Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    2,278
    Canada
    B3200, L5740,
    Default Re: B3300su Hydraulic Pressure Relief
    Quote Originally Posted by J_J View Post
    B3200 3pt relief.
    Yes the 3pt has its own relief which is set about 200psi lower than the rest of the system.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    ZD1211
    GF1800 sold
    Kubota RTV900
    JD 850D Gator sold
    JD F935 x 2 sold
    Case 590SM-2
    JD 310D TLB sold
    Ford 555D sold
    Gehl 602 excavator sold
    JD317 sold
    JD323D
  2. #22
    New Member
    Join Date
    Mar 2009
    Posts
    20
    Central Ma.
    B3300su
    Finally got to check the pressure relief this afternoon. I took some pictures while doing it.
    First i warmed the tractor for about 15-20 minutes. Shut it off.
    Then i removed the right rear wheel.
    Disconnected the top coupler for the FEL. Installed the pressure gauge.
    Specs call for 2205psi pressure relief. I am reading about 2100psi @ about 2400rpm.
    Shut tractor off. I then removed the cap for the pressure relief in the FEL valve. Note: There are no shims.
    I added a .2mm shim for about an 80psi increase...as per instructions.
    Reinstalled the pressure relief.
    Started tractor up and increased rpm back to 2400.
    I read about 2200psi. (Picture come out blurry)
    Removed gauge and reconnected the top hose. Installed rear tire.
    I havent had a chance to try it...I will let you know if i see any change.
    B3300su Hydraulic Pressure Relief-kubota-pr1-jpg<a href='http://www.tractorbynet.com/c/kubota' onclick=kubota PR1.jpg  Views: 305  Size: 109.4 KB  ID: 305140" class="thumbnail" style="float:CONFIG" />B3300su Hydraulic Pressure Relief-kubota-pr2-jpgB3300su Hydraulic Pressure Relief-kubota-pr3-jpgB3300su Hydraulic Pressure Relief-kubota-pr4-jpgB3300su Hydraulic Pressure Relief-kubota-pr5-jpg
    Attached Thumbnails Attached Thumbnails B3300su Hydraulic Pressure Relief-kubota-pr1-jpg
  3. #23
    Join Date
    Jun 2004
    Posts
    1,759
    Northeast MA
    Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
    Quote Originally Posted by dtherrien View Post
    So which one of the hex cap plugs is the pressure relief valve in your picture? Is it the rightmost one (only one with no pipe coming from it?)
    I see in the pic of the pressure relief valve you've got a shim pack - is that a Kubota part?
  4. #24
    New Member
    Join Date
    Mar 2009
    Posts
    20
    Central Ma.
    B3300su
    Here is another picture with an arrow to the cap that is the pressure relief.
    I ordered the gauge kit from bxpanded...it came with the gauge(ready to hook up) color coded shims and instructions.
    Everything work out exactly as indicated in the instructions.
    I only needed the one .2mm shim to bring mine close to 2205psi.
    B3300su Hydraulic Pressure Relief-kubota-pr-jpg<a href='http://www.tractorbynet.com/c/kubota' onclick=kubota PR.jpg  Views: 286  Size: 109.0 KB  ID: 305257" class="thumbnail" style="float:CONFIG" />
  5. #25
    Join Date
    Jun 2004
    Posts
    1,759
    Northeast MA
    Awesome - thanks for the help. I already have a gauge - but I will go check bxpanded for that kit anyway.
Similar Threads
  1. Hydraulic pressure relief tool
    By BeauGeste in forum Hydraulics
    Last Post: 11-01-2017, 05:44 PM
  2. Pressure Relief Trouble (Blood Pressure and Hydraulic)
    By LouieJunior in forum Hydraulics
    Last Post: 08-26-2012, 04:35 PM
  3. Backhoe 757C Hydraulic pressure relief?
    By treefarmer391 in forum Attachments
    Last Post: 05-25-2010, 10:38 AM
  4. Hydraulic pressure relief? B series
    By Grubs in forum Kubota Owning/Operating
    Last Post: 11-01-2009, 12:25 PM
  5. Hydraulic Pump pressure relief problems
    By Gary Baxter in forum Chinese Tractors
    Last Post: 07-24-2009, 06:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
