Page 25 of 160 FirstFirst ... 15222324252627283575125 ... LastLast
Results 241 to 250 of 1599
  1. #241
    Gold Member cschulz's Avatar
    Join Date
    Jun 2011
    Posts
    281
    Ortonville,MI
    Kubota BX2660
    Default Re: BX25D. Mod #1 and continued.
    Hey Paul, Ive seen that you mentioned using Machinery Enamel in another posting for paint. Do you purchase from a automotive paint supplier? And do you use reducer or hardeners? Is the color off the shelf or custom tint? Thanks I really needed to find a better way to add tough paint to my tractor parts.
    Chris
    2011 Kubota BX2660 Loader/ 60"Mower
    My Tractor Tools QA and Grapple System
    BT601 Back Hoe
  2. #242
    Elite Member Chilly807's Avatar
    Join Date
    Sep 2009
    Posts
    3,258
    Nova Scotia
    Kubota L3400DT
    If you have access to the Canadian market, Home Hardware sells a shade of their house brand rust paint called "kubota Orange". I bought some a while ago, but haven't used it yet so I have no idea how close it really is. I'm not so concerned about a perfect match as I am about durability.
    Sean
  3. #243
    Super Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    Quote Originally Posted by cschulz View Post
    Chris
    Dupont Nason is a good paint. Reasonably priced and tough. I use a fair bit of it.
  4. #244
    Join Date
    Sep 2009
    Posts
    3,258
    Nova Scotia
    Kubota L3400DT
    Now I'm getting inspired to do a photo review of the modifications I've made to the L3400 I have. Nothing quite so polished as Paul's tractor mods, but still functional. A lot of the ideas came from people here on TBN, but some were originals.
    Sean
  5. #245
    Veteran Member WaxMan's Avatar
    Join Date
    Nov 2008
    Posts
    1,053
    USA CT
    Kubota Grand L 3240 cab BH 92 backhoe
    Quote Originally Posted by wawajake View Post
    Just a simple modification that I am sure you Paul(4shorts) could improve on:
    I found here in Ontario like I imagine on Atlantic coast, I found myself slipping on tractor floor board when getting up into tractor, with muddy or snow covered boots.
    I had a piece on 1 inch square tubing, that I welded a handful of nuts to upper face and then bolted the piece to outer edge of left side floor board. Just a safety modification that has saved me landing on my butt and elbows this winter...see pic attached, maybe 4shorts or others can improve for your machine.
    I think what you did is pretty good, looks like a step, it will never come off or wear out. Looks like you already improved it.
    Quick Links to my other Modifications
    Stack.......... Inclinometer.........FEL Indicator........... ICC Lights............Tilt Wheel ...............
    Fel Knob....... Bucket Cam........ Double Step..........Auto Level .........Snow Video..........
    WaxMan
    to preserve and protect
  6. #246
    Elite Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    3,245
    Bay Roberts, Newfoundland
    Kubota 5740,BX25D
    Quote Originally Posted by radioman View Post
    looks good ! however about the statement to get your tractor dirty like mine is not kidding.... I like the quick disconnects you used though at BH part. I might as well add that to the bullet connectors that is already in back of BH so its easier to use on different power needs. Question - did you check to see if your wiring harness has enough slack to fold the rops down without binding up?
    I don't worry to much about dirt. I hae never seen anything that couldn't be cleaned up again. We got pressure washers here to take care of the dirt
    Yup. There's plenty of slack there for the ROPS pivot
    Quote Originally Posted by varmint View Post
    I used similar little plastic self-adhesive wire tie pads thingys on my ROPS when I put a light up high, and darned if about half of them just won't stay glued. I guess I will have to clean them and use some instant adhesive or something. Can hardly wait to see the chain saw scabbard project!
    Ya I had the same issues as well but now that I'm using ones with 3-M stickies on them I haven't had an issue. I found another type of wiring retainers this past week. They are aluminum and bendable and have 3-M stickey stuff on them. I'll do the chain saw holder this coming week
    Quote Originally Posted by 1savoy View Post
    Hey Paul,
    I love all the incredible ideas and work. Keep it coming. I see you also use split loom wire covering as I do for many projects. I have seen this Painless Performance PowerBraid Split Sleeving for a while and have been meaning to buy some. I wondered if you have seen it and tried it? If you have, do you like it? Any pros and cons? Like it holds dirt and does not clean up well, or doesn't look as nice as the pictures? I know, I just need to buy some and try it
    Painless Performance: - Dressup Accessories For Customs
    Thanks,
    Russ
    Thank you Russ. Glad your enjoying this stuff. I've never seen that casing before. Now you have me curious. I'll have to look into that. In the meantime when I'm doing my restorations I use the stuff I have pictured. It sure cleans up wiring giving it a clean custom look. Thanks for commenting.
