Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
  1. #31
    Silver Member stoyan79's Avatar
    Join Date
    Sep 2011
    Posts
    224
    Kubota L3700SU
    Default Re: Would you do 50hr service @ 10hrs?
    It is 2425, which feels high to me. I have found that the sweet spot is around 2,000-2,200.
    Quote Originally Posted by TripleR View Post
    What is your 540 PTO rated engine RPM?
  2. #32
    Join Date
    Sep 2011
    Posts
    224
    Kubota L3700SU
    Thats good idea. If I can't get to 20 hours, maybe I will just drive it on the road (no traffic on my road) for few miles @ high gear and will vary the RPMs until I get to 20 hours, then when its still warm I will dump the oil and change it.
    Quote Originally Posted by PHILIP8N View Post
    Attachment 305253Sounds like a good plan. I did not break my tractor in like I would have hoped to. I drove it from dealer to farm, about 5 miles, at full engine rpm, stopping every once in a while to vary rpm's. I let it idle while hooking up bush hog, then did this for 2 straight days in 80-90F ambient a 2650 engine rpm, only stopping to clear radiator screen and refuel. When finished, I had 18 hours and dumped oil. Philip.
  3. #33
    Join Date
    Jun 2012
    Posts
    162
    Mid, Michigan
    Kubota L3540 w/ LA514 FEL, 66" QA Bucket, 48" QA Forks, 7' RB, 18" Ripper, Ferris IS2000z ZTR
    Not sure if someone has said this, but probably there was. I would change all the filters on the machine at least once during the machines warranty period. You may find things that have been collecting in there that may indicate a problem. It would be better to know that while you still have a warranty on it. If they look clean, I think an argument could be made to put them back on. Most likely though, one of your filters will have a lot of metal shavings in it from the manufacturing price. My hydraulic filter did, and many others on here have found that too. However, I would want to make sure that there were enough hours and use of the hyrdraulics though to make sure it has worked them all out to the filter. Would be best to find a job for that tractor to tackle.
  4. #34
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,643
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Quote Originally Posted by PhilY View Post
    You bring up a good point.
    To the OP, how do you store your tractor? Heated shop, outdoors in the sun, sheltered or whatever. I don't think there is anything you can do to your 10 hour tractor that will damage long term. That being said, if you allow your oils to absorb condensation, that can bring some problems to you, for example diluted oil will provide less lubrication, also possibility on corrosion. It likely is treated a severe duty cycle in your manual. I don't think synthetic oils are any better in your situation.
    If I was in your situation I try and find a neighbour that needs help instead of driving up and down your road! Better for your tractor to see real work than carboning up even if its pulling high gear. Plus I'm sure your neighbour will appreciate the "free" help. My old fordson tractor needed workouts in the field not just mowing duties.
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  5. #35
    Join Date
    Nov 2008
    Posts
    849
    Brampton, On\lot Powassan, ON Canada
    Kubota B4200\MF 135\Kubota B3200
    Funny I feel I am abusing the tractor by changing the oil once a year, but thats still better then once every 100 hours that dealer recommends. They do not talk about time frames like vehicles that recommend 3 months or 3,000 miles, what ever comes first. I don't know what the bigger tractors hold, but 4-5 litres and a $10 filter is a small price to pay once a year.
    Unimogdave
  6. #36
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,816
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Quote Originally Posted by stoyan79 View Post
    For someone use to running the older tractors and I was one of them, the PTO speeds on more modern tractors does seem high. I have gotten use to it over the years and run all of mine at full PTO engine speed. There are several threads on this.
    "In theory, there is no difference between theory and practice. But in practice, there is." - Yogi Berra
  7. #37
    Join Date
    Sep 2011
    Posts
    224
    Kubota L3700SU
    I think I will change the oil once every 2 years as I will be well below the hours for an oil change.
    Quote Originally Posted by David Devuono View Post
  8. #38
    Veteran Member milkman636's Avatar
    Join Date
    Aug 2010
    Posts
    1,176
    Palm of the Right Hand
    Bobcat CT335 + Kubota BX2370-1
    I tend to favor an annual approach for maintenance of seldomly used equipment. Its a good opportunity to check things over thouroughly and provides a peace of mind knowing things are ready to work. For long intervals I also like to put a visible date on the filters so I can remember when I changed it last.Two years could easily turn into to three if your memory runs like mine sometimes.
    "Contentment makes poor men rich, Discontent makes rich men poor." Benjamin Franklin
    "...The conflict between believers and non believers is not about the beliefs..." IslandTractor
  9. #39
    Veteran Member PHILIP8N's Avatar
    Join Date
    Sep 2009
    Posts
    1,338
    Indianapolis
    Kubota L3940 Kubota GR2120 Ford 8N Ford 6000
    For seldom used equipment I go 2 years as well (lawn mowers, generator, pressure washer, snow blowers, some tractors). I keep a spread sheet on the barn wall of all equipment wih date, hours/miles done, and date, hours/miles for next. It is a very long list with 17 engines and 2 compressors, only way I can keep track of it all. Philip.
    Kubota L3940HST-1 2009
    84" front blade
    LA724 loader w/HD 72" round back bucket
    turf tires
    Kubota GR2120 2013
    Kubota W5019 PC
    Ford 8N 1950
    Ford 6000 diesel 1961
    Woods RD7200 finish mower, Land Pride RCR1272 rotary cutter, Land Pride RTR1274 tiller, Bearcat CH5540 5" chipper, L8170 ballast box, 6' Woods pulverizer, 6' Dragon box scrapper with hydraulic rippers, 14" 2 bottom plow, post hole auger, 7' Land Pride RB1584 rear blade, 3 point boom pole, 48" 4000# SSQA pallet forks
  10. #40
    Join Date
    Oct 2005
    Posts
    1,537
    Cincinnati, OH
    Kubota B3030
    Quote Originally Posted by wmonroe View Post
    I would change the engine oil only also. At this point however I would not put synthetic in, need to break it in good first.
    Thats an old wives tale!
    Kubota B3030 with 40 amp alternator kit; LA403 FEL; 60 inch backblade; sub-soiler; ballast box; EzMover hitch; Payne clamp-on bucket forks; a HD set of smaller discs and a 60" landscape rake with dolly wheels
    Hobart HH210 Mig welder
Similar Threads
  1. 50hr service do it yourself???
    By Typhoon in forum Kioti Owning/Operating
    Last Post: 03-08-2009, 06:47 PM
  2. little help w/ 50hr service
    By fiddleback in forum Kioti Owning/Operating
    Last Post: 10-18-2006, 11:47 PM
  3. 50hr service
    By travelingman in forum Kubota Owning/Operating
    Last Post: 05-09-2005, 10:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
