Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
  1. #11
    Platinum Member Carl Bert's Avatar
    Join Date
    Jul 2010
    Posts
    865
    Rockland county, New York
    Kubota B26, John deere X595
    Default
    I can tell you first hand that the B26 is a great little machine. Perfect all around machine for use on your property. I can't speak for mowing, as I never had or used one on my machine. I can tell you that the backhoe is easily removed in a matter of minutes. If you do decide on the B26, I would recommend getting the hydraulic thumb. It is worth every penny. This machine is very well built and should last a lifetime for personal use.
    If you have any specific questions, don't hesitate to ask. I love talking about my B26. Good luck in your search.
    2010 Kubota B26 TLB w/hyd thumb. 2004 John Deere X595 w/62" MMM.
    Carl Bertuzzi
  2. #12
    New Member
    Join Date
    Jan 2013
    Posts
    6
    Soquel
    2011 Kubota B3200hsd
    Default Re: Kubota B26 yes or no?
    Ok,
    How about a used L35? any thoughts on that model?
  3. #13
    Veteran Member bandit67's Avatar
    Join Date
    May 2004
    Posts
    1,552
    Foothills, Colorado
    B3000 HSDCC
    The L35 is a good machine. I've used one on my property, but it would have taken me a little more time to get smoother with the GST on my mountain property. A used L35 nowadays will most likely have a lot of hours and seen a lot of hard use.
    One thing to consider with the B26 is your elevation. I assume you're not anywhere near as high above sea level as I am? I'm at 8500'. The B26 would not have a good enough power to weight ratio as high up as I am, so that took it off my short list. Another thing about the B26 is if you're only using it mainly for your own property, and not in a commercial setting, you'll never wear it out. One of the large B series or the L series should handle your property well enough. I was very pleasantly surprised with how well my non-commercial B3030 TLB handled all of the tasks I threw at it, and I have a lot of decomposed granite and rocks to deal with.
    Here are some pics showing some of the work my BH75 did on a rock ledge hillside that I needed to dig out. I started with a full size TLB, but found that the bucket alone couldn't chip away any faster than my little machine could, as I couldn't utilize the significantly larger bucket when breaking up the rock ledge.
    These little machines are pretty amazing. Don't think you'll be unhappy with whatever you decide on.
    Attached Thumbnails Attached Thumbnails Kubota B26 yes or no?-152_5228-jpg   Kubota B26 yes or no?-152_5225-jpg
    2012 Kubota B3000, block heater, filled rears, rear wheel spacers, fender extensions, LA403 w/60" bucket, BH77 w/12" bucket & mechanical thumb, Kubota pin-type QA, Kubota forks, Caroni TM1600 flail, Buhler Allied YC6010 3pt blower, Meyer 72" FEL mounted plow, Midwest LR2072 rake
    Previous machines:
    2008 Kubota B3030 (Open Station), LA403, BH75, 4 - 55w halogen front & rear ROPS mounted worklights with L39 dash switches
    2004 Case NH DX24E Subcompact
    Kubotas from Barlow's
  4. #14
    Join Date
    Sep 2011
    Posts
    140
    South eastern Pa.
    kubota B26
    I had a B20 first and then traded up to the B26. I really like this machine. I live in the woods and it is the perfect size for getting around in the trees. I have a grapple bucket and a snow plow for it. One of these days I will get the thumb.
    Not sure about the mowing. It is only 26 hp which is plenty for digging and bucket work but mowing takes hp. You should look closer at that issue.
  5. #15
    Gold Member
    Join Date
    May 2007
    Posts
    257
    Central NH
    Kubota B7610HSD
    Default
    I have the older model B7610. I have 4N1 bucket along with a grapple & Woods backhoe. This little machine constantly amazes me on what it can move and do. I have not had any issues using the 4N1 bucket or the FEL Grapple.
    One of the things I love about it, is that it is small. I have been able to get into small areas to do backhoe work, or get in close to a house for trenching. Because the weight, I have had a couple of jobs because I can cross a septic field without doing any damage.
    With all that said, I wouldn't mind having more FEL lift capacity, but I wouldn't want to trade up in tractor size to get that.
  6. #16
    Join Date
    Sep 2010
    Posts
    688
    Eastern Ontario
    Kubota MX5100
    The B26 is a great machine (used to own a B20) and is great in woods because of it's size and durability. I agree that no QA FEL sucks and I was looking at the L45 but decided for the price and new tasks I do with my tractor, e.g. plowing and discing, I upgraded to a MX5100. A BH is a great implement and expensive but I would not go without it.