    Quote Originally Posted by dodge man View Post
    It looking good! I noticed your out riggers don't have pavement pads. Is that a future mod?
    One thing I noticed, when you put the pad on the underside of the light, you cut holes for all the bolts and nuts. I probably would have just glued it on as is, and of course it would have looked lumpy and not near as nice. Good job.
    Thanks my friend. I have the pavement shoes. I bought them from my dealer. They had them in stock and they were sitting around so I bought them but I'll be modding them as well.
    As for the rubber padding. I punched the holes in the first layer to get it to fit flush with the light base. The second piece of foam only had two holes in it so I could get access to the two bolts that's required to remove the top for servicing if needed. As you mentioned. If I didn't punch the holes the fit and finish would have been less than desirable.
    Quote Originally Posted by Scooby074 View Post
    Paul, what is the PN for that Doorman weatherpack set? Where did you get it? Cost? Ive been searching for one. Checked the Doorman catalog, but I cant find the set to get the PN (can find the individual pieces though). Thanks
    Now that's a good question. That kit and other parts of it is supplied to our shop by NAPA and they replenish it as it goes down. Check with your local NAPA store. They will have a catalog with all the PN's in it.
    Quote Originally Posted by 3v0 View Post
    Wonder if one could have cut blind holes for the nuts and bolts leaving the outer skin intact.
    not sure what you mean but if its the foam your referring to I couldn't get the right thickness so I glued two pieces together and as explained above I punched the first layer to get it tight to the modules bottom and making a tight fit in the process. The bottom piece was to give it the cleaner look and more head protection.
    Chris
    Chris that paint was purchased from an automotive paint supplier in the city. They mixed it and it was a perfect match. It has to be thinned but I've never added any hardener. It's fast dry and very durable.
    Quote Originally Posted by Chilly807 View Post
    If you have access to the Canadian market, Home Hardware sells a shade of their house brand rust paint called "Kubota Orange". I bought some a while ago, but haven't used it yet so I have no idea how close it really is. I'm not so concerned about a perfect match as I am about durability.
    Sean
    Hum. I didn't know that. I'll be checking that out.
    Sean
    Well you should be posting your work. As you can tell, we all like looking at other people's work and getting ideas in the process. Go for it
    On another note. Wifey and I were in the city today and dropped over to the home show in a place called Mt.Pearl. While we were there I snapped a few photos of the Newfoundland Kubota booth which in my opinion was the best booth there
    ...Excellence is not a skill. It is an attitude...
    YouTube Video's: http://www.youtube.com/user/7863348?feature=guide
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25D with many mods
    Kubota ZTR ZG 222 Z
    Custom Toyota Fork Lift
  7. #247
    Super Star Member
    Join Date
    Apr 2004
    Posts
    13,213
    SF Bay Area-Ca Olympia WA Salzburg Austria
    Cat D3, Deere 110 TLB, Kubota BX23 and L3800 Craftsman Mower, Deere 350C Dozer
    Chris
    I sure miss the days when I could pick up a can of automotive paint from the paint store...
    The old school stuff doesn't exist anymore... Dupont Centari with Hardener sure made me look good!!!
  8. #248
    Super Star Member
    Join Date
    Apr 2004
    Posts
    13,213
    Chris
  9. #249
    Join Date
    Jul 2008
    Posts
    3,245
    Kubota 5740,BX25D
    Had a few guys in the shop today looking at the BX. They've been watching the progress here on TBN which is cool. They really liked seeing it in person but one of them asked me my personal favorite add on and after thinking for a moment I started to chuckle and said that my favorite add on isn't one that I did but one that another company built so when I told them which one it was I figured I'd show you. I picked this one because of the safety factor, quality construction and the way this company treats their customers and it was 100% on all accounts.
    Bro-Tek: Tractor Add Ons
    I added a few photos to show you just how much extra stance and stability these wheel spacers will give your BX. I'm in no way affiliated with this company. I'm just a happy customer
    Before
    After
    Kubota ZTR ZG 222 Z
  10. #250
    Veteran Member varmint's Avatar
    Join Date
    Mar 2003
    Posts
    2,382
    Northern Maryland
    Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
    Went to the Bro Tek site, just out of curiousity, but no wheel spacers listed.
Similar Threads
  1. BX25 vs BX25D FEL?
    By Cap-n-Cray in forum Kubota Owning/Operating
    Last Post: 12-10-2013, 05:00 AM
  2. Kubota BX25D / BX70?
    By Artisan in forum Kubota Buying/Pricing
    Last Post: 04-21-2013, 02:29 PM
  3. Continued Vibration
    By DocD in forum Attachments
    Last Post: 08-11-2008, 08:54 AM
  4. Load Binders continued...............
    By johnday in forum Owning/Operating
    Last Post: 04-01-2005, 08:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
