Page 14 of 17 FirstFirst ... 411121314151617 LastLast
Results 131 to 140 of 164
  1. #131
    Platinum Member Firefighter Kubota's Avatar
    Join Date
    Aug 2008
    Posts
    573
    Seacoast NH
    Kubota 7510
    Default Re: HOW DO YOU TOW YOUR TRACTOR?
    Good luck with the dealer. They really don't have a leg to stand on morally, ethically or legally... but I'm sure they'll try to talk their way out... If they waste more than 30 minutes of your time and you don't have a new 7500# w/ brakes on BOTH axles, I'd walk out and write the state attorney general... Maybe even an local lawyer?
    Really , only 2 dealers sell trailers with brakes??? that makes NO sense...Its illegal
    In NH any trailer with a GVW of 3000# has to have electric brakes on all axles.
    Good luck and keep us posted!
    B 7510
    FEL 302, Rear remotes, Hydraulic Toplink, Blockheater, 60" MMM, Pats easy change, 6' York rake, 5' grader blade, Powerhorse Log splitter, 6.5 ft Western plow, 3 pt 2" trailer reciever, Bucket forks, "Thumb" grapple, Loaded Turfs, Carver wear blade, 40 AMP alternator, AND A CUP HOLDER!
    IAFF L-2892
  2. #132
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,800
    NOT HERE
    L3200- 2623
    LA524-805
    Bucket-265
    Quick Attach- 110, I am guessing
    BH77- 850
    16" Bucket- 84
    Total weight-4737
    So you are between 4500-5000lbs.
  3. #133
    Gold Member
    Join Date
    Oct 2010
    Posts
    479
    Northern, NJ
    Kubota L45
    I've been mulling around reading this and have a quick question/point.
    Not that I advocate being right up against the limits, but...
    If a trailer is rated for 7k lbs GVWR, and the trailer weighs 1500 lbs it seems the general consensus is that 5500 lbs is the max load that can be placed on this trailer.
    HOWEVER
    Since the truck should be taking 15% of the load for proper tongue weight, can the load placed on the trailer actually be 6550 lbs?
    Clearly that is provided the axle weights don't go over their individual ratings and the hitch is rated for the tongue load.
    ac
  4. #134
    Gold Member
    Join Date
    Apr 2012
    Posts
    253
    JACKSONVILLE, AL
    2011 KUBOTA L3200 W/ LOADER, BH77 BACKHOE
    Quote Originally Posted by Firefighter Kubota View Post
    Alabama Law is the same...problem is no one checks this in our state. No one inspects whats going on, and the dealers are doing what most dealers do.....moving units as quickly as possible to make a buck. I was actually hoping I was by myself on this and just had a streak of bad luck but what I found was that this is regular practice. I'd be willing to bet that Alabama is not alone either. I also did research and found that Kubota requires all dealers to have their personell TRAINED by the states DOT or Public Safety on a yearly basis (at least in Alabama), and this is done because of all the deliveries they make and changes in laws or updates, so that only reenforced my suspicions that they DO KNOW WEIGHT LIMITS AND TOWING/TRAILER LAWS. They just choose to ignore what is not governed regularly.
  5. #135
    Join Date
    Aug 2008
    Posts
    573
    Seacoast NH
    Kubota 7510
    Quote Originally Posted by avc8130 View Post
    HOWEVER
    ac
    You are correct above as in bold... that is the GVWR of the trailer...The towing vehicle is not included in calculations
    B 7510
    IAFF L-2892
  6. #136
    Gold Member
    Join Date
    Apr 2012
    Posts
    253
    JACKSONVILLE, AL
    HOWEVER
    ac
    Thats the problem...the trailer is rated at 5000# GVW. The trailer I got is stamped "5000lbs maximun weight limit" and "700lb tongue weight". That means the tractor alone exceeds the limit.
  7. #137
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    3,772
    SW Pa.
    Massey Ferguson GC2400
    Quote Originally Posted by PAPPASMURF View Post
    I hope they fix the problem real quick for you.
    And don't forget to get extra straps for the FEL and Backhoe...........and the backhoe is required to be resting on the deck, it cannot be suspended in the air.
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  8. #138
    Gold Member
    Join Date
    Apr 2012
    Posts
    253
    JACKSONVILLE, AL
    Quote Originally Posted by Don87 View Post
    Thanks Don....I'll update everyone after this is resolved.
  9. #139
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,800
    NOT HERE
    I don't know if his trailer is long enough to do that.
  10. #140
    Super Member
    Join Date
    Mar 2008
    Posts
    6,427
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    As I understand it, if there is a transport lock (ie: a metal pin to lock the boom up and to keep it from swinging) the boom can be in the air.
    Aaron Z
    If mankind minus one were of one opinion, then mankind is no more justified in silencing the one than the one - if he had the power - would be justified in silencing mankind.
    John Stuart Mill
Similar Threads
  1. Replies: 0
    Last Post: 08-12-2012, 09:03 AM
  2. tow tractor in india --
    By eric and his rtv in forum Photos
    Last Post: 12-15-2010, 11:31 AM
  3. Truck vs Tractor TOW
    By wkpoor in forum Owning/Operating
    Last Post: 06-16-2008, 06:04 PM
  4. How often do you tow your tractor
    By goodoleboy in forum Owning/Operating
    Last Post: 11-02-2005, 12:59 AM
  5. Converting a B9200 HSD Tow (airline tow) to Ag
    By chrisbarbee in forum Kubota Buying/Pricing
    Last Post: 08-12-2004, 03:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
