Results 1 to 10 of 10
  1. #1
    Bronze Member Tcfake613's Avatar
    Join Date
    Aug 2011
    Posts
    51
    Elizabethtown, PA
    Kubota B2620
    Default Quick hitch with Kubota ballast box
    Anyone have this setup? Seems the top center pin is recessed too far back to hook up properly. I assumed most newer three point implements would not be a problem. Is there an adapter I can use? Anyone else run into this?
    Quick hitch with Kubota ballast box-image-1930481583-jpg
  2. #2
    Silver Member Kevinc2004's Avatar
    Join Date
    Nov 2010
    Posts
    113
    Gastonia,NC
    2015 B2601
    Default
    I have the woods quick hitch on my BX1860 for 2 years now. The center hook is adjustable, but I had to move the top pins on 2 implements to the compatible holes. Also there was an adapter that come with my WOODS unit incase of an older implement that was not designed fot the Quick Hitch systems.
    The biggest trouble that I had was to change all the hitch pins out to Category 2 or to add the adaptors to the Category 1 pins. The apapters are about 17.00 per pait at Tractor supply, but for most implements the regular Cat 2 pins work just as well.
    B2601, 54 in MMM, QA LA434, Woods Pallet Forks & Rear Quick Hitch!
  3. #3
    Silver Member GBOUTDOORS's Avatar
    Join Date
    Feb 2013
    Posts
    168
    S.E. Mass.
    Bx2360
    Default Re: Quick hitch with Kubota ballast box
    I drilled a new hole on the ballast box to bring the pin as far forward as it could and this has worked for me.
  4. #4
    Veteran Member amigauser's Avatar
    Join Date
    Oct 2005
    Posts
    1,189
    Unionville, Connecticut USA
    Kubota B2601
    I have the same issue with my kubota L box, I use chain from the box to the hook and that works for me without modifying the box itself.
    Kubota B2601 w/FEL & Q/A, 54" bucket, Bradco Pallet Forks, EA Grapple, EA Pine Straw Rake, Titan Stump Bucket, Titan 3pt pallet forks, Titan trailer mover, Titan ballast box, Turfco Aerator and Land Pride Pulverizer.
    Ferris Evolution 52" ZTR
    Stihl stuff
  5. #5
    Gold Member unbidden's Avatar
    Join Date
    Dec 2010
    Posts
    426
    R.I.
    Kubota BX2660
    Foster Center, RI
  6. #6
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    2,240
    Canada
    B3200, L5740,
    You need to take the top hook out then hook the bottom hooks then reattach the top hook when the box is in position.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    ZD1211
    GF1800 sold
    Kubota RTV900
    JD 850D Gator sold
    JD F935 x 2 sold
    Case 590SM-2
    JD 310D TLB sold
    Ford 555D sold
    Gehl 602 excavator sold
    JD317 sold
    JD323D
  7. #7
    Join Date
    Sep 2009
    Posts
    2,436
    Up State S.C.
    AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
    There's a thread describing an extension supplied by some company, possibly Harbor Freight, as well as a homemade one, for those things. I'll try to find it.
  8. #8
    Join Date
    Sep 2009
    Posts
    2,436
    Up State S.C.
    This is not the one I was looking for but, might give you some ideas. http://www.tractorbynet.com/forums/a...rry-all-i.html
  9. #9
    Join Date
    Sep 2009
    Posts
    2,436
    Up State S.C.
    http://www.tractorbynet.com/forums/a...k-hitch-2.html
    Post #18 mentions a $12.00 adapter if the hook isn't compatable.
  10. #10
    Join Date
    Aug 2011
    Posts
    51
    Elizabethtown, PA
    Kubota B2620
    Default
    Thanks for all the suggestions folks. I've got some good ideas to go with. Think I will start with a trip to Tractor Supply this week!
Similar Threads
  1. Kubota B/BX series Ballast Box + Quick Hitch for sale
    By RayBo in forum Private Party Ads
    Last Post: 09-26-2013, 07:19 AM
  2. Ballast ballast box and quick hitch
    By rtm038 in forum John Deere Owning/Operating
    Last Post: 02-15-2010, 10:58 AM
  3. Quick Hitch and ballast box
    By Jonathank in forum Projects
    Last Post: 01-25-2003, 12:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