    2011 Kubota MX5100, BH92, BH BB72, Walco Bush Hog and Snowblower, Wallenstein 310 Splitter & Forks
  7. #17
    Veteran Member workinallthetime's Avatar
    Join Date
    Nov 2006
    Posts
    1,079
    Tulsa, ok
    b3030 TLB,zd326
    welcome!
    i was in your same boat a few years ago, I went with a b3030 TLB and never looked back. Something at that time made me stear away from b26 and go with the b3030. i can tell you it is a great all around machine. I am at about 560 hours right now and would say at least 1/2 those hours are using the BH. i made a mechanical thumb for mine and that really increased the value of the BH. the thing is if you were to get a b3030 or something in that catagory you would have close to the same power but the ability to add a belly mower for your mowing gig's. i purchased a Zd326 to do my mowing since i was also doing mowing jobs and wanted to get done quick and be more flexable about the work i took.
    Over the past few weeks i have been doing some serious thinking about a L39 or L45, however the 50K plus price tag has me looking for used jd 110 or 310
    good luck
    equipment = L45 tlb, zd326p
    attachements = disk, pallet forks, box blade, 4n1, thumb, ld material bucket
    past equipment = b???? old slow no p/s, bx23 tlb, b3030 tlb, mf 175, jd301a
  8. #18
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Hire mowing is tempting, but it is hard to make any money at it. Well, let me put it another way: it is easy to lose money at it. There are a lot of yahoos out there hiring out bush-hogging for way too little, not having insurance, not covering their transportation, or depreciation on their tractor. By the time they go out of business three months later, somebody else has taken their place. In the mean time, anybody who wants to actually run a sustainable business is being priced out of the market. It's not to say that it can't be done, but you need to get customers who are willing to pay a fair wage for someone who is going to act like a professional. Or you need to understand that you're working for beer money and little more. But bush-hogging is very hard on a tractor. I bush-hogged just a little bit, and I did more damage to my tractor in that time than anything I've ever done around my own property. The problem is that you are often driving blind, and you're going to run over something or get hung up in a rut or who knows what. You'll snag a hydraulic line or bust up your bush-hog and then where are you at? Fixing it out of pocket, and all the tiny amount of profit you made on the last three jobs goes to fixing up the tractor. Oh, and let's not forget that as soon as you do work for hire, whatever insurance policy you have covering your tractor (if you have one) goes out the window. And, worst-case scenario, you damage somebody's property and they sue you, and the fact that you don't have business liability insurance (because who can afford that on a bush-hogger's pay) means you're personally on the hook.
    I say all this as the voice of experience. When I first got my tractor, I had the idea that I would help cover the payments hiring out bush-hogging. I did a few jobs before deciding that it just wasn't worth it. That may not be everybody's decision, but it was mine.
  9. #19
    New Member
    Join Date
    Jan 2011
    Posts
    4
    B26
    Quote Originally Posted by Spitfirefd View Post
    Ok,
    I have had a B26 for 3 years and it is amazing what I have been able to do with it
  10. #20
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,703
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I have a B26 and it is a strong little tractor and very maneuverable which is its strong points=small but strong. I don't particularly like the smallish 3 point hitch links and they look rather weak for using a box blade or other heavy equipment. I don't use mine for anything but backhoe and loader work as I have another tractor for mowing. I got a good deal on my used, otherwise the price would have been more than I wanted to pay. I could have bought a Mahindra Max 28 new for what I gave for my B26 but I don't think it would have been as tough as the B26. I was out in the woods today pushing over small trees and digging larger one up by the roots, pushing thru the saw briars, grape vines and other tangles that had the trees wrapped up. With the 4 post FOPS I could just plow thru the vines pushing a load in front and the rest sliding over the two front post and canopy. I couldn't do that on a CUT with ROPS without a suit of armor on or I would have been cut to ribbons. For small, maneuverable backhoe work in heavy cover it cant be beat, but it will cost your wallet dearly for that extra. For whatever TLB that you get, be sure to get the hydraulic thumb, it adds lots of versatility to the hoe in being able to grasp materials and move them around. If you don't mind a little larger tractor you might look at the John Deere 110. I think they have about 40 HP which would be better for mowing. I don't think you can haul even the B26 with a bushhog on a 14 foot trailer, its going to be pretty well full up with just the TLB.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
Similar Threads
  1. WHY IS A KUBOTA B26 DEARER?
    By GILLYS CHILLI FARM AUSTRA in forum Kubota Owning/Operating
    Last Post: 02-23-2012, 05:44 PM
  2. Towing my Kubota B26
    By Carl Bert in forum Trailers & Transportation
    Last Post: 02-11-2012, 07:01 PM
  3. Kubota B26 TLB
    By raintree in forum Buying/Pricing/Comparisons
    Last Post: 11-01-2011, 09:45 PM
  4. Price for Kubota B26
    By finestusa in forum Kubota Buying/Pricing
    Last Post: 01-19-2011, 08:45 PM
  5. What Kubota engine in the B26?
    By nvr-enuf in forum Kubota Owning/Operating
    Last Post: 12-31-2010, 07:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
