodes in forum Kubota Owning/Operating
    Last Post: 01-17-2006, 12:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
