Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    May 2011
    Posts
    18
    Kingsport, TN
    Husqavarna CZ1740, Case 1825 Skid and Kubota B2920 TLB
    Default Retrofit a Toothbar on B 2920
    2+ Years ago I picked up a toothbar at an auction for $100. It was made for a 60"+ wide bucket. I decided to make it fit the kubota.
    First step was cutting it down and then develop a method to attach it.
    Marking It
    Retrofit a Toothbar on B 2920-20130127_151501-1-jpg
    Cutting with Portaband
    Retrofit a Toothbar on B 2920-20130127_153119-1-jpg
    Then I needed to develop a way to secure the bar to the bucket. Some 4" plate I had laying around so I figured contour to the bucket and then use some binders on the back side to cinch the bar down. (Binders aren't installed yet, had to stop for the night).
    4" Plate before and after.
    Retrofit a Toothbar on B 2920-20130127_151535-1-jpg
    Bending it in my Swag/HF brake.
    Retrofit a Toothbar on B 2920-20130127_152242-1-jpg
    Welded up.
    Retrofit a Toothbar on B 2920-20130127_161312-1-jpg
    Test fit. Comes on and off easy.
    Retrofit a Toothbar on B 2920-20130127_161350-1-jpg
    Strap contoured to bucket.
    Retrofit a Toothbar on B 2920-20130127_161416-1-jpg
    Backside where I will attach a binder to strap and then weld an attachment point on the bucket.
    Retrofit a Toothbar on B 2920-20130127_161354-1-jpg
    About 2 hours of work start to finish including setup/cleanup. I'm looking forward to digging some holes this spring.
    I'll update this as I add the binders this week.
  2. #2
    Elite Member johnk's Avatar
    Join Date
    Jun 2003
    Posts
    2,715
    western NY
    Kubota GST Grand L3130 w/ 723 loader, Ags
    Default Re: Retrofit a Toothbar on B 2920
    Very nice job and completed in record time. You will like the increased digging ability when using it..
    Kubota grand L 3130; 723 loader; Hinged back Box Scraper; 7' HD Back Blade; Tooth Bar; PHD w/ 9 & 12 Inch Auger; PEC; Carryall
  3. #3
    Veteran Member Deano's Avatar
    Join Date
    Oct 2008
    Posts
    1,239
    Southern Maryland
    Kubota BX24
    Looks good!
    Deano
    2006 BX24, 6' Modern Implements rake, Woods RB60 rear blade, Wallenstein thumb, Bro-Tek rear skid plate, home made front skid plate, W.R. Long flat tooth bar, 4' finishing mower (TPH), 4' box blade, post hole digger, New style seat!!!!!, Agri-Fab drop spreader.
  4. #4
    New Member
    Join Date
    May 2011
    Posts
    18
    Kingsport, TN
    Got this done along with the QA I built a few weeks ago.
    Works great and I got to use it to dig some fresh ground because I needed to level out some space near the house.
    I cut some basic hooks on the plasma table and welded them to the back of the bucket. Then I welded some chain to the tooth bar brackets that go under the bucket. Now I just use a small load binder to cinch the bar tight to the bucket. I did cut the excess chain off so there are only 3 links on each side.
    Retrofit a Toothbar on B 2920-20130211_190703-jpg
    Retrofit a Toothbar on B 2920-20130211_190737-jpg
Similar Threads
  1. 20 to 40 Amp Retrofit???
    By ghbick in forum John Deere Lawn & Garden
    Last Post: 08-17-2012, 10:55 AM
  2. Replies: 11
    Last Post: 03-18-2010, 08:37 PM
  3. Retrofit for BX-24
    By FishAlaska in forum Kubota Owning/Operating
    Last Post: 01-21-2009, 11:35 AM
  4. Tire Retrofit
    By Randy Gerringer in forum Kubota Owning/Operating
    Last Post: 03-07-2008, 09:25 PM
  5. Digging Toothbar vs Landscape Toothbar
    By davemhughes in forum Attachments
    Last Post: 02-16-2007, 02:10 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
