Results 1 to 10 of 21
03-20-2013, 07:26 AM #1
- Join Date
- Jun 2008
- Posts
- 22
rotary mower for bx series
I have a small field on our hunting lease that needs to be mowed before our turkey season opens this spring. I have a kubota bx 1500. Has anyone ran a 4 ft. rotary cutter on this this tractor and if so, how did it do. The grass in this small field is not very thick and the field is maybe one acre.
03-20-2013, 07:33 AM #2
- Join Date
- Apr 2000
- Posts
- 6,588
- Location
- central New York
- Tractor
- all makes and models
Re: rotary mower for bx series
I'd rather see a 42" behind it do to the horsepower.
03-20-2013, 07:57 AM #3
- Join Date
- Apr 2008
- Posts
- 7,175
- Location
- Somerset, Ky
- Tractor
- L3901HST F3080 RTV1140 BX2370-1
I have just raised the MMM deck as high as it would go and mowed it slow, if I was mostly sure there were no big rocks in it. Or you could have someone mow it the first time with a Bush hog then mow it yourself with your MMM.
2017 L3901 HST FEL, 2017 BX2370-1, 2012 F3080 4WD 72" RD, 2010/2009 RTV1140CPX , 72" Woods RFM, 60" LP Grapple, J DUNN Tree Grapple, 6' LP Rotary Mower, LP25 Hydraulic PHD, LP Quick hitch, RatchetRake , Rip and Dig, LP BB, LP 50" Tiller, Snow plow, Titan SSQA Forks, Titan Hitch Mounted Ripper, Titan SSQA to 3PH adapter plate, Sickle mower .. and Horse Drawn disk 13 Toyota Tacoma Double Cab, 18 Ford Flex
03-20-2013, 04:26 PM #4
- Join Date
- Oct 2012
- Posts
- 66
- Location
- Harris & Fayette Counties, TX
- Tractor
- Kubota B6200, MF 230, JD 4240
I agree that the 42" would be better. I have a 48" that I use with a B6200 which has a bit more horsepower than the BX1500 and it seems to work fine until I get in thick or tall grass.
03-20-2013, 04:36 PM #5
- Join Date
- Mar 2009
- Posts
- 18,917
- Location
- Missouri
- Tractor
- Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
Are you looking to buy one or borrow one?
03-21-2013, 01:26 AM #6
- Join Date
- Nov 2008
- Posts
- 849
- Location
- Brampton, On\lot Powassan, ON Canada
- Tractor
- Kubota B4200\MF 135\Kubota B3200
I have a 48 inch bush hog. I used it to clear about 3 acres of weeds three feet tall behind my B4200 which only had 10 PTO horsepower. In low 3rd gear it would bog down, in Low 2nd gear it mowed fine. Thick brush would bog the tractor in any gear. You should be fine and the only issue may be that the 3PTH on my little B4200 (12hp)will not lift the rotary mower as its about 480 lbs. I just dragged it around. I am looking forward to trying it out with my new B3200 (32HP?) Are you looking at a future tractor upgrade or just see a good deal on the 48inch? They are heavy.
Unimogdave
03-21-2013, 07:35 AM #7
- Join Date
- Mar 2009
- Posts
- 3,618
- Location
- Newton NC
- Tractor
- Which One do you want to know about?
The King Kutter 48" XB rotary cutters are made especially for subcompacts. They feature dual adjustable tailwheels for stability, protective rubber shielding, stumpjumper and a floating hitch. As long as the grass isn't terribly thick, you should be fine with the XB or a similar cutter.
Ted Corriher
www.EverythingAttachments.com
1-866-581-5818
A family-owned American Company that also sells quality Made in USA Implements every chance we get! We pride ourselves on giving good product information and putting the needs of our customers above our own!
03-21-2013, 09:14 AM #8
- Join Date
- Apr 2011
- Posts
- 327
- Tractor
- Kubota BX2660
With the BX1500, I think 48" would be a bit much. A 42" would make more sense at that horsepower
Here is my BX2660 (19.5 HP at the PTO) with a LandPride 48" rotary cutter.
03-21-2013, 09:47 PM #9
- Join Date
- Nov 2011
- Posts
- 3
I have a bx1500. We mow commercially for some solar panel sites that are 80 - 90 acres in size. We use a 48" brunch hog with no problems. Much more reliable than the ZTR's that we use in conjunction.
03-23-2013, 12:26 PM #10
- Join Date
- Apr 2011
- Posts
- 12
- Location
- Georgia
- Tractor
- Kubota BX 2660
I have a BX 2660 kubota and am trying to decide which rotary cutter to buy. I manage vacant properties and sometimes the first cut is rough! The grass can be thick and up to 7 feet tall an saplings 2-3". Usually the lot size is 1/2 acre up to two acres. Also, unsure if it would be wiser to purchase a DR Brush Cutter rather than a 3 point attachment for my Kubota.
I have only had my Kubota 1 year and would like to hear some advice. Thanks
Similar Threads
John Deere HD rotary mower - 09 series?
By AKfish in forum John Deere Buying/PricingReplies: 17Last Post: 08-03-2013, 08:34 AM -
HX rotary mower series?
By AKfish in forum John Deere Ag TractorsReplies: 4Last Post: 09-11-2011, 12:01 AM -
How durable is the JD LX series rotary mower?
By Gypsy Rose in forum AttachmentsReplies: 5Last Post: 02-04-2009, 07:28 AM -
Flail Mower rotary cutter+finish mower -vs- flail mower
By ArtVandelay in forum AttachmentsReplies: 8Last Post: 09-17-2007, 06:47 PM -
Experience with Kioti 15-series Rotary Mower?
By WSJ in forum AttachmentsReplies: 0Last Post: 04-26-2006, 12:48 PM
