Dirt Dog...That is really strange. It likely started as loose bolts but we're way past that now. They sell steel bolt circles but I'm not sure if they will have your bolt pattern. If I recall, mine was some odd metric dimension. Better do that or replace that center section fast before you get into greater trouble. Lots of junkyards in the upper midwest that will likely have a used one. You just have to check around.
If you could find a center section that you bolt on over your wheel, tack weld in place and then remove for welding. Most are 1/2" thick. I know that Unverferth Wheel in Ohio will make them but surely there might be someone else. Also try the used wheel thing. I've seen them listed for sale in either Michigan or Wisconsin.
