Page 4 of 9 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 89
  1. #31
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,385
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Default Re: Catastrophic Failure
    That looks like there is water in you oil and some was on top of your piston. Cold weather freeze up.
  2. #32
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,643
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Quote Originally Posted by Leejohn View Post
    I don't see the water in oil. There may be water on the oil outside the case from precipitation. I doubt very much that a freeze crack as the tractor was warm and the oil would have been completely milky in colour.
    The repair doesn't look to intensive compared to the jd 2305 case failures. Look up the for posts on it, it really sucks, trust me, don't ask how I know! As long as there is no internal parts damage, it looks like a relatively easy fix for a skilled FIYer. I would guess something physically pressed against the case(like an over extended cylinder) rather then a high hydraulic pressure. I would guess that a high hydraulic pressure would leak at seals before a catasrophic case failure. Just my uneducated guess though. Keep us posted please.
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  3. #33
    Elite Member
    Join Date
    Dec 2000
    Posts
    2,968
    Southern VT, Southern ME
    John Deere 4100 HST /410 FEL, R4s
    Wow looks like just behind where the rockshaft control valve bolts up. I would think your system pressure relief valve must be nearby. Mines located right below it
  4. #34
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,385
    Doniphan, Mo.
    The reason I posted about freeze up is because my brothers BH just blew the top out of one of the L & R cyls. When it went it ended up about 60' away. The metal is about 1/2" thick.
    Also the bucket is on the ground and it moved it about 2' until the dirt pile got to big.
  5. #35
    Join Date
    Nov 2011
    Posts
    1,643
    Curious, was his oil milky in colour?
  6. #36
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,385
    Doniphan, Mo.
    There was a little water that hadn't drained out of the piston. The BH was been setting for awhile, we well have to open the drain plug and see if water comes out now. I would say it is. It wouldn't take a lot of water if trapped on top of the piston like his was. What got me was how far the boom moved. If I think of it I'll try and get a picture.
  7. #37
    Elite Member Chilly807's Avatar
    Join Date
    Sep 2009
    Posts
    3,258
    Nova Scotia
    Kubota L3400DT
    Quote Originally Posted by joshuabardwell View Post
    Would this relief valve also protect the system if one closed the descent-rate control valve on the three-point and then attempted to raise the hitch?
    It doesn't work that way, all the descent rate valve controls is the rate of fall. It's a check valve of sorts and is spring loaded. It has no effect on the raise part of the cycle, even if it's closed completely the valve will lift off the seat and allow oil to enter the cylinder unrestricted. Once it's in there, however, it's trapped and has no way out past the valve. I would think the safety valve would be plumbed directly into the cylinder to allow excess pressure to escape if the need arose. In other words, it shouldn't have to also pass through the descent rate valve to get out. That's the way it's shown on mine anyway.
    The attached pics are from the WSM for my tractor, an L3400. It shows the cylinder safety valve being set for roughly 3000 psi (2845-3277 psi), which is well above the normal relief setting of 2250psi, and the hydraulic diagram shows where everything is plumbed in relation to each other. The lowering valve (6) is shown in green, the cylinder (7) is in yellow, as is the safety valve (8).
    Catastrophic Failure-dsc01615-jpgCatastrophic Failure-dsc01616-jpg
    Sean
  8. #38
    Join Date
    Sep 2009
    Posts
    3,258
    Nova Scotia
    Kubota L3400DT
    Wow.. quite the failure. I've never seen anything quite like that before. Sure looks like an overpressure situation, if that's the weakest point of the casting.
    Sean
  9. #39
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    Quote Originally Posted by Chilly807 View Post
    Sean
    My thoughts exactly. You can see a clear line all the way where it broke. It appears to be following the thickness of the cast iron from the inside. I am willing to bet that once you get that cover off and inspect it from the inside with a strong light, you will see a dark color metal spot indicating an old fracture that was there way before you got the tractor and the gray paint covered it on the outside. If you dont see a spot of an old long time fractured spot, then either you have quite possibly found a manufacturing design defect or definately a failed relief valve. Time to inspect it too. By the way, its good to know that your oil was not milky- but even with contaminated oil you would noticed sluggishness with hst or loader as its using the same oil.
  10. #40
    Elite Member
    Join Date
    Dec 2000
    Posts
    2,968
    On my machine the thermal/shock safety relief ball check is located right inside the control valve itself.
    Looks like a high pressure blowout to me. I once experienced a CAT skidder pump housing crack under pressure upon start up. It was freezing cold out.
    Looking foward to seeing more diassembly
Similar Threads
  1. JD4300 -- Catastrophic Failure of the Shift Shaft
    By reasley in forum John Deere Owning/Operating
    Last Post: 04-28-2014, 05:40 PM
  2. Catastrophic failure: Berta rotary plow
    By clytle374 in forum 2-Wheeled Tractors
    Last Post: 02-26-2013, 09:42 AM
  3. Catastrophic hydraulic top link failure
    By pclausen in forum Attachments
    Last Post: 01-07-2013, 12:35 AM
  4. Catastrophic failure 3 weeks after warranty expired
    By airbusdriver in forum Bobcat Tractors
    Last Post: 09-22-2012, 03:55 PM
  5. Hydraulics failure...
    By corelokt308win in forum Iseki
    Last Post: 08-09-2005, 04:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
