Results 21 to 30 of 46
01-11-2013, 07:04 PM #21
Re: New snow plow project for your viewing pleasure
Thanks. I haven't got to use mine enough yet to know if it is working right or if the cylinders on the very used plow I bought are scrap iron.
01-11-2013, 07:14 PM #22Elite Member
- Join Date
- Feb 2011
- Posts
- 3,805
- Location
- NOT HERE
- Tractor
A advantage to it is you can leave your loader on and switch back to the bucket easily especially if you have SSQA. I went with a loader mounted blade because I could switch it to another tractor easily versus a subframe mount would require some work because it is more less tractor specific. You can also stack snow relay high with a loader mounted blade. A subframe mount probably does work better.
01-11-2013, 10:22 PM #23
For me it it was one less implement change. I need both the plow AND the loader...and unless its alot of snow I use just the loader and grader blade on the rear... For large snow falls I can plow with the blade, drop the blade with only 2 pins ( as it mounts into my bucket) and then pile /move snow with the bucket...
Otherwise I need to drop the plow, 4 pins, back up and move over and then hook up the bucket with 4 pins... It also saved me from making a plow sub frame... Also, do to the extended length of the plow mounted inside my bucket, I can push snow deep and high... Almost higher than I can pile with the bucket...B 7510
FEL 302, Rear remotes, Hydraulic Toplink, Blockheater, 60" MMM, Pats easy change, 6' York rake, 5' grader blade, Powerhorse Log splitter, 6.5 ft Western plow, 3 pt 2" trailer reciever, Bucket forks, "Thumb" grapple, Loaded Turfs, Carver wear blade, 40 AMP alternator, AND A CUP HOLDER!
IAFF L-2892
01-12-2013, 09:56 AM #24
Same thinking here. With a JD carrier I can pull two snap clips and drop the bucket in thirty seconds then hook into the plate mounted to the plow ,re insert the snap rings , attach two hoses to the third function disconnects and be in business. The plow won't be much further out then the bucket was and that puts the end of the blade where I can see it. And I can use the loader arms to lift the plow any height needed to step wing back or push back banks.
01-18-2013, 02:57 PM #25Silver Member
- Join Date
- Nov 2004
- Posts
- 123
- Location
- Nebraska
- Tractor
- Kubota B2400 HST
Here's how it looks after the first coat of paint. Hopefully I'll get the second coat of paint on tomorrow. Then I can start working on getting the hydraulics hooked up.
01-18-2013, 03:56 PM #26
That ain't Kubota orange!!
01-19-2013, 07:35 AM #27Super Star Member
- Join Date
- Apr 2000
- Posts
- 11,418
- Location
- Lebanon,NH.
- Tractor
- Kubota L2800HST w/Frontloader & CC 2042
Nice job.
All thats missing horse shoe for luck,by that I mean..whew I was luck I miss the mail box,auto etc. when plowing at night.
01-19-2013, 03:37 PM #28Silver Member
- Join Date
- Nov 2004
- Posts
- 123
- Location
- Nebraska
- Tractor
- Kubota B2400 HST
Second coat of paint. Now on to the hydraulics.
01-19-2013, 05:01 PM #29New Member
- Join Date
- Jun 2012
- Posts
- 4
- Location
- Chapel Hil,ncl
- Tractor
- new holland tn65
We were promised a pushable snow last night but it missed me by 10 miles. All dressed up and nowhere to go. So, I thought I'd post some pictures anyway. The front old western? plow was inherited from my father and has now been refitted on my third tractor, This time a Branson w/ QA loader, which makes switching a snap compared to lining up the old pin on rigs. The rear blade is an old State surplus highway blade a got for $125. I bought 3 of them(2 for my buddy snowplower) He made one of them into a snow pusher. Anyway, with blades front an rear, you can windrow a parking lot by just putting it in reverse and backing up instead of wasting the backup time. I bought the universal attachment plate on Ebay and had it welded to the front plow. Now all we need is snow! We got zero pushable last year.
01-20-2013, 12:57 PM #30Silver Member
- Join Date
- Nov 2004
- Posts
- 123
- Location
- Nebraska
- Tractor
- Kubota B2400 HST
I installed the hydraulics last night. The 2-foot hoses to the cylinders seem a little short. I've ordered some 3-foot hoses to replace them. Works good.
Note the cushion valve to provide extra protection against non-symmetrical forces applied to the plow.
I also had to replace one of the cylinders because it had a connector broken off and I could not get the rest out of the hole. I'm still thinking about drilling it out and trying to re-thread the hole. But that's something I've never done before so I'm a little leery.
The mount is not painted because I'm probably going to try and move the connection points back 12 inches. I'm still trying to decide how to do that.
Similar Threads
Here she is!! pics for your viewing pleasure
By Dingo Man in forum Kioti Buying/PricingReplies: 47Last Post: 05-16-2012, 01:41 PM -
FEL snow plow project
By sc22fo in forum CustomizationReplies: 1Last Post: 02-22-2012, 08:25 AM -
Snow plow project
By scott2360 in forum Kubota Owning/OperatingReplies: 18Last Post: 12-20-2010, 06:54 PM -
Snow 4310 snow plow project
By JB4310 in forum John Deere Owning/OperatingReplies: 1Last Post: 11-16-2009, 11:14 AM -
New project: Front Snow Plow
By SkunkWerX in forum CustomizationReplies: 44Last Post: 12-21-2007, 06:31 AM
