Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. #21
    Gold Member
    Join Date
    May 2009
    Posts
    263
    South Jersey
    Kubota BX25D
    Default Re: BX2200 belly mower deck removal
    Quote Originally Posted by horsefarm84 View Post
    Thanks Jeff for the info. I think I will probably get something like the items in the link to better store my deck during the winter. I currently have it leaned up against the wall in my garage.
    thanks again,
    ryan
    I have the kit with the 5" wheels. It makes it very easy to roll the deck where you need it. Besides just storage, it helps with maintenance. I can roll it outside to pressure wash the deck on both sides. It is also convenient when taking off the blades for sharpening/maintenance.
  2. #22
    Veteran Member crbr's Avatar
    Join Date
    Apr 2007
    Posts
    1,688
    East TN
    Kub - 2K6, B7800
    Quote Originally Posted by Jeff H View Post
    I too use the hoist for maintenance on the MMM, particularly when removing the blades. I lift the deck 90 deg vertical and sit on a milk crate to remove the blades for sharpening. Not trying to one-up you, but merely elaborating on uses for creativity.
    ** Kubota **
    Psalms 86
    John 1:12-13
    Duraflap / Kaydenco not worth a hoot for service or products.
    "Google" is a proper noun, not a verb.
    If you mean what you say, then say what you mean, or just don't say anything
  3. #23
    New Member
    Join Date
    Dec 2012
    Posts
    19
    Huber Hts, Ohio
    Kubota BX2200
    Loudo,
    Attached are photos of the front mount quick lift (BX2711) and the snowblade (bx2763)
    BX2200 belly mower deck removal-quick-20hitch-20installed-jpgBX2200 belly mower deck removal-kubota_bx2763_blade_bx2711_quick_hitch_1200_walworth_24329875-jpg
  4. #24
    Gold Member
    Join Date
    May 2009
    Posts
    263
    South Jersey
    Kubota BX25D
    I didn't realize there was another model quick hitch.
    I have the BX2751 quick hitch where the cylinder is centered and sits higher. On mine if you disconnect the snow blade, you still cannot leave the quick hitch on and re-attach the loader as the loader will hit the quick hitch. The whole thing has to come off. So it is not so quick if you want to switch from loader to blade and back.
    Looks like the low profile of that BX2711 would allow it to stay attached to the tractor with the loader on?
  5. #25
    Platinum Member SeymourBota's Avatar
    Join Date
    Aug 2004
    Posts
    783
    Central Vermont
    Kubota B2410, BX2200
    I installed my quick lift (BX2711) and front-mounted snow-blade (BX2763). I had to remove the front mower deck mount kit to get the BX2711 mounted but both were a piece of cake. After that, I simply drove up to the snow blade and it mounted up easily as well; whole process tool about 30 minutes.
    New problem.....My BX2200 has a mounted joystick-type hydralic countroller on the driver's right side with (6) male hydro connectors; (2) are used to connect it to the parent system and the other (4) are available for the attachments. The BX2711 has (2) hydro hoses to adjust up/down and the blade has (2) hoses to adjust the blade's angle of attack. I have all the hoses connected but their movement is very minimal. both only have about 1/4" to 1/2" of travel. Essentially, the blade is currently at a straight 90 degree angle of the tractor and is positioned about 6" off the ground. I can't adjust the blade at a slanted angle or lower it closer to the ground. Any ideas what may be occuring or what I may have done wrong?...
    The hoses are not connected correctly. Try changing two of them to get the back and forth flow of hydro fluid needed to operate either the up/down or angling.
    Peter
  6. #26
    New Member
    Join Date
    Dec 2012
    Posts
    19
    Huber Hts, Ohio
    Kubota BX2200
    SeymourBota, That was my problem...I had each set of hoses connected on my 4-way valve horizontally, not vertically... It works perfect now! I will probably get some color coding labels for the hoses and connectors. I can't believe I'm saying this but i hope I get more snow so I can try it out
    Thanks to all the responders for your guidance. I really like this site! The members here are very helpful!
  7. #27
    New Member
    Join Date
    Dec 2012
    Posts
    19
    Huber Hts, Ohio
    Kubota BX2200
    Jeff,
    The 2711 hitch "might" allow you to have both the loader and the hitch mounted (I don't know for sure as I don't have a fron loader yet) but I will have to remove the hitch when I reinstall my MMM in the spring. After the guidance I received from this thread...It should be a big deal.
    BTW...I'm looking for an LA211 front loader...I'm amazed how hard they are to find used (separate from the tractor).
  8. #28
    New Member DiggerDog's Avatar
    Join Date
    Oct 2012
    Posts
    15
    Fredericton, NB
    Kubota BX25
    Default
    I had a similar problem when I installed my front mount snowblower. The hoses were color coded when I received it, and I hooked the blue to blue and the red to red. It wouldn't work at all, so I reversed the connections, and then it worked. I changed the color coded rings to match and was good to go.
  9. #29
    Veteran Member NY_Yankees_Fan's Avatar
    Join Date
    Mar 2002
    Posts
    2,210
    Warren County, NJ (60 miles from NYC)
    Kubota BX 2200
    Jeff,
    Take a look at the Woods FEL I believe they make an after market unit for the BX 2200 or at least did so in the past.
    AKA Tom
    #28 World Series Champions for the Yankees in 2014
    Kubota BX 2200, FEL, 60" MMM with Gator Blades, 48" Kioti Aerator, M96 Herd Seeder, W.R. Long Tooth Bar, 48" First Choice Tiller, Kubota BX 2750 Front Snowblower, Sims Cab, MacKissic Chipper TPH 122, Carry All, Canopy, and Weight Box
  10. #30
    Silver Member Loudo's Avatar
    Join Date
    Dec 2011
    Posts
    116
    Bundaberg Queensland Aus.
    Kubota BX2230
    Thank you for the pix Horse. I have never seen snow equipment nor the front mounts.Happy plowing
    The Bear lives here...
Similar Threads
  1. Video of belly mower removal on 2305?
    By srs in forum John Deere Owning/Operating
    Last Post: 06-17-2015, 01:55 PM
  2. trying to level the deck on my belly mower
    By joecarey in forum New Member Introductions
    Last Post: 09-10-2011, 11:30 PM
  3. Mowing BX2200 Mid Mount Mower deck belt removal question
    By THEDADLORD in forum Kubota Owning/Operating
    Last Post: 04-01-2007, 06:27 PM
  4. Mowing CK30 HST Belly mower removal
    By rk20033 in forum Kioti Owning/Operating
    Last Post: 02-26-2006, 04:54 AM
  5. Mowing Belly Mower REMOVAL
    By StanMcCluskey in forum Yanmar
    Last Post: 11-15-2002, 03:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
