Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,800
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Default Re: M8560HD12
    Our Case went toes up and we needed a tractor NOW, so I couldn't get cast center like I had wanted without waiting six weeks. We had cast centers and fluid filled tires on our Massey Ferguson 375 and it pulled amazing loads. My brother is using it now and he recently put new rear tires on and didn't get them filled yet, you can really tell the difference, still decent, but not as good as before.
    We used an 80 HP tractor for years and it did everything we needed, so we replaced it with the M8540, but if I had thought I might need the extra HP, I would have gone with the M9540; not a lot of difference in price. With the M9960, you can get the 24/24 transmission which is not offered in the M8560, not an issue for us, so we got the 12/12 hydro shuttle. We didn't need dual rear remotes when we bought it, but now have a box scraper with hydraulic shanks, so it is nice to have along with the hydraulic toplink, a necessity for us now that we have begun using one.
    I put three rear remotes with Top and Tilt on our L5740, but it doesn't sound as though you will need that.
    I also wanted an air ride seat, but have found the regular suspension seat comfortable enough, so didn't add one later; might consider it if you spend a lot of time in the seat though. I grew up riding steel seats, so what we have now is great in comparison.
    I would also look to a rear wiper, we use ours on the 5740 all the time.
  2. #12
    Elite Member Briana03's Avatar
    Join Date
    Jul 2010
    Posts
    3,292
    San Diego, California
    None
    Welcome to TBN
    I moved your thread to the kubota Owning/Operating forum.
    Briana
    TBN Support
  3. #13
    Veteran Member MHarryE's Avatar
    Join Date
    Feb 2009
    Posts
    2,067
    Northeastern Minnesota
    Kubota M7-171, Kubota M110GX, IH 4386, IH1486, Case 301.8, Kubota L6060, plus many others
    Default
    You will be giving up over 10 PTO HP compared to your Oliver. In addition the torque backup might be better on the larger engine (either 4.6 or 5.1 on the Oliver vs. 3.8 on the kubota). Suggest looking hard at the 9960 as it seems to be a much better match - if the price doesn't kill the deal. The 9960 has about 3 more PTO HP. Still the tractor ill be about 3,000 pounds lighter than the Oliver so like they said, find all the ballast you can add for traction.
    JD7720; KubotaM135GX; NH TS115A; JD6230; KubotaL6060
  4. #14
    Join Date
    Jan 2013
    Posts
    71
    Hamilton, OH
    TS6.110 4WD Cab, WM75 FEL ROPS
    Quote Originally Posted by MHarryE View Post
    I am definitely going with the M9960HD12 ROPS and may even fill the tires - I know I am giving up some nice power/torque trading in the Oliver 1755, but the hydraulics on that puppy just never can get repaired completely w/o $$$ thrown at it
    Excellent advise everyone, I will post pics upon arrival
  5. #15
    Veteran Member xring100's Avatar
    Join Date
    Dec 2012
    Posts
    1,470
    Livingston County, Michigan
    Kubota M8540, ZD1211 60"
    Default
    I would Definitely go for rim quard its a cheap 1800 lbs of ballast if you have the 18.4 r 30 mine was $300/ $350. I think for what your doing you will appreciate the investment in the 9960 over the 8560. I have more horse power than i hope to ever need with my 8540 but i needed the loader capacity and a skid steer for me was out of the question.
    Dave
    Dave
  6. #16
    Join Date
    Apr 2012
    Posts
    743
    pa
    kubota 7040sud
    i suggest you talk to FOREMAN etexas HE DOES HAYING WITH A 7040 i would get the 3 rear remotes if you need them you have them
  7. #17
    Join Date
    Jan 2013
    Posts
    71
    Hamilton, OH
    Quote Originally Posted by xring100 View Post
    Dave
    Thanks Dave, may do rim guard after plowing and 1st cutting to see how tractor runs - i think the weight with cast wheels will work, but won;t know until start breaking ground
    Marc
  8. #18
    Join Date
    Jan 2013
    Posts
    71
    Hamilton, OH
    Quote Originally Posted by case245 View Post
    I will check w/ 7040 - thankx
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
