Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    14
    Decatur,IL
    Kubota L3200
    Default L3200 Fuel Cap Leaking
    Anyone have trouble with their fuel cap leaking on the L3200? If so what did you do to fix it? Looks like there is a small nick on the sealing surface.
    It appears that a small amount of fuel is leaking around the rim of the cap / tank when fuel sloshes around in the tank.
    L3200 Fuel Cap Leaking-img_0881-jpgL3200 Fuel Cap Leaking-img_0883-jpgL3200 Fuel Cap Leaking-img_0888-jpg
  2. #2
    Join Date
    Nov 2004
    Posts
    159
    Nebraska
    Kubota B2400 HST
    Default Re: L3200 Fuel Cap Leaking
    I have a b2400 and the fuel cap will not go on tight. When I tighten it down it pops off. I've replaced it once. The new one worked for a while. Then the new one would not tighten. What I do now is to place a rubber band around the spout and screw on the cap. This works until I have to remove the cap because the diesel degrades the rubber. New rubber band every fuel change.
    I'm disgusted with the whole thing. Whoever heard of fuel caps going bad. And to make it worse the cost of a new one is like $20-$30.
  3. #3
    Join Date
    Jul 2012
    Posts
    160
    St.Albans,Maine
    TYM T451,bolens G214.John Deere 440CID,Shaver sc25 stunpbuster,woods750 backhoe,wallenstien splitter,woods bb60 mower,woods 60"tiller,countryline tiller,99 international 4700 car carrier
    Try going down to the local auto parts store pickup a piece of rubber cork gasket material (has ground ruber and cork in composition)cut a gasket a tad larger than the inside of your cap and cut the center out to fit in your cap.You can get different thickness's of this material Id try the thicker one first.It will compress everywhere except where your nick on the filler neck is and make a good seal also diesel will not affect it
  4. #4
    New Member
    Join Date
    Nov 2012
    Posts
    14
    Decatur,IL
    Kubota L3200
    Thanks for the replies. Well I sanded the rim down to take the nick out. Re-installed the cap and still have a leak. I am wondering if my cap might be the problem. Can anyone with a L3200/3800 verify that the inside of my cap has the correct seals?
  5. #5
    New Member
    Join Date
    Aug 2011
    Posts
    24
    KY
    Kubota L3800
    My l3800 looks to have the same gasket as yours and will leak a bit when full if I don't torque it down a bit more than usual. I am planning on adding a viton o-ring to it one of these days.
  6. #6
    Gold Member kubotacres's Avatar
    Join Date
    Oct 2011
    Posts
    374
    Louisiana
    Kubota L3560 HST
    I've never noticed any leakage on my L3200. I'll look at it closely next time and see if there are any differences. Which i doubt it is..
    2016 Kubota L3560 4x4,HST, LA805, QA 72" Bucket, Landpride Implements
    2015 Kubota RTV500 4x4
    2014 Badboy ZT Elite Mower
    1965 IH Cub
  7. #7
    Join Date
    Oct 2011
    Posts
    374
    Louisiana
    Kubota L3560 HST
    As I thought, mine is the same as yours. Although mine doesn't leak, it doesn't look like much of a gasket in there. I guess if mine ever does start, I'll use the cork gasket to seal it.
    1965 IH Cub
Similar Threads
  1. RTV 900 Fuel Cap leaking
    By Sawdustsmb in forum Kubota Owning/Operating
    Last Post: 08-20-2012, 12:38 PM
  2. Replies: 12
    Last Post: 03-29-2012, 12:06 AM
  3. Fluid leaking out of breather cap.
    By Jeff244 in forum Parts/Repairs
    Last Post: 03-19-2011, 03:42 PM
  4. RTV-Leaking fuel cap
    By pangadotcom in forum ATVs & Utility Vehicles
    Last Post: 11-07-2006, 09:47 PM
  5. Hydraulic Fluid Leaking from res. Cap?
    By gt14 in forum Yanmar
    Last Post: 04-25-2006, 11:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
