Results 1 to 7 of 7
  1. #1
    Join Date
    Oct 2007
    Posts
    57
    Southern Ontario
    2006 BX2350
    Default BX Expanded Work Light Kit
    I'm planning to order these lights and I would like to hear from those who have used them as to if there is a noticeable difference in performance between the 4 3/4" and 6" lights, and if the 3 light kit would be necessary/superior to the 2 light kit. Any help from owners would be appreciated. Thank you.
  2. #2
    Silver Member paulemar's Avatar
    Join Date
    May 2011
    Posts
    117
    Pittsburgh, PA
    Kubota BX25, 60" MMM, 3 point hitch
    Default
    Quote Originally Posted by magnatic View Post
    I just installed the 4 3/4"-2 light kit a few weeks ago. I mounted them on the ROPS under the top of my BX25 to give them a bit more protection from stray branches, etc. They really do light up the night especially with the headlights on too. They will basically be used seasonally during the winter with the front snowplow. The install was pretty easy once I found and removed the tape from the extra power wires on the tractor. In hindsight, I should have purchased the 3 light kit because there is a need to see when backing up on those cold dark nights. All parts seem to be of good quality and everything needed for the install is included. I'm happy!
    BX25, "60" MMM, 3 point hitch, Brinly 12" cat 0 1 bottom plow, TSC Countyline carry all, Kubota ballast box, 4X4 Loyal drag harrow, BXpanded Piranha tooth bar, Bro-Tek rear skid plate, Bro-Tek wheel spacers, Bro-Tek backhoe ripper tooth. Kubota BX2763A front plow, Phoenix T4 48" rototiller, Harbor Freight Quick Hitch, BXpanded Quick-on Work light Kit.
  3. #3
    Join Date
    Dec 2009
    Posts
    755
    Kansas...USA
    Kubota B2620
    Default Re: BX Expanded Work Light Kit
    In my case, I was in a hurry to get it done for an upcoming hay ride. So I ordered the small set of two and they worked fine for me just like paulemar. If one wants to get more involved in such lighting, he could spend quite a bit more or a bit less. The BX-Expanded product does just as it describes and served me well on the BX. I then transfered them to my new Kubota B2620 where they hooked up just as easily. I think my BX2660 could have handled a three light set up, especially if there were a seperate set of switches. Cheers Mike
    Kubota B2620 HST
  4. #4
    Silver Member George the Beagle's Avatar
    Join Date
    May 2011
    Posts
    109
    Southern Maine
    BX 1860
    I have the smaller set and they throw plenty of light. I have a front mount snowblower and the stock headlights are effectively blocked by the blower (and the FEL when it's being used) so these lights are an excellent addition. You'll like them--plenty of light from the smaller ones.
  5. #5
    Join Date
    Apr 2011
    Posts
    585
    Boston
    L3700SU
    I got my father a set for XMas, went with the smaller set and just 2 of them. Now I wonder if a 3rd for backing up would have been a good idea.....dammmmmm.
  6. #6
    Join Date
    May 2011
    Posts
    117
    Pittsburgh, PA
    Default
    Quote Originally Posted by Tomtint View Post
    I'll probably wait until this coming summer, but I think I'll add an LED facing the rear. There are only 2 wires to tap the new light into, so that will be the easy part. Making a decent looking, functional, mounting bracket will a little more of a challenge. It's too bad they don't make an add-a-light kit or sell the mounting brackets separately for those of us who now think the 3 light option would have been a better choice. Hint, Hint!
  7. #7
    Join Date
    Oct 2007
    Posts
    57
    Southern Ontario
    2006 BX2350
    Thank you so much for your advice. Based on your recommendations, I just ordered a 3 light set of the smaller lights. I appreciate your help.
Similar Threads
  1. BX Expanded work lights
    By Hondapro in forum Kubota Owning/Operating
    Last Post: 10-15-2010, 06:42 PM
  2. B7610 Work Light Kit
    By Buckeyeman in forum Kubota Owning/Operating
    Last Post: 09-14-2009, 10:04 PM
  3. Kubota B73 Rear Work Light Kit
    By Farmall45b in forum Kubota Buying/Pricing
    Last Post: 12-03-2008, 03:45 PM
  4. Why do I have a work light fuse, but no work light?
    By StrangeRanger in forum Kubota Owning/Operating
    Last Post: 03-29-2007, 10:25 PM
  5. 3120 Rear Work Light Kit
    By Malvern in forum John Deere Owning/Operating
    Last Post: 10-31-2006, 10:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
