Results 1 to 6 of 6
  1. #1
    Veteran Member lawn_king's Avatar
    Join Date
    Jun 2006
    Posts
    1,619
    Hanover massachusetts
    kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
    Default Inlellapanel 2008 GL 3540
    Can anyone tell me how much clearence there is from the very top of my dashboard to the circuit boards? I would like to mount a billiard ball sized compass there, but im afraid of damaging the circuit board with the mounting screwes.
    We have done so much, for so long,with so little, we are now qualified to do anything with nothing!
  2. #2
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,824
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Default Re: Inlellapanel 2008 GL 3540
    Beats me, have you check the threads by bullit94 and 4shorts, I think they have done quite a few mods on the GL; wish I could help.
    Clothes make the man; naked people have little or no influence on society - - Mark Twain
  3. #3
    Veteran Member PHILIP8N's Avatar
    Join Date
    Sep 2009
    Posts
    1,338
    Indianapolis
    Kubota L3940 Kubota GR2120 Ford 8N Ford 6000
    I have an app for that! Sorry, couldn't resist. Philip.
    Actually, I once mounted my Garmin to the hood of my tractor to confirm travel speed of the Intellipanel. Speed was right on the money, it also has a built in compass.
    Kubota L3940HST-1 2009
    84" front blade
    LA724 loader w/HD 72" round back bucket
    turf tires
    Kubota GR2120 2013
    Kubota W5019 PC
    Ford 8N 1950
    Ford 6000 diesel 1961
    Woods RD7200 finish mower, Land Pride RCR1272 rotary cutter, Land Pride RTR1274 tiller, Bearcat CH5540 5" chipper, L8170 ballast box, 6' Woods pulverizer, 6' Dragon box scrapper with hydraulic rippers, 14" 2 bottom plow, post hole auger, 7' Land Pride RB1584 rear blade, 3 point boom pole, 48" 4000# SSQA pallet forks
  4. #4
    Elite Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    3,245
    Bay Roberts, Newfoundland
    Kubota 5740,BX25D
    I figure you got about an inch.
    Attached Thumbnails Attached Thumbnails Inlellapanel  2008 GL 3540-image-jpg
    ...Excellence is not a skill. It is an attitude...
    YouTube Video's: http://www.youtube.com/user/7863348?feature=guide
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25D with many mods
    Kubota ZTR ZG 222 Z
    Custom Toyota Fork Lift
  5. #5
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,927
    Northern Vermont
    Kubota, Case, Deere
    Is the plastic cowling hard to remove? I would opt to go that route and make sure the screws will not hit anything or chafe on any wires. You could even put a little RTV on the ends of the screws, let it dry, and then put the cowling back in place.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  6. #6
    Join Date
    Jul 2008
    Posts
    3,245
    Kubota 5740,BX25D
    Quote Originally Posted by crazyal View Post
    There's 4 bolts and one Phillips screw to remove to get the plastic cover off around the instrument cluster. Each of the 4 bolts take a 12 mm socket. I use a 1/4 drive and they are located in each corner of the cover facing forward to the seat. The phillips screw is up by the display facing you on top of the cluster display. Look close,its there but counter sunk. Takes about 5 minutes to remove. The hardest part is pulling up the cover around the throttle lever. I usually put the lever at full throttle and that makes it easier. To install, reverse the procedure
    Kubota ZTR ZG 222 Z
Similar Threads
  1. New 3540
    By tmartel1959 in forum Kubota Buying/Pricing
    Last Post: 08-24-2011, 09:41 PM
  2. G L 3540 working
    By lawn_king in forum Kubota Owning/Operating
    Last Post: 05-17-2008, 08:34 PM
  3. new 3540 HSTC
    By mdwyer in forum Kubota Owning/Operating
    Last Post: 04-03-2008, 10:06 PM
  4. Pricing a 3540
    By micromike in forum Kubota Buying/Pricing
    Last Post: 09-21-2007, 11:13 PM
  5. Overheating 3540
    By the_wolfman in forum Chinese Tractors
    Last Post: 07-17-2007, 02:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
