Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
  1. #1
    New Member
    Join Date
    Dec 2012
    Posts
    19
    Huber Hts, Ohio
    Kubota BX2200
    Default BX2200 belly mower deck removal
    Hello,
    I'm a relatively new kubota BX2200 owner. The one I bought was lightly used and came with the belly mower deck already attached and the BX2763 snow blade and BX2711 front hitch. As I was trying to figure out how to install the front hitch and snow blade, I realized the belly mower deck had to come off. Does anyone have instructions how to do either operation, removing the mower deck and/or attaching the front hitch. I have done several searches and haven't found instructions, only pitfalls when removing and reattaching the deck, such as improperly connecting the PTO.
    Any guidance is greatly appreciated...
    ryan
  2. #2
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    2,009
    Rochester, MN
    Kubota BX2230
    Default Re: BX2200 belly mower deck removal
    Drop the mower all the way down to the ground. You may have to spin your limit control knob to do that. On the front right, pull the lock pin out and then the front left lever should pivot down and release the mount. You probably want to remove this pivot lever completely for other use. The front arms can also be wrestled off the front of the mower. There doesn't seem to be an ideal position on my 2230 for this to be done, but it can be done. Then reach underneath in front of the back wheels and pull the lift pins out. Raise the 3ph arms so these get up and out of the way. Now from the operator's left side reach in and slide the collar forward (right behind the knuckle) on the driveshaft. . It should settle into a detent about 1/2 inch forward. Then grab the shaft and wiggle it to help you pull it forward off the front of the rear end. Slide it out to one side or the other (oh, and you may want to turn the gauge wheels sideways before you start so that they work for you on this part instead of skidding). Reverse steps to install.
    Can't help you on the hitch or blade.
    Oh, and to TBN! I love this site and the helpful guys here.
  3. #3
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,947
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Will add, to get the height knob to move, you will have to lift the MMM all the way to the top before the knob will turn.
    I no longer have my manual or I would post pictures; RayDaKub has it down pat though and has done more work on his than most of us.
  4. #4
    New Member DiggerDog's Avatar
    Join Date
    Oct 2012
    Posts
    15
    Fredericton, NB
    Kubota BX25
    Default
    I took mine off the other day and installed my front mount snowblower. It came off fairly easily, as described, but now I am wondering how hard it will be to put back on. I guess I will find out in the spring!
  5. #5
    New Member
    Join Date
    Dec 2012
    Posts
    19
    Huber Hts, Ohio
    Kubota BX2200
    RaydaKub,
    Thank you for the instructions...it worked like a charm... The process took about 15 minutes and I didn't lose my salvation in the process the process is very easy.
    I do have one more question...I pulled the collar forward but the shaft would not come out of the rear end...the forward portion of the shaft did slide from the rear portion of the shaft... I was able to remove the belly mower away from the tractor.
    However, I'm assuming both portions of the drive shaft should have removed from the traction's drive mechanism... (if not the attached rear portion of the shaft would cause damage if the drive was accidentally engaged)... Is there a trick to knocking the rear portion of the shaft loose from the rear end?
    Thank you again for the guidance...
    ryan
  6. #6
    New Member
    Join Date
    Dec 2012
    Posts
    19
    Huber Hts, Ohio
    Kubota BX2200
    Thanks to TripleR and DiggerDog for your advice as well.
  7. #7
    Silver Member Loudo's Avatar
    Join Date
    Dec 2011
    Posts
    116
    Bundaberg Queensland Aus.
    Kubota BX2230
    Welcome horsefarm84. yessir , both sections have to be removed, if the shaft has not been removed for some time you may have to use some spray lube and gently work the shaft to back and forward to remove it. I still have the original manuals and can send you pix if you want, I am not sure if the BX22 and BX2230 are the same ,maybe someone can help? My mmm is in a corner of my shed as I found attaching and removing it a PITA, and have opted for a rear flail mower and have made a plate that protects the underneath of the tractor thanks to leejohn who sent me the plan,it's on another thread somewhere here. I hope my is of some help.
    The Bear lives here...
  8. #8
    Veteran Member NY_Yankees_Fan's Avatar
    Join Date
    Mar 2002
    Posts
    2,210
    Warren County, NJ (60 miles from NYC)
    Kubota BX 2200
    Horse
    Pull on the collar towards the front of the tractor and the shaft will come off. Look at the collar on the snowblower shaft it moves, you will need to pull it and lock it in the back position to get the shaft on. Push the collar forward and lock it onto the drive unit for the snowblower . Make sure it is place because if it does not lock it will come free and do a lot of damage.
    AKA Tom
    #28 World Series Champions for the Yankees in 2014
    Kubota BX 2200, FEL, 60" MMM with Gator Blades, 48" Kioti Aerator, M96 Herd Seeder, W.R. Long Tooth Bar, 48" First Choice Tiller, Kubota BX 2750 Front Snowblower, Sims Cab, MacKissic Chipper TPH 122, Carry All, Canopy, and Weight Box
  9. #9
    New Member
    Join Date
    Dec 2012
    Posts
    19
    Huber Hts, Ohio
    Kubota BX2200
    Thanks for the advice...I've heard about the damage the shaft can cause if it comes loose and I'll be extra careful come spring when I re-attach the deck. Thanks again to all! Happy New Year
  10. #10
    New Member
    Join Date
    Dec 2012
    Posts
    19
    Huber Hts, Ohio
    Kubota BX2200
    Thanks Loudo,
    I sprayed some PB Buster on it and work it awhile and it finally came off...
    Thanks again
Similar Threads
  1. Video of belly mower removal on 2305?
    By srs in forum John Deere Owning/Operating
    Last Post: 06-17-2015, 01:55 PM
  2. trying to level the deck on my belly mower
    By joecarey in forum New Member Introductions
    Last Post: 09-10-2011, 11:30 PM
  3. Mowing BX2200 Mid Mount Mower deck belt removal question
    By THEDADLORD in forum Kubota Owning/Operating
    Last Post: 04-01-2007, 06:27 PM
  4. Mowing CK30 HST Belly mower removal
    By rk20033 in forum Kioti Owning/Operating
    Last Post: 02-26-2006, 04:54 AM
  5. Mowing Belly Mower REMOVAL
    By StanMcCluskey in forum Yanmar
    Last Post: 11-15-2002, 03:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
