Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Join Date
    Sep 2009
    Posts
    194
    NE ky
    Default
    This is sudt2 after warm up.
    Attached Thumbnails Attached Thumbnails UDT vs SUDT vs SUDT2?-image-4238662323.jpg
  2. #12
    Join Date
    Dec 2009
    Posts
    753
    Kansas...USA
    Kubota B2620
    Default Re: UDT vs SUDT vs SUDT2?
    Quote Originally Posted by Hersheyfarm View Post
    So, what does this suggest???.....,maybe an air emulsion, maybe contamination. It appears to have a clear area at the bottom and the top. I'm just learning.
    Kubota B2620 HST
  3. #13
    Join Date
    Sep 2009
    Posts
    194
    NE ky
    Default
    This is after sitting a half hour.
    Another member checked his on the same kind of machine and it was identical. This could be the norm for fluids, I would like to see more samples from others to know.
    Attached Thumbnails Attached Thumbnails UDT vs SUDT vs SUDT2?-image-3791408506.jpg
  4. #14
    Platinum Member nspec's Avatar
    Join Date
    Dec 2007
    Posts
    549
    Southern Rhode Island
    Kubota B2630, '53 Farmall Super H, '47 Farmall AI, '44 Farmall A
    That first thread is shows super aerated oil - you can see all the bubbles. What kind of tractor was this from? Was it overheated? How was the oil drained? Perhaps tractor has a pump that is cavitating or sucking air in the system somewhere?
    That's not normal, and not at all representative of my results with SUDT2. I made the switch because I was really just curious - it was an inexpensive upgrade over a normal oil change. I'm a skeptic by nature and didn't expect any noticeable difference. The results I got where shocking. VERY noticeable decrease in hydro noise and much smoother operation. My oil is smooth, clear, and clean like vegetable oil.
  5. #15
    Join Date
    Aug 2008
    Posts
    1,002
    Kubota fluid (SUD/UDT etc) is over pimped... I use Amsoil and way better and cheaper.
    "In God we trust; all others must bring data"
    -Edwards Deming
  6. #16
    Join Date
    Sep 2009
    Posts
    194
    NE ky
    Quote Originally Posted by nspec View Post
    the tractor is an M59, the oil is new and the tractor has been checked by Kubota to the nth degree. You can see it here if you search 'm59 hydraulics got slow and weak'.
    the oil was extracted from the fill hole with a syrenge after warm up. It clears up pretty quickly. Another member here checked his m59 the same way with identicle reults. Different fluid tho.
  7. #17
    Platinum Member PHILIP8N's Avatar
    Join Date
    Sep 2009
    Posts
    986
    Indianapolis
    Kubota L3940 Ford 8N Ford 6000
    Looks like water emulsion to me. From water getting in oil case, and not enought time at full operating temp to burn off moisture. Lots of intermittent use, during cool down, breathes humidity back in. Can you see this on the dip stick too? Philip.
    Kubota L3940HST-1 2009
    84" front blade
    LA724 loader w/quick attach
    HD 72" round back bucket
    turf tires
    Ford 8N 1950
    Ford 6000 diesel 1961
    JD LX188 1997
    JD L110 2003
    Woods RD7200 finish mower, Bearcat CH5540 5" chipper, L8170 ballast box, 6' Woods pulverizer, 6' Dragon box scrapper with hydraulic rippers, 14" 2 bottom plow, sub-soiler, post hole auger, 3 point pallet forks, 3 point 2" drawbar receiver, 30" rear scoop, 7' Land Pride RB1584 rear blade, 3 point boom pole
  8. #18
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,475
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Quote Originally Posted by sw03 View Post
    I compared Amsoil 0-30 synthetic tractor hydraulic oil and it was right at $184.00 for 5 gallons.
    Kubota SUD2 was $107. Am I missing something here.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  9. #19
    Join Date
    Sep 2009
    Posts
    194
    NE ky
    Quote Originally Posted by PHILIP8N View Post
    I use it hours at a time digging sewers, heats up plenty good. Not really noticeable on the dipstick, I found this when I was catching fluid for the first 50 hr filter change.
  10. #20
    Join Date
    Dec 2007
    Posts
    549
    Default
    One more thought.... Is it possible the fluid level is too high? Overfilling can cause frothing or foaming of the fluid. There is definitely air being introduced somehow to cause all of the bubbles in that picture.
Similar Threads
  1. Oil & Fuel UDT vs SUDT,
    By tdev in forum Owning/Operating
    Last Post: 12-13-2011, 08:02 AM
  2. SUDT vs. UDT - What a difference!
    By sixgun in forum Oil, Fuel & Lubricants
    Last Post: 07-10-2011, 11:18 PM
  3. udt vs sudt, do they mix?
    By poldies4 in forum Kubota Owning/Operating
    Last Post: 10-30-2010, 04:09 AM
  4. UDT vs. SUDT
    By Kabuki in forum Kubota Owning/Operating
    Last Post: 02-02-2010, 09:24 AM
  5. udt-sudt ?
    By lawn_king in forum Kubota Owning/Operating
    Last Post: 09-14-2008, 12:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
