Results 1 to 7 of 7
  1. #1
    Member
    Join Date
    Feb 2013
    Posts
    28
    South Windsor,CT 06074
    Kubota B21
    Default What would be the most practical set-up?
    I own, since new, a 1997 kubota B21 with a TL421 FEL and a BT751 hoe. (585 hrs) I intend to drop the BH and mount a 54" Bervac Blizzard B54B 2 stage snowblower. I cleared about 10,000 sq.ft. of residential driveway with the FEL after the 2013 blizzard. We got a solid 29" and a 36" windrow at the street. I think the TL421 and the B54B with remotely controlled chute rotation and deflection would be the best setup for this model tractor. I would use tire chains and ballast if needed. The PTO specs 13.5 HP. I would not consider a width greater than 54". And, getting some type of cab inclosure, is almost a must. Any practical advice or experience with this setup would be appreciated. Thanx Tinman236
  2. #2
    Super Member
    Join Date
    Aug 2004
    Posts
    6,481
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Default Re: What would be the most practical set-up?
    Sounds about right to me.
    Just be sure 54" is about 4" wider than your tires!
    Being hydro you can support wider as you con control the speed all while maintaining PTO RPM's.
    I run a 60" on a similar (20hp, less at PTO) but gear tranny and using techniques can cope with snows up to 14" as well as serious berms.
    With hydro you'll have no problems.
  3. #3
    Elite Member Tig's Avatar
    Join Date
    Oct 2006
    Posts
    2,557
    The County, Ontario, Canada
    Kubota, B7100HST-D
    I run a 50" blower on 13 PTO HP. The variable speed of the HST is key to making it work well in the deep stuff.
    Steve
    The best things in life are not things.
  4. #4
    Elite Member WayneB's Avatar
    Join Date
    Oct 2006
    Posts
    2,829
    New Hampshire
    Kubota B-7500
    Sounds like a good approach to snow blowing. For a number of years I had a rear blower and I attached plexiglass to the ROPS and that really reduced the amount of blowing snow coming into the driver seat area. I also added a Sunshield type cap and then ordered a Femco weatherbreak which really cut down the amount of blowing snow plus the weatherbreak also directed heat from the motor and made it nicer.
    This past year I went ahead and bought a front mount snowblower and quick hitch so I can change over from blower to plow (snow blade) which works better for me. The front snowblower is a little bit faster and less pain in the neck from always looking backwards when I had the three point hitch blower, but the new blower isn’t made as heavy at the old one. sign of the times I guess, pay more and get less.
    Attached Thumbnails Attached Thumbnails What would be the most practical set-up?-img_5454-jpg   What would be the most practical set-up?-femco1-jpg   What would be the most practical set-up?-img_5455-jpg   What would be the most practical set-up?-goingtobirdfeeders-jpg   What would be the most practical set-up?-dscn1027-1-jpg
    What would be the most practical set-up?-femco2-jpg
  5. #5
    Member
    Join Date
    Feb 2013
    Posts
    28
    Kubota B21
    Thanx for your imput.Wayne--nice bota you have there-- Looks like u have snowremoval under control. Regards--Tinman236
  6. #6
    Member
    Join Date
    Feb 2013
    Posts
    28
    Kubota B21
    Tig--thanx for your thoughts. I agree-HST is key- along with patience. regards-Tinman236
  7. #7
    Member
    Join Date
    Feb 2013
    Posts
    28
    Kubota B21
    Piloon- Thanx for your advice-a 60" wide unit would be better than a 54"er as it would allow the tires more room around the cut. That would help keep the SB more parallel to the ground. Too wide a unit could create problems. Regards-Tinman236
Similar Threads
  1. Practical tips
    By Richard in forum Rural Living
    Last Post: 09-17-2010, 01:26 PM
  2. Practical Joke
    By NewToy in forum Rural Living
    Last Post: 06-24-2009, 12:18 AM
  3. What's the smallest practical HP/Tractor you'd consider?
    By 63DH8 in forum Buying/Pricing/Comparisons
    Last Post: 01-29-2009, 09:16 AM
  4. Practical to add Hyd. to JD 850?
    By CoHay in forum John Deere Owning/Operating
    Last Post: 01-24-2009, 06:03 PM
  5. Dealer How do dealers set prices set on Kubota Tractors
    By WALOL in forum Kubota Buying/Pricing
    Last Post: 02-10-2005, 03:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
