Results 1 to 4 of 4
  1. #1
    Gold Member moriboy's Avatar
    Join Date
    Jul 2010
    Posts
    340
    SW Oregon
    Kubota M7040, L3901, KX057-4, JD 650G
    Default DIY options=weekend of fun!
    I bought a pretty much bare bones M7040 last year during hay season, knowing full well that I would be adding some options down the road. At the time of purchase, we were in a hurry to get an additional haying tractor, so the one in stock at the dealer came home. Things have worked out for us this year, so I went on a bit of a shopping spree and now have the tractor outfitted how I want it. I had to order all of the parts which took about 3 weeks to get. I wanted to share with you all a quick summary of the install along with a few pictures. The total time to install this was about 6 hours. Here goes!
    DIY options=weekend of fun!-image-2128580156-jpg
    Here is a picture showing the new Anbo grapple. It's a 72 wide one. Although its a bit dirty, I really haven't had a chance to use it for more than 5 minutes. It's just to wet and muddy! First impressions are that it is going to be awesome for clearing brush and picking up/moving logs. The build quality is amazing as well. I do believe you get what you pay for, yes it was expensive..
    DIY options=weekend of fun!-image-1096005019-jpg
    DIY options=weekend of fun!-image-435295103-jpg
    To keep them rear wheels on the ground when I'm using that fancy grapple, I needed to add some weight to the rear. While I do have the tires filled I still believe you can't have too much ballast. Unfortunately when I bought this tractor, I was not able to get cast centers. So, I added 2 wheel weights to each wheel. That adds about 650 pounds total. I haven't had much in the grapple yet, but moving round bales on the steepest ground is very comfortable now.
    DIY options=weekend of fun!-image-3986731588-jpg
    In order to run the grapple (and my future post hole drill), I added the factory 3 function kit for the FEL. Installation was a breeze. Put the new handle on, bolt up a new valve body, add a couple new hoses, plug in a wiring harness, and you're done.
    DIY options=weekend of fun!-image-4273064241-jpg
    This picture is showing how the kubota shock less ride system looks once installed. I move a lot of round bales, and our ground can be pretty bumpy. This system allows the loader to "float", absorbing most of the bounce. I can tell you it's amazing! You lose a little speed when raising or lowering the loader. Fortunately turning it on or off is simply done by turning the knob. I highly recommend this option if you want to take the bounce out of your ride. Installation was a little tricky since the instructions were terrible. You add quite a few new hoses and tee fittings. You also end up with a lot of extra parts, which add to the confusion.
    DIY options=weekend of fun!-image-3717239533-jpg
    In order to run our NH 216 rake, I need 2 remotes. I had one, but added the second one. Very simple process. Bolt the new remote on top of your current one, hook up a cable, and add the handle. I'm going to get a hydraulic tilt cylinder someday, so a 3rd remote is in my future as well.
    DIY options=weekend of fun!-image-3828880692-jpg
    Additional remote handle shown. I staggered them to allow for easier operation. Not sure yet if I like it that way. It's simple to adjust if needed.
  2. #2
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default Re: DIY options=weekend of fun!
    Nice tractor and grapple. You can never have enough hydraulic outlets.
  3. #3
    Super Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    Really digging the boom suspension! Too bad it wasn't electrically actuated. Not sure about the low hanging hoses though?
    Grapple control is a nice clean install too.
  4. #4
    Join Date
    Jul 2010
    Posts
    340
    SW Oregon
    Default
    I still have to put the covers back on that house all of the hoses. I left the cover off for now so I could check for leaks and also to make sure I don't need to adjust hose angles. Electric activation is a neat idea.... It wouldn't be that hard to do.
Similar Threads
  1. Had some fun in the dirt this weekend..
    By mark2610d in forum Kubota Owning/Operating
    Last Post: 02-11-2009, 10:28 AM
  2. My weekend fun.
    By Casco1 in forum Owning/Operating
    Last Post: 12-24-2007, 05:13 PM
  3. Weekend fun - tomato stand
    By HRS in forum Rural Living
    Last Post: 08-02-2006, 06:39 PM
  4. Weekend work, uh I mean fun
    By BigWill in forum New Holland Owning/Operating
    Last Post: 04-29-2004, 09:59 AM
  5. Fun Weekend
    By rdricks in forum Kubota Owning/Operating
    Last Post: 09-03-2002, 06:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
