Results 21 to 30 of 71
01-25-2013, 08:47 PM #21
Re: Frozen, Gelled fuel
I use Power Service. It's actually rated better than Howes(IIRC). But read the bottle carefully, I think you need to add more at certain temperatures. I always go for the 'max' amount just to be sure. Today may have been 12 degrees, next week might be -15..........just never know.
EDIT: There was a big thread on which additives to use in the 'oil, fuel & lubricants forum last winter.
Double edit: The new ULSD fuels can start 'clouding' at temps of 40F and can gell at temps below 30 degrees.Don
MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
01-26-2013, 08:41 AM #22
B 7510
FEL 302, Rear remotes, Hydraulic Toplink, Blockheater, 60" MMM, Pats easy change, 6' York rake, 5' grader blade, Powerhorse Log splitter, 6.5 ft Western plow, 3 pt 2" trailer reciever, Bucket forks, "Thumb" grapple, Loaded Turfs, Carver wear blade, 40 AMP alternator, AND A CUP HOLDER!
IAFF L-2892
01-26-2013, 09:33 AM #23
I am betting your fuel problems are biofuel related. It is being added to diesel now and biofuel turns solid at a relatively high temp. Your best bet is to use a good additive every fill once the temps go down.
L5740 LA854 loader
L3130 LA723 loader sold
B3200 LA504 loader
B1550 sold
B2620 sold
B4200 sold
F2680E
GF1800
JD 850D Gator
JD F935 x 2 sold
Ford 555D TLB
Gehl 602 excavator
01-26-2013, 10:34 AM #24Bronze Member
- Join Date
- Dec 2012
- Posts
- 58
- Location
- Western NC
- Tractor
- green
We use B99 biodiesel during the warm months exclusively, then switch to B20 or 50 in the winter for machines that will be run regularly. The combine has all of the biodiesel drained out and replaced with No 2 and run for a while so as not to have any bio in the fuel system at all. The time to get the right fuel in your tractor is before cold weather.
Using good clean No 2 with proper winter additive and decent filtration should not gel in the 20's. How long does it take for you to go through a tank of fuel? Is it parked undercover, and do you fill the tank at the end of a hot day in the sun?
Which racor did you mount on your tractor?JD 5085M *JD 6110 w 640 loader *JD 6330 *AC F2 Gleaner * Ford 7.3 PSD x 2
01-26-2013, 10:51 AM #25Bronze Member
- Join Date
- Jul 2012
- Posts
- 94
- Location
- St.Albans,Maine
- Tractor
- TYM T451,bolens G214.John Deere 440CID,Shaver sc25 stunpbuster,woods750 backhoe,wallenstien splitter,woods bb60 mower,woods 60"tiller,countryline tiller,99 international 4700 car carrier
power service diesel 911 in the red plasic bottle is the best thing Ive ever used for jelled fuel
01-26-2013, 12:14 PM #26
01-26-2013, 12:25 PM #27Elite Member
- Join Date
- May 2004
- Posts
- 3,795
- Location
- Innisfil, Ontario, Canada
- Tractor
- MF 1635 12x12 Powershuttle
Kleen flo, Howes, wont touch powerservice with a 10 foot pole.
Thanks,
Will
I do not care if someone's net nanny is watching!! You need to stop...
01-26-2013, 12:34 PM #28
Does anyone here us Seafoam as an additive and if so, has it helped in preventing gelling?
01-26-2013, 02:48 PM #29
Since I get my off road diesel the same time I get my heating oil, late spring to early summer when the price is usually the best, it usually doesn't have any anti gel in it. I'll I've ever used is power service, it's easy to get. Never had an issue, even with the cold nights we see I've never had it gel up. My guess is that if your seeing gelling issues with any additive then it's most likely either you are not adding it in the correct ratio or something unrelated is happening.
Kubota L4240,Case 580K backhoe, Case 450 Dozer
01-26-2013, 05:35 PM #30
I know how to treat my girls who know how to treat me! You ought to see what wifey gets.
I bet if you ask real nice Santa will bring you a carpet too!!
(Biggest case of "carpet envy" I've ever seen)
Similar Threads
Gelled Fuel?
By GreatWhitehunter in forum John Deere Owning/OperatingReplies: 41Last Post: 02-15-2012, 04:26 PM -
Oil & Fuel Does this sound like gelled fuel?
By Z-Michigan in forum John Deere Owning/OperatingReplies: 26Last Post: 01-14-2011, 10:00 AM -
How do I tell if I have gelled fuel?
By Randybee1 in forum Oil, Fuel & LubricantsReplies: 10Last Post: 02-04-2008, 01:48 PM -
Oil & Fuel First winter w/ a Diesel engine: Fuel Gelled
By b249 in forum Kubota Owning/OperatingReplies: 10Last Post: 03-06-2003, 01:39 PM -
Gelled Fuel
By MikePA in forum Oil, Fuel & LubricantsReplies: 66Last Post: 01-26-2002, 01:42 PM
