Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
  1. #11
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,799
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Default Re: Bx2660 woods rcc42
    I took some pictures of a slip clutch and shear pin on some of our equipment and if it will help, I can post them later, but for right now as radioman says, you have to look under the collar which is easy to do and you will see something like this if it's a slip clutch.
    PTO Slip Clutch w Shaft 20 Spline 44 87 I D Driveline Protected New | eBay
  2. #12
    Join Date
    Dec 2012
    Posts
    106
    Ohio
    Kubota bx2660 loader mmm back blade woods rotary cutter
    If this guy would call me back I could go find out already
  3. #13
    Gold Member unbidden's Avatar
    Join Date
    Dec 2010
    Posts
    426
    R.I.
    Kubota BX2660
    Quote Originally Posted by Maestro71 View Post
    I really appreciate it.Attachment 309629 can you tell from the pic if it has a slip clutch.
    Can't tell from the picture, but looking at the size of the cowling around the clutch / shear pin housing it probably does. Question is do you need a slip clutch... probably not necessary. If it doesn't have one just be sure you carry extra shear pins, it only takes a few minutes to replace one.
    By the way, can't know without looking and trying, but the deck looks to be in great shape.
    Foster Center, RI
  4. #14
    Join Date
    Dec 2012
    Posts
    106
    Ohio
    Well I bought it the drive shaft is completely covered by a plastic housing but it sais sc on it so I believe it has a slip clutch I don't see a pin ill attach a pic
  5. #15
    Join Date
    Dec 2012
    Posts
    106
    Ohio
    Bx2660 woods rcc42-image-jpgBx2660 woods rcc42-image-jpg
  6. #16
    Join Date
    Mar 2009
    Posts
    18,799
    Missouri
    You need to take the cowling off and adjust he slip clutch as per manual. They can rust and not slip properly.
    This is for our Woods 121, so you eed one for your model, but it will give you and idea.
    SLIP CLUTCH ADJUSTMENT
    A slip clutch is designed to slip, protecting the gearbox
    and driveline, should the cutter strike an obstruction.
    A new slip clutch, or one that has not been used for
    three months, may seize. To free the clutch, shut tractor
    off, loosen the spring tension on all six bolts, start
    tractor and engage tractor PTO to slip the clutch. Shut
    tractor off, tighten all bolts two turns, start tractor and
    again engage tractor PTO to slip the clutch. When
    clutch slips freely, shut tractor off and tighten springs
    evenly as necessary to prevent slippage. Do not
    exceed the maximum compression of 1-3/4" at dimension
    “A”.
    If a clutch continues to slip with springs compressed to
    the maximum setting, check friction disc (5) for excessive
    wear. Discs are 1/8" thick when new. Replace after
    1/32" wear. (Minimum disc thickness is 3/32".)
  7. #17
    Join Date
    Dec 2012
    Posts
    106
    Ohio
    So this is a slip clutch under the cowling? I haven't had a chance to look. Had to take the wife to the mall so I wouldn't have to hear about the 800 I spent on another " lawn cutter digger thingy"
  8. #18
    Join Date
    Mar 2009
    Posts
    18,799
    Missouri
    Thankfully my wife likes this stuff too, she claimed the BX's when she retired and when I talked about selling the BX2200, she decided we "need" both, one for mowing the yard and one for digging, bush hogging and moving stuff off her walking path.
  9. #19
    Super Star Member
    Join Date
    Dec 2003
    Posts
    11,619
    NC
    Kubota Grand L3830
    The first order of business is go to Every Thing Attachments and look/review the video Ted has posted on how to size a PTO shaft to the tractor and implement. Please do this before attempting to use. Expensive damage could occur.
    Remove or open the flap cover on gear box end. Look inside and you should see a round disc with bolts with springs held on by nut around the outer edge of the disc. This will be the slip clutch. Loosen the nuts on all the bolts. Attach the rotary cutter to the tractor and drive into some tall grass. The clutch should slip. If it doe not slip it is rusted to the mating plate. Gentle now, pry the disc apart. Do not damage the clutch.
    If it does slip, slowly tighten the nuts equally around the disc until the clutch just stops slipping when in use cutting grass. Replace the inspection/repair coverage and enjoy.
  10. #20
    Gold Member
    Join Date
    Apr 2011
    Posts
    327
    Kubota BX2660
    I answered your message, but I will say it here as well.
    The BX series do not require a slip clutch. Its protected from overrun within the output section of the kubota PTO drive, and a shear bolt in the PTO connection to the mower's gear box.
Similar Threads
  1. Replies: 3
    Last Post: 02-23-2013, 08:16 PM
  2. Mowing ENGINE RPM's on BX2660 for Running Woods Rotary Cutter
    By Lumberdink in forum Kubota Owning/Operating
    Last Post: 08-22-2012, 07:50 AM
  3. Comparison 2008 BX2660 vs 2011 BX2660?
    By lavajavadude in forum Kubota Buying/Pricing
    Last Post: 07-26-2011, 06:46 PM
  4. Woods GB60 too big for BX2660?
    By connor77 in forum Kubota Owning/Operating
    Last Post: 05-07-2010, 03:07 PM
  5. BX2660 & Woods BH6000
    By dvmccll in forum Kubota Owning/Operating
    Last Post: 05-04-2009, 03:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
