Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    New Member
    Join Date
    Sep 2012
    Posts
    12
    Nashville, Tennessee
    Kubota L245DT
    Default Clutch suddenly stopped engaging (L245DT)
    I was working with the FEL today and the clutch suddenly stopped went out. It worked fine powering into a dirt pile, then I clutched and shifted to reverse, let out the pedal and nothing. There were no strange sounds or burning clutch smell.
    With the pedal released I can switch in and out of all gears, which should not be possible. Depressing and releasing the pedal continues to do nothing, except that when I depress it there is a little friction sound (sort of a brushing or rubbing, not squealing). I would say there's a little less resistance than normal when depressing the pedal. I've read about stuck clutches on here but can't find this opposite problem by searching. It would seem like the springs that hold the clutch to flywheel are worn out, except it was so sudden.
    Anyone have any ideas on where to start looking?
    Relevant facts (maybe?):
    I had just topped off tranny fluid and was working on a hill.
    I get a little tranny fluid from around the gear shifter and PTO shifter when I've been running it hard for a while (e.g. mowing uphill).
    Thank you kindly.
    kubota L245DT
    1000 hrs (new to me; only put 15 hrs on it)
  2. #2
    Join Date
    Mar 2010
    Posts
    2,128
    Default Re: Clutch suddenly stopped engaging (L245DT)
    Orange Tractor talks has a video about replacing this tractor's clutch. Vic does a very good job. Worth looking into.
  3. #3
    Join Date
    Jan 2012
    Posts
    1,870
    Success Missouri
    Kubota L3800DT, L3750DT Shuttle
    Time for a new clutch.
    Don
    Kubota L3750 Hydro Shuttle, 4wd, FEL; L3800 Gear drive, 4wd, FEL
    Husqvarna XP chainsaws 346xp X3, 357xp, 562xp, 359
  4. #4
    Elite Member
    Join Date
    Sep 2004
    Posts
    2,566
    Kansas, Butler county, Just east of DooDah
    Kubota L4200 GSTCA
    Look under the bell housing, is there a hole there with a cotter pin loose in it... is there trans fluid at that hole?
  5. #5
    Join Date
    Mar 2010
    Posts
    2,128
  6. #6
    Join Date
    Jan 2010
    Posts
    149
    Katrine Ontario Canada
    U 25 Super Series Mini Excavator, Kubota B2320, Kubota L3400 HST with FEL and QA forks, Kubota RTV 500
    Has your clutch been jerky or "launching" (let out the clutch nothing happens then it jumps) lately? My 2005 B7510 had corrosion between the aluminum rear trans housing (I thought it was cast iron but not so) and the clutch pivot shaft for the clutch fork. The corrosion caused the shaft to hang up when releasing the clutch petal then quickly engaging. Had to split the tractor remove the shaft and clean then grease the shaft. Changed the clutch and pressure plates due to 1200 hours and it was already apart but the clutch was
    actually in pretty good shape. Has worked great since then (now 1900 hrs.)
  7. #7
    New Member
    Join Date
    Sep 2012
    Posts
    12
    Kubota L245DT
    Wow. Thank you all for these responses!
    Quote Originally Posted by KennyV View Post
    I can't see a hole with a cotter pin under there. Is it on the tractor's centerline? If so it must be up under the front wheel driveshaft where I can't see it.
    Quote Originally Posted by 2458n View Post
    That really is a helpful site. I'm guessing you mean this page: Getting to Know your kubotaç—´ Clutch | OrangeTractorTalks
    Quote Originally Posted by firemech View Post
    No. It worked perfectly until I went to back up there. That's why I'm looking for other opinions: there were no hints beforehand.
    Quote Originally Posted by Bluegill2 View Post
    I admit I can't think of any other possibility either; I was just hoping... since the onset was so sudden... it might be simple.
  8. #8
    Join Date
    Dec 2009
    Posts
    99
    Bellingham, Washington
    Kubota B7100, IH B275
    Is the throw-out lever moving with the clutch pedal and returning to it's normal positioin? I'm not sure where it's positioned on a 245DT.
    It sounds like either:
    1. the throw-out bearing is hung up and not returning to "normal" when the pedal is released
    2. the pressure plate is no longer attached to the flywheel, (i.e. bolts fell out)
    or
    3. the input shaft to the transmission is no longer, uh, "connected".
    Unfortunately, $$ increase from first to last, and splitting the tractor to find out is pretty much inevitable.
    Let us know what you find!
  9. #9
    Elite Member rbargeron's Avatar
    Join Date
    May 2000
    Posts
    2,814
    MA
    L5450, L48, L3250, L345
    It does sound like you'll need to split the tractor to get to the problem, whether its pressure plate fingers worn off, or release bearing stuck, or the shaft seized in the bellhousing. If the FEL is the non-removable type, it's easier to leave it attached to the tractor.
    To split it the machine, raise the bucket and block it up off the side rails. Unbolt the loader's chin bar from its side rails, take off the hood, disconnect the steering link, hydraulic supply pipes, unplug/disconnect wires etc., support both halves on rolling jacks, take out the bell housing bolts, and then roll the engine and front axle away from the rest of it. Works best on a flat floor, and if you visualize it for a while first. Good luck. Dick B
    L345, L3250, L48, L5450, never enough attachments
  10. #10
    New Member
    Join Date
    Sep 2012
    Posts
    12
    Kubota L245DT
    Quote Originally Posted by petes View Post
    I believe it's #6 here, and it does move as usual when I depress the pedal:
    Clutch suddenly stopped engaging (L245DT)-l245dt-clutch-innards-jpg
    or
    I opened up the inspection window and I think I have the answer. 1st the good: The throwout bearing moves back and forth as it should when the clutch pedal is depressed and released. And, the pressure plate is definitely attached to the flywheel and spins with the engine running.
    But, when I opened up the window, I could that the release levers were not all perpendicular to the bearing (see pic, especially toward the bottom). Also, I can see some fibers in there. My guess is that the disc suddenly disintegrated (Is that possible?), removing the pressure from those fingers and explaining why suddenly the clutch pedal felt lighter. So: I think I need to do a typical clutch replacement. I'm thankful it's not the transmission!
    Clutch suddenly stopped engaging (L245DT)-2013-04-18-15-31-a
Similar Threads
  1. Kubota l245dt engine suddenly locked up
    By swdavis3 in forum Parts/Repairs
    Last Post: 02-01-2012, 09:22 PM
  2. G5200H suddenly stopped
    By hookedondiesel in forum Kubota Lawn & Garden
    Last Post: 05-31-2011, 08:30 AM
  3. TC stopped suddenly
    By townsquare in forum Toolcat
    Last Post: 07-22-2009, 08:44 AM
  4. Oil & Fuel fuel guage suddenly stopped working
    By beowulf in forum Kubota Owning/Operating
    Last Post: 12-09-2005, 11:52 PM
  5. Brush Hog Stopped Mowing Suddenly
    By AndyMA in forum Attachments
    Last Post: 10-13-2005, 05:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
