Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. #1
    Join Date
    Sep 2010
    Posts
    244
    Central Maine
    Kubota BX25
    Default Linear actuator in place of hydraulic ram?
    I'm curious to know if anyone has used a linear actuator in the place of a hydraulic ram for a top link or bucket grapple. It seems to me that it would be easier than adding the hydraulics. Since you can get a 1000 lb. rated actuator, I wouldn't think lack of force an issue. I was thinking about trying one as a top link on my BX. Do you think this is worth pursuing? Thanks.
    Proofread carefully to see if you any words out.
    BX25, BX2750D Snowblower, Bro-Tek thumb, BXpanded Forks and Under Armor, Ballast Box, 3-PT Pallet Forks ...... My Kubota Pics
  2. #2
    Join Date
    Mar 2002
    Posts
    1,119
    N.E. PA
    BX22
    Default Re: Linear actuator in place of hydraulic ram?
    Linear actuators are relatively slow and can't take shock loads very well. Aside from that, a 2' cylinder would have 10,000 lbs force at 3000 psi, so the force difference is considerable.
    paul
  3. #3
    Platinum Member Firefighter Kubota's Avatar
    Join Date
    Aug 2008
    Posts
    685
    Seacoast NH
    Kubota 7510
    For an inexpensive , easy light use option, not a bad idea. Beats the **** out of adjusting the turnbuckle for your top link... Probably a bit weak for a grapple...
    That being said I installed hydros on both...
    Linear actuator in place of hydraulic ram?-picture-026-jpgLinear actuator in place of hydraulic ram?-picture-037-jpg
    B 7510
    FEL 302, Rear remotes, Hydraulic Toplink, Blockheater, 60" MMM, Pats easy change, 54" Puma 3pt Snowblower w Hydraulic chute controls, 6' York rake, 5' grader blade, Powerhorse Log splitter, 6.5 ft Western plow, 3 pt 2" trailer reciever, Bucket forks, "Thumb" grapple, Loaded Turfs, Carver wear blade, 40 AMP alternator, Stereo, AND A CUP HOLDER!
    IAFF L-2892
  4. #4
    Join Date
    Sep 2010
    Posts
    244
    Central Maine
    Kubota BX25
    Quote Originally Posted by techman View Post
    paul
    What you say is true but since the total lift on my BX 3PH is something like 670 lb. I would think a 1000 lb. actuator would have no trouble with that since all it's doing is leveling while the lift arms are supporting the majority of the weight. I was actually thinking maybe a 500 lb or less actuator would work. And I would want the movement to be slow. Does that not make since?
  5. #5
    Elite Member rbargeron's Avatar
    Join Date
    May 2000
    Posts
    2,811
    MA
    L5450, L48, L3250, L345
    Quote Originally Posted by dsmiley View Post
    ....... all it's doing is leveling while the lift arms are supporting the majority of the weight................
    I think an electric top link is an ok idea - provided it's well made & rugged.
    In some situations, like handling crop bins, you wouldn't want a cheap top link that might break - dumping 15 bushels of fresh-picked apples (ask me how I know).
    L345, L3250, L48, L5450, never enough attachments
  6. #6
    Join Date
    Sep 2010
    Posts
    244
    Central Maine
    Kubota BX25
    Quote Originally Posted by rbargeron View Post
    I'm thinking those apples got picked twice. I want to store my firewood on pallets on a hill behind my house and bring the pallets over as I need them. It would be handy to be able to level my 3-pt forks when picking up the pallets and also when coming down the hill. I just think it might work great without the hassle of a turn buckle or installing the necessary hydraulics.
  7. #7
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,536
    Lincoln County, NC need new avatar!
    Just a Scag
    There's no good reason to buy a 500lb actuator when a 1000lb unit is available. You need to consider the actuator's ability to resist simply failing and pulling apart from the extension loading exerted by the pallet. Your assumption that the lift links are carrying the load is incorrect. Prove this by attempting to lift the rear of a full pallet enough to slack your existing top link.
    Spring is the season of optimism.
  8. #8
    Veteran Member ericher69's Avatar
    Join Date
    Aug 2008
    Posts
    1,670
    Ontario Canada
    2008 Kubota b2920
    Default
    I have a linear actuator for my blower chute deflector 110lbs...
    You also need to look at the "static" holding force of the actuator. It can be many times less than push/pull rating
    ericher69
    IAFF Local 849
  9. #9
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,951
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Not to sound like a smart a**, but if it was that easy and cheap everybody would have them vs. hydraulic ones, and there would be 10 companies advertising here to sell them one.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  10. #10
    Join Date
    Sep 2000
    Posts
    9,536
    Just a Scag
    Quote Originally Posted by kennyd View Post
    You do make a good point, Kenny.
Similar Threads
  1. Linear Actuator
    By msb1766 in forum Customization
    Last Post: 01-29-2012, 10:02 AM
  2. Which linear actuator for BX2750D
    By dsmiley in forum Kubota Owning/Operating
    Last Post: 12-14-2011, 07:49 AM
  3. linear actuator for plow blade
    By rfowler in forum Build-It Yourself
    Last Post: 08-23-2010, 07:28 PM
  4. Help with Capacitor for Warner Linear Actuator.
    By DocHeb in forum Build-It Yourself
    Last Post: 05-14-2006, 04:42 PM
  5. source for Linear Actuator?
    By Larry_Van_Horn in forum Build-It Yourself
    Last Post: 08-26-2003, 08:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
