Page 2 of 12 FirstFirst 12345 ... LastLast
Results 11 to 20 of 116
  1. #11
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,203
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    Default Re: Soundproofing the B3030 Cab and found something interesting
    I'd consider double sided sticky tape or contact cement to make it all stay where you want it to. Good solution. Realize that true sound isolation occurs when there is a void between surfaces so that sound gets trapped in the void and cannot transfer from surface a to surface b. You're effectively dampening the sound transfer in the padding vs. eliminating it by stopping the sound waves from getting across the 'void'.
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  2. #12
    Veteran Member srs's Avatar
    Join Date
    Feb 2004
    Posts
    1,072
    Jarrettsville Maryland
    Kubota B3030 HSDC
    Quote Originally Posted by Coyote machine View Post
    WaxMan, with what Coyote machine is saying is there a way to create a "void" between the surfaces so the sound is eliminated vs dampening it? Doesn't sound like there is enough room to create a void, which is a shame, but I can't tell by the photos if there is some way to create the "void".
    Stanley----Kubota B3030 HSDC
  3. #13
    Join Date
    Jan 2006
    Posts
    963
    West Central Idaho
    Kubota L5740HSTC3; B3000HSDCC
    Quote Originally Posted by WaxMan View Post
    I"ll post some pictures as I go if anyone is interested.
    Yes please, I am very interested because I also want to try to seal up the cab from dust migration. Did you also have to remove the seat?
  4. #14
    Veteran Member WaxMan's Avatar
    Join Date
    Nov 2008
    Posts
    1,053
    USA CT
    Kubota Grand L 3240 cab BH 92 backhoe
    Quote Originally Posted by srs View Post
    The only place the middle of the floor touches anything is that plate on top the HST It's about 6 x 8 inches. That is what supports the floor in the middle. It cannot be made into a void. The only thing, which was my first though is put one 2 or 3 inch rubber motor mount there but that would put all the stress on that one spot.
    Over time the floor might crack/ sag ? where the one mount is because it is not reinforced for that one spot.Then I thought of putting 4 rubber 3/4 dia. mounts hitting only in four spots. Then I found the rubber pad Using the rubber pad shown previously, it has many voids in the 6x6 area but it still covers almost the exact spot that kubota designed the floor to be supported by, only instead of crushed foam bringing it down to metal to metal it will have that rubber piece with many void areas in the rubber.
    If you zoom in on the rubber it has many voids and only the outline of the squares rest on the floor and HST. I think that is the best I can do for voids, unless someone has a better idea? I'm open for any suggesting.
    The floor has to be supported some how, it can't just hover over the HST. It always has to end up in dampening somewhere in a horizontal application with weight on top. Only way it can be a complete void is vertical between walls or something where weigh is not a factor.
    The more I think about it that mat seems like it will work pretty good. I ordered a 3/4 inch thick and a 3/8 inch thick 6x6 mat. I'll have it tomorrow. I think the 3/4 will work OK, but if not I'll used the 3/8 which I know will work because that is the thickness of the foam before being crushed to metal contact which probably happens the day it was assembled at Kubota.
    Quick Links to my other Modifications
    Stack.......... Inclinometer.........FEL Indicator........... ICC Lights............Tilt Wheel ...............
    Fel Knob....... Bucket Cam........ Double Step..........Auto Level .........Snow Video..........
    WaxMan
    to preserve and protect
  5. #15
    Join Date
    Nov 2008
    Posts
    1,053
    USA CT
    Quote Originally Posted by RFB View Post
    Yes only because when you remove the floor panel the seat is just dangling there, it's only four bolts and gets it out of the way. You don't have to remove the sheet metal the seat is resting on. Although now that I see how nice the new soundproofing is I might redo that area too.
    It's very easy to remove the seat and floor panels. This is not a hard project to do, How much will it deaden the sound is the question.
    From what I have seen so far it should make a big improvement. This picture will give you a better idea of what has to be removed.
    Attached Thumbnails Attached Thumbnails Soundproofing the B3030 Cab and found something interesting-img_2083-jpg
    WaxMan
  6. #16
    Join Date
    May 2009
    Posts
    7,203
    Southern VT
    What you plan to do should significantly dampen the sound transmission from the trans, and possibly from the engine as well, into the cab. It would be virtually impossible to eliminate all noise transferred because the cab has to be attached to the frame/chassis of the tractor. I'm sure you will notice significant improvement from your efforts.
    Keep us apprised with pics of your process.
  7. #17
    Join Date
    Feb 2004
    Posts
    1,072
    Kubota B3030 HSDC
    It's a shame kubota did not put some type of floor brace or strut to support the floor to separate the it from the transmission. Regardless you've got some expensive and very good products to suppress the noise and vibration. Keep up the good work! Stanley
  8. #18
    Join Date
    Jan 2006
    Posts
    963
    West Central Idaho
    Waxman,
    Thanks again for the photos; they help me to think through the process before attempting it. What area(s) do you think is/are responsible for the dust/dirt ingress?
    Have you imagineered a solution for the dust issue?
    Also, I did a search for Mason Iso products and found these:
    http://www.amazon.com/s/ref=bl_sr_in...&node=16310091
  9. #19
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,338
    Lancaster County, PA
    Kubota L3200, Ford 1210
    The link RFB posted is a good place to start. We do some vibration isolation with equipment. The one thing some people don't consider is isolating the bolts. If you have a machine that produces vibration, any bolts fastening to it should be isolated as well. If you insert a pad between the vibrating piece of steel and the part you want to isolate, the bolt should be installed using rubber bushings and washers so the bolt doesn't short-circuit the isolation material. Otherwise the bolt will conduct the vibrations from one surface to the next.
  10. #20
    Join Date
    Feb 2004
    Posts
    1,072
    Kubota B3030 HSDC
    Quote Originally Posted by chim View Post
    Chim, that makes a lot of sense but the only problem I see with the B3030 is that there isn't a lot of room between the bolt and the floor. Can you suggest a remedy for this? Thanks for your advice.
Similar Threads
  1. Look what I found! (long...but interesting)
    By N80 in forum Owning/Operating
    Last Post: 10-21-2007, 07:30 PM
  2. Kubota B2630, B7800, B3030, B3030 Cab
    By SteveCarver in forum Buying/Pricing/Comparisons
    Last Post: 04-01-2006, 10:46 AM
  3. I found this interesting
    By Whiskey in forum Related Topics
    Last Post: 11-03-2004, 11:37 PM
  4. Found this interesting
    By jlbota in forum Related Topics
    Last Post: 01-14-2004, 06:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
