Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
  1. #11
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,643
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Default
    I think we need more information on your actual yard.
    I prefer the mmm as its more nibble, tracks better and gives a nicer cut. That being said, my farm king mowers are pretty tough, the only damage came from backing into a tree and i bent the wheel bracket. Easily fixed. In flat open area the rfm works ok, they sway back and forth a little in the back so its hard to get really straight lines. For some reason the wheels on the farm king rfm dont line up front to back so you get 4 tire lines in the grass plus the two from the tractor. I dont like that. Depending on your budget, you may want to look at a ztr.
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  2. #12
    Member
    Join Date
    Mar 2013
    Posts
    45
    western U.P. MI.
    bx25
    Default Re: mmm or rear finish mower for bx25
    Thanks for all the replies. I have a little less than an acre at home. Some trees, kids play set, garden. My hunting property has a quarter mile of road that needs the shoulders cut. As was mentioned, I might be better off with another rider. The bh has only come off once, only because I don't own any other 3 point attachments yet. I know that a mmm is not cheap, that is why I am leaning more toward a rear finish mower. Would rather use the bx25 to cut then buy another rider though. Hard decision. Oh well, we have a month of winter here yet, and then a few weeks of slop before any grass will need cutting.
  3. #13
    Gold Member
    Join Date
    Apr 2011
    Posts
    327
    Kubota BX2660
    For cutting a yard with trees and buildings, the MMM is more precise and easier to maneuver. For open lawns like a golf course, the RFM would be my choice.
  4. #14
    Gold Member TroyR57's Avatar
    Join Date
    Nov 2004
    Posts
    408
    Winnfield Louisiana
    B3200 tlb 149 hrs, Honda Bid Red 2013
    Hi, I once had a BX23 with 54 inch MMM, was great. For mowing yard, remove the BH, for mowing the Ditch, along the road to the camp, keep the back hoe on. Two reasons, one if you get stuck you can use the back hoe to get your self out, two, I used to swing the hoe to the up hill side, to balance the tracktor out, and also put the low side out riger down, some what to prevent turn over. Just my two cents. Troy
    Honda Big Red MUV
    Honda Fortrax Forman 500
    B3200 TLB
    Land Pride 60 inch BB
    Construction 4 Forks
    60 inch RFM Land Pride
    Land Pride RCR 1860
    Land Pride RTA 1250
  5. #15
    Super Member dragoneggs's Avatar
    Join Date
    Jun 2013
    Posts
    8,449
    Seabeck, Washington
    Kubota BX-25D, Z122RKW-42, and JD LTR166 Lawn Tractor
    Newbie with brand new BX25D here. I need to make the same decision. But I am gathering from the responses that I would be best with a MMM. Now I am putting Bro-Tek wheel spacers on because my property is one acre and one big slope, so I know that forces me to a 60in width. I like the idea that it will also help with the COG and I can also cheat with the BH swung to uphill side. Only scary thing about that is I would need to remember to swing it at each turn! So, what do you all recommend as far as brands for a 60in MMM?
  6. #16
    Super Member JOHNTHOMAS's Avatar
    Join Date
    Apr 2008
    Posts
    7,214
    Somerset, Ky
    L3901HST F3080 RTV1140 BX2370-1
    Be careful on slopes and always go up and down and not crossways when possible. Here is another view of a BX25 if your wondering what it looks like from this side.
    mmm or rear finish mower for bx25-img_0994-jpg
    2017 L3901 HST FEL, 2017 BX2370-1, 2012 F3080 4WD 72" RD, 2010/2009 RTV1140CPX , 72" Woods RFM, 60" LP Grapple, J DUNN Tree Grapple, 6' LP Rotary Mower, LP25 Hydraulic PHD, LP Quick hitch, RatchetRake , Rip and Dig, LP BB, LP 50" Tiller, Snow plow, Titan SSQA Forks, Titan Hitch Mounted Ripper, Titan SSQA to 3PH adapter plate, Sickle mower .. and Horse Drawn disk 13 Toyota Tacoma Double Cab, 18 Ford Flex
  7. #17
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,880
    Ontario, NY
    Kubota BX24
    dragoneggs, I did the same when I first got my BX24, I swung the BH up hill to help counter balance, but I noticed, it has a higher center of gravity with the BH on and I felt better with the BH off when mowing. After you practice how to take it off, it will only take you 10 mins or less to take it off before you mow and that is exactly what I do.
  8. #18
    Join Date
    Jun 2013
    Posts
    8,449
    Seabeck, Washington
    Quote Originally Posted by JOHNTHOMAS View Post
    Yikes I assume that was not intentional? What specifically happened?
  9. #19
    Join Date
    Jun 2013
    Posts
    8,449
    Seabeck, Washington
    Quote Originally Posted by radioman View Post
    So for significant slopes maybe I want to replace the BH with a lower COG implement or counter balance weights? I don't think I want to fill the tires but I understand that is an option.
  10. #20
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Quote Originally Posted by dragoneggs View Post
    You will be more stable with the FEL and BH off. Adding fluid to the tires will help with stability and traction but is not necessary. I think the do not recommend fluid in the tires on the BX25.
Similar Threads
  1. Mid-Mount Mower Rear finish mower vs MMM?
    By T185 in forum Attachments
    Last Post: 09-06-2008, 10:30 AM
  2. GL3940HST w/ MMM or Rear Finish Mower?
    By Brent C. in forum Kubota Buying/Pricing
    Last Post: 09-06-2007, 10:57 PM
  3. Mowing GL3940HST w/ MMM or Rear Finish Mower?
    By Brent C. in forum Kubota Owning/Operating
    Last Post: 09-05-2007, 09:42 PM
  4. Mowing MMM vs. Rear finish mower
    By AdamK in forum Kubota Owning/Operating
    Last Post: 07-03-2004, 11:26 PM
  5. MMM v/s rear finish mower
    By YGuy in forum Kubota Buying/Pricing
    Last Post: 05-13-2003, 01:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
