Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Veteran Member varmint's Avatar
    Join Date
    Mar 2003
    Posts
    2,399
    Northern Maryland
    Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
    Default Re: BX2200 Wont Start, New Battery, fule pump runs and starter clicks
    There are two ways of thinking about this: 4shorts, who is a professional, and for whom time is money, and the other guy, who is just trying to get by, and maybe has less money. This reminded me of troubles I had with a Camry starter in the early 90's- the warranty was over, and the starter was giving me trouble. I had time, not so much money. I wound up soldering a piece of fabricated brass where something had been mis-aligned at the factory had worn thru, and the fix lasted for many years, until I got rid of the car, anyway. The started was Toyota-fine, otherwise. Sure, it would have been much quicker and easier to put in a new one, and had I been charging somebody to fix it, that would have made sense. But...
  2. #12
    Elite Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    3,245
    Bay Roberts, Newfoundland
    Kubota 5740,BX25D
    Quote Originally Posted by ibnxe View Post
    I guess I'm from the old school. I almost always disassemble failed components to see what went wrong... and repair, if it is something simple.
    Quote Originally Posted by varmint View Post
    This is a situation where none of is wrong. You both have very valid points and for myself I might have just did the repair IF I could have just got the one part but if your going to the dealer to buy a solenoid you'd be much better off getting a rebuilt starter with a three year warranty for 1/3rd the cost of the one dealer part with no warranty plus in my case it would have to be ordered in and that can take days on an island.
    Also IF you just need to put brushes in the starter its really useless to do that unless you have a lathe near by to cut the armature. Put new brushes on a old armature and its going to let you down.
    Now from my stand point Varmint got it right. If I take a customers tractor, car ..... And just repair the starter and charge for example two hours to install the solenoid and that starter ends up with other issues shortly after, what do you think the customer will say?
    I bet it will go like this " Heck man. It was only the other day I spent $150 on this starter and its broken again! "
    To avoid that issue I replace the starter for 1/3 of the cost with the 3 year warranty and if it causes an issue with in 90 days I replace it for free and after the 90 days he gets the 3 year warranty and just pays the labour.
    Face it. If the solenoid is bad in the starter what's the bushings, armature, bendix drive, windings like? I bet there's other weak components in there as well. These are the reasons I say replace the starter plus the fact the end user is satisfied. I think that's more than fair. As I say, everyone has great points and this is just mine
    ...Excellence is not a skill. It is an attitude...
    YouTube Video's: http://www.youtube.com/user/7863348?feature=guide
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25D with many mods
    Kubota ZTR ZG 222 Z
    Custom Toyota Fork Lift
  3. #13
    Join Date
    Mar 2003
    Posts
    2,399
    Northern Maryland
    Reading this thread got me remembering a story I heard from a guy who runs a marine outboard engine repair shop on Maryland's Eastern Shore- a location with lots of boats and motors. You'd think he'd be in a good place, but when they began to mix ethanol into gas, his troubles began: LOTS of customers with outboard engine problems (from ethanol) so he was busy, but the trouble began when these customers came back with problems, again, and didn't think they should pay all over... he didn't have time to do the work that made money for him, because he was baby-sitting too many ethanol caused problems. He was bummed out, with no happy future in sight! Fix it, fit it again, and again. Now, some guys were smart enough not to leave any gas in their engines, but some weekend sailors couldn't get it into their heads that the gas was their problem, not the motor guys.
  4. #14
    New Member
    Join Date
    Mar 2013
    Posts
    2
    sellersville, pa
    Kubota BX2200
    Thanks to everyone for their suggestions and help. Here's where the issue stands. Have fully charged battery and starter wont crank or click. With a voltmeter checked and confirmed 12 + volts at the starter positive terminal. from their I removed the wire from the ignition that fires the solenoid/ starter. With key in crank position I only see 7.3 volts. Jumping the solenoid to the positive terminal results in the started turning over and working. Is my ignition switch bad? Loose or corroded wire or connections? What could cause low voltage from the ignition switch? Thanks
  5. #15
    Platinum Member 3v0's Avatar
    Join Date
    Jan 2013
    Posts
    521
    Oklahoma Pan Handle, United States
    Kubota BX2200
    On topic. The tractor will not start when the transmission is in high or low range, has to be in neutral. A quick test is to put it in low and turn the switch to start it. Now put it in neutral and try again. Did the sound it makes change? If it did it is not the safety interlocks. I just made that up. Think it is right
    Off topic:
    When I hit collage the starter went out on my car. I knew it was the bendix but the guy at the garage that fixed it said they only replace the entire starter. The starter failed twice under warranty and the second time it was the bendix again! that time he replaced the Bendix but I had payed for a starter and at least one tow.
    After that I started investing in tools. Years latter I was too lazy or busy to replace a power steering hose so I had my wife take the car to have it fixed. The bums either knocked loose or unplugged the oxygen sensor.
  6. #16
    Join Date
    Nov 2008
    Posts
    849
    Brampton, On\lot Powassan, ON Canada
    Kubota B4200\MF 135\Kubota B3200
    Its interesting that on three occassions since I bought my B3200 a month or so ago my tractor has died because I got out of the seat while it was moving and it would not restart no matter what position the levers were in. After a few minutes, it would start so this has me thinking there is some kind of timer in the start circuit. When the tractor is stopped, I can start it in any range setting, even standing beside the tractor. I have not tried it with the PTO engaged.
    It sounds as though you are on the right track now that you have confirmed the starter is okay. You will need to go one by one through the safety features. Test each switch.
    Unimogdave
  7. #17
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    You are on the right track -- the older BX's have issues with the starter switches. Before you replace - I'd trace the starter wire from starter all the way to switch and make sure its not rubbed through insulation causing corrosion and higher resistance for voltage somewhere. Its a free check before wasting money on a switch.
  8. #18
    Join Date
    Jan 2013
    Posts
    521
    Kubota BX2200
    Quote Originally Posted by David Devuono View Post
    ... When the tractor is stopped, I can start it in any range setting, even standing beside the tractor. I have not tried it with the PTO engaged.
    My BX2200 must be in neutral to start.
  9. #19
    Elite Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    Quote Originally Posted by 3v0 View Post
    Mine, too. In fact, almost all HST tractors have to be in neutral or the clutch depressed (if so equipped) to start.
    2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
    2002 Kubota L48 TLB, 12", 18", 24" HD buckets
    2001 Kubota BX2200, Turf, LA211 FEL
    7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
  10. #20
    Join Date
    Jan 2013
    Posts
    521
    Kubota BX2200
    gwdixon it is cool to see the BX2200 parked next to the big boys. Does it have a FEL too?
Similar Threads
  1. Replies: 7
    Last Post: 05-25-2013, 04:51 PM
  2. Replies: 14
    Last Post: 09-26-2012, 07:43 PM
  3. Kubota BX2200 engine runs only when starter operates
    By jjflash0109 in forum Parts/Repairs
    Last Post: 04-20-2012, 05:26 PM
  4. kubota bx2200 wont start
    By gerry w in forum Kubota Owning/Operating
    Last Post: 07-28-2011, 05:42 PM
  5. 4110 wont start just rapid clicks
    By roermo in forum John Deere Owning/Operating
    Last Post: 12-16-2008, 04:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
