Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Gold Member imgone52's Avatar
    Join Date
    Dec 2011
    Posts
    316
    Tompkins County, New York
    Cub Cadet Yanmar SC2400
    Default Re: Why buy a ball hitch mount?
    The receiver hitch is far more versitile and once it's installed (frame mounted or 3 point) no tools are required to change from ball to drawbar or any other special type of hitch. As with all attachments, you must understand limits and safety requirements.
    CCY SC2400, FEL, MMM, WB, Chore tote, Broadcast Spreader
  2. #12
    Platinum Member AStanton's Avatar
    Join Date
    Feb 2012
    Posts
    994
    North Central, CT
    I had a ball hitch installed on the bucket of my BX25. It's not good for big turns, however, it's nice to have in a pinch.
    Attached Thumbnails Attached Thumbnails Why buy a ball hitch mount?-kubota-bx25-ball-1-jpg   Why buy a ball hitch mount?-kubota-bx25-ball-2-em
  3. #13
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Quote Originally Posted by Soundguy View Post
    you can get stay bars too.
    I am not sure if the stay straps will work on a bx.
  4. #14
    Join Date
    Jan 2012
    Posts
    1,422
    Ma
    Kubota b2920
    Its nice to be able to pull up to the trailer, raise the 3 pt and hook into it. For trailers too heavy to move by hand it makes lining up much easier and you can just get off once to hook safety chains etc. also for heavy trailers you need to lift the tongue to fold up the jack or get it off the ground. The drawbar is too low for that on most small machines.
  5. #15
    Join Date
    Feb 2012
    Posts
    994
    North Central, CT
    Here's my version of a 3-pt hitch tow ball. I went to a local Tractor Supply and purchased the drawbar. Then mounted a 2" ball. The H bracket was fabricated by a welder I know. The whole thing cost about $80. It's good for light duty towing and can be swapped between my BX25 and B3030.
    Attached Thumbnails Attached Thumbnails Why buy a ball hitch mount?-kubota-bx25-trailer-hitch-jpg   Why buy a ball hitch mount?-kubota-log-splitter-jpg   Why buy a ball hitch mount?-kubota-b3030-log-splitter-jpg
  6. #16
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Quote Originally Posted by 94BULLITT View Post
    no toplink eh?
    if it's got a toplink and lower lift arms i don't see why stay straps would not be able to work...??
  7. #17
    Silver Member RandyBell's Avatar
    Join Date
    Mar 2012
    Posts
    230
    Zanesville, Ohio
    2N Ford
    I put my receiver on the drawbar that my cherry picker is mounted on, the picker is bolted on top with the bolts going down through the receiver plate. That way I have my 3rd link to control it and I use chains to set height for the trailer, I have a 2N ford not much hydraulic control.
    Randy
  8. #18
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    no toplink eh?
    I think the stay straps would be to long, the draw bar would be real low. I will have to try it sometime and see now.
  9. #19
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    the ones i use are adjustable 2 part bars. needs 2 thus 4 parts.. they telescope toghther then you set a locking nut.. and that keep the 3pt drawbar from lifting.. though if you use the 3pt.. there is probbaly enough force to pretzle-ize the stay bars..
  10. #20
    Veteran Member PHILIP8N's Avatar
    Join Date
    Sep 2009
    Posts
    1,344
    Indianapolis
    Kubota L3940 Kubota GR2120 Ford 8N Ford 6000
    That is one thing everyone does, but only once! Once bars are in place, make sure you disconnect the pump drive on the N series, or close the 3 point control valve on newer tractors. Here is a half way decent pic of the stay bars. Philip.
    Attached Thumbnails Attached Thumbnails Why buy a ball hitch mount?-swingdbar04-jpg
    Kubota L3940HST-1 2009
    84" front blade
    LA724 loader w/HD 72" round back bucket
    turf tires
    Kubota GR2120 2013
    Kubota W5019 PC
    Ford 8N 1950
    Ford 6000 diesel 1961
    Woods RD7200 finish mower, Land Pride RCR1272 rotary cutter, Land Pride RTR1274 tiller, Bearcat CH5540 5" chipper, L8170 ballast box, 6' Woods pulverizer, 6' Dragon box scrapper with hydraulic rippers, 14" 2 bottom plow, post hole auger, 7' Land Pride RB1584 rear blade, 3 point boom pole, 48" 4000# SSQA pallet forks
Similar Threads
  1. Reese hitch trailer ball mount flipped upside down.
    By Lineman North Florida in forum Trailers & Transportation
    Last Post: 10-08-2012, 01:09 PM
  2. pins for hitch receiver/ball mount?
    By jeffsw6 in forum Trailers & Transportation
    Last Post: 02-14-2012, 12:41 PM
  3. gooseneck or ball mount
    By tessiers in forum Trailers & Transportation
    Last Post: 02-17-2008, 09:34 PM
  4. Freedom Hitch ball hitch attachment
    By RAllen in forum Attachments
    Last Post: 07-25-2001, 09:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
