Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. #21
    Veteran Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    1,642
    SW VA
    David Brown 885, Kubota RTV 900, Kubota 9540
    Default
    Quote Originally Posted by daugen View Post
    did you tear up your sidewall? Or just a tired tire?
    I'd like to learn more about what wrecks modern tractor tires, so maybe I can avoid it...
    Always thought the more plies the merrier.
    I ran over a broken T post stub. I hauled it to Free Service Tire, they said they could patch it, I waited two weeks, they then called and said they couldn't. By the time a new replacement tire came in I was without a loader tractor for over a month. It was a costly mistake I hope to never make again.
    I actually started a thread that had pictures of the damage.
    Treat me good and I'll treat you better, treat me bad and I'll treat you worse.
  2. #22
    Join Date
    Jan 2010
    Posts
    1,285
    Piedmont, NC
    Kubota L4610 & BX2230, Farmall Super M, Super A
    Default Re: are my front tires wimpy?
    Quote Originally Posted by Verticaltrx View Post
    FWIW, the Kubota MX4700 and MX5100 use considerably larger tires and it is the same compact grand L 'chassis'. So you could upgrade (all around I'm guessing) to the MX4700 tires for a more beefy front tire.
    I could be wrong, but I think the MX models are still using a 16" diameter wheel on the front, the same as the Grand L's, although the MX does take a wider tire. The rears are indeed on larger rims. Years ago there was a TBN member who wanted to upgrade the tires on his Grand L to a premium Michelin industrial series because it had aggressive R1-type lugs on a heavy R4 carcass - pretty neat concept, no? The issues were the cost and finding suitable sizes. After he bought the tires he found the new front tires would snag the loader brackets in a full lock turn, making it necessary to torch off some of the loader mounts before he could use the tractor. The more recent higher horsepower Grand L's have a slightly longer wheelbase, but it's still pretty tight quarters, particularly the clearance behind the front wheels.
  3. #23
    Join Date
    Feb 2012
    Posts
    1,641
    Holland, PA
    2012 Kubota L5740HSTC3, 1986 Case IH 255, 1986 Gravely 8199G
    sounds like all I would gain is an inch in height or width without running into things.
    The moral of this story is they aren't very big, but they were designed that way.
    I like the idea of more real ballast for all sorts of good reasons.
    2012 Kubota L5740HSTC3 with FEL and Long grapple, 1986 Case IH 255, Land Pride PD10 PHD, Land Pride RCR60 mower, Land Pride box blade and rear rake, Fred Cain subsoiler, County Line potato plow, County Line 1 bottom plow, 1986 Gravely 8199G with tow behind DR rototiller, 50" deck+40" Gravely wing mower, Gravely snowblower, Swisher 44 rough cut mower,Ariens snowblower, Echo 450-18 & 600-24, Echo PPT280, 2006 JD LX280, , 1968 Cub Cadet 125, Husky-Speeco 35 ton splitter 2012 Suburban 2500
  4. #24
    Platinum Member TomSeller's Avatar
    Join Date
    Jan 2013
    Posts
    536
    Somewhere, LL
    Many
    Default
    Do the small front tires make your rear tires look fat?
    Seriously, I have a Kubota with front tires nearly the size of yours and I wouldn't want them any larger. I guess it depends on what you use it for, but on tight turn arounds in the brush and woods with obstacles it would seem the larger tires would be an encumbrance. I have a JD with tires similar to the LS referenced, but that one is more of an open field tractor where there is no down side to the taller tires.
  5. #25
    RFB
    RFB is offline
    Join Date
    Jan 2006
    Posts
    871
    West Central Idaho
    Grand L5740HSTC, Kubota LA854 FEL with QA Bucket
    Default
    The Michelins work well on the front of the 5740.
    Attached Thumbnails Attached Thumbnails are my front tires wimpy?-image-2536904921.jpg
  6. #26
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    1,797
    Canada
    B3200, L5740,
    Quote Originally Posted by RFB View Post
    What tires/size do have on the front and rear of your 5740?
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    GF1800
    JD 850D Gator
    JD F935 x 2 sold
    Ford 555D TLB
    Gehl 602 excavator
  7. #27
    RFB
    RFB is offline
    Join Date
    Jan 2006
    Posts
    871
    West Central Idaho
    Default
    I will check tomorrow to confirm the sizes. (Don't remember them right now.)
  8. #28
    Join Date
    Dec 2009
    Posts
    1,797
    Canada
    B3200, L5740,
    Thanks, that would be great.
    L5740 LA854 loader
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    GF1800
    JD 850D Gator
    JD F935 x 2 sold
    Ford 555D TLB
    Gehl 602 excavator
  9. #29
    Bronze Member Dirtdeere's Avatar
    Join Date
    Oct 2012
    Posts
    54
    Nevada
    John Deere 955, mod 70 FEL, model 7 backhoe
    Default
    You could try swapping the front tires to the rear and the rears to the front. That would look cool and it shouldn't mess with the 4wd at all cuz that's what the factory installed as original equipment
  10. #30
    Join Date
    Jan 2013
    Posts
    536
    Somewhere, LL
    Many
    Default
    I wouldn't change a thing on that tractor. Nice.
Similar Threads
  1. No more wimpy Kubota!
    By Jay4200 in forum Kubota Owning/Operating
    Last Post: 12-10-2012, 09:18 PM
  2. Wimpy new sprays
    By chopped in forum Owning/Operating
    Last Post: 07-20-2010, 01:12 PM
  3. Fix for wimpy B3030 seat?
    By Lane in forum Kubota Owning/Operating
    Last Post: 03-20-2007, 09:00 AM
  4. Fixing the wimpy flail mower
    By 40Kchicks in forum Parts/Repairs
    Last Post: 06-17-2005, 10:37 PM
  5. Kubota (Wimpy Hydraulics)
    By guppy in forum Customization
    Last Post: 05-18-2004, 01:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
