Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
  1. #11
    Platinum Member 3v0's Avatar
    Join Date
    Jan 2013
    Posts
    521
    Oklahoma Pan Handle, United States
    Kubota BX2200
    Default Re: Block heater...worth installing ??
    Quote Originally Posted by yelbike View Post
    Whats the difference?
    There are several ways to heat the block. kubota uses a freeze plug heater where you have to pry out a freeze plug and insert the heater. I have seen these rust through.
    A lower radiator heater is installed by cutting the lower radiator hose and clamping the pipe like heater in to splice the hose back together.
    Before and after
    Block heater...worth installing ??-mercedesblockheatinstall22-jpg
    Both are good solutions in that they heat the water. There are other types of heater like the magnetic one Astanton mentioned, head bolt heaters, and even dip stick heaters.
  2. #12
    Gold Member
    Join Date
    Sep 2008
    Posts
    354
    Central Maine
    Kubota BX24 TLB
    Up here in Maine, my dealer put a kit in my BX for free/no charge/nada that includes: 1)block heater, 2)rear work light, 3) welded center FEL hook as part of doing good business.
    Union Farm Equipment (right next to the Deere dealer) Rt 17. Union, Maine nfi.
    I use the block heater for a hour or so before starting, usually gets the water temp gauge in operating range, then glow plug for 8 seconds or so. Unless the BX has been sitting at zero degrees for a few days which is doubtful in my unheated garage but it happens, it starts right up smoothly with only a small puff of black. If really cold, it will shake it off for 1-2 seconds then smooth back to normal running. I set idle up a little to start, maybe 1600+rpm, then let it run for another 5minutes before working it.
  3. #13
    Join Date
    Sep 2010
    Posts
    244
    Central Maine
    Kubota BX25
    Quote Originally Posted by PRF View Post
    I'm wondering if an engine block heater, plugged in for a couple hours prior to use might help with these issues?
    Not only will it start quicker, it will be all warmed up and ready to work, no waiting. And it has to be better for the engine. Mine is at running temp. in an hour.
    Edit: Peter types faster than me.
    Proofread carefully to see if you any words out.
    BX25, BX2750D Snowblower, Bro-Tek thumb, BXpanded Forks and Under Armor, Ballast Box, 3-PT Pallet Forks ...... My Kubota Pics
  4. #14
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,919
    Northern Vermont
    Kubota, Case, Deere
    I rarely use mine. When I decide I want to use the tractor it's never plugged in and I usually don't want to wait. It could be a week or more in the winter between uses so it makes no sense to leave it plugged in. I tried to plug it in for a half hour but it really didn't have enough time to warm it.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  5. #15
    Gold Member PRF's Avatar
    Join Date
    Dec 2012
    Posts
    267
    Connecticut
    2012 Kubota L5740, 1970 IH 2444, John Deere x485
    Totally worth it. If i try and start my tractor with out plugging in, is does start after a bit out cranking but it sure does like it. It needs throttle to start, puffs white smoke and has a rough starting idles. Depending on temperature sometimes plugging it in for as little as15 minutes will make a huge difference. I recommend it for any cold starting.
    That's what mine does, so I'm glad to see the heater is working for ya
    Quote Originally Posted by AStanton View Post
    PRF,
    I live in your neck of the woods and use a magnetic block heater that I bought at Napa Auto. I use it when temps drop below twenty degrees for my B3030. The beauty of this heater is that you can use it on another tractor. I use a dollar in the pic to show scale.
    Definitely the easiest way, but I think I'm going with one that heats the coolant..thanks !!
    Quote Originally Posted by 3v0 View Post
    Before and after
    I could be wrong, but I think the tech at my dealer mentioned mine having a threaded plug for the heater? If not, I like that hose heater, is it a Kubota item?
    Quote Originally Posted by PeterK View Post
    I got 2 out of 3 from my dealer, actually the hook, rear lights and wiper.. I was pleasantly surprised when they delivered it.. Needs a block heater though.. That poor engine struggling on initial firing makes me cringe !!
    Thanks very much for the replies fellas !!
  6. #16
    New Member
    Join Date
    Mar 2012
    Posts
    15
    bracebridge on
    kubota
    It’s well worth it. I have mine on a timer and plug it in if I’m going to be away for the day and I know that I will need it when I get home. I leave it for about 2hrs and 3 if it is really cold, and then let it run for 10min, by then your cab is nice and warm.
    John
  7. #17
    Join Date
    Jan 2013
    Posts
    521
    Kubota BX2200
    @PRF the lower radiator hose heater is generic. Just find one that is the right diameter for the hose after checking to see that you have the room.
    It is kinder to plug a diesel but on bigger tractors it takes a lot of watts to warm them up. Not so much on a SCUT.
    Getting off topic here but it is a bit nostalgic.
    Back in North Dakota during blizzards we kept a loader and a tractor with a snow blower plugged in. The loader tractor had to start to feed cattle and the snow blower to clear the road in case of an emergency.
    In the 60s everyone on our gravel road was snowed in till the county came to dig us out. When the farmers got decent FELs they started clearing the drifts over the road. That was slow cold work. In time they put blades on the farm tractors. At least one got a cat. Then rear mounted and finally front mounted snow blowers.
  8. #18
    Join Date
    Dec 2012
    Posts
    267
    Connecticut
    Great story.. We truck raw milk and I can remember standing on the back of an old D4 dozer while my grandfather plowed the drifts, with the singing Detroit milk truck right behind us.. They didn't have very powerful snow plows back in the 60's !!
  9. #19
    Elite Member Ken45101's Avatar
    Join Date
    Feb 2009
    Posts
    3,437
    southern Ohio
    Kubota M5040, M9540, B21 TLB, B2710, RTV900, JD 325 Skid steer, KX-121-3 mini excavator
    Quote Originally Posted by dsmiley View Post
    NOT really "ready for work." You are only warming the engine oil, not the transmission fluid. In very cold weather with an HST, it may be even more important to let it idle for a while and warm up the transmission fluid.
    I only have a block heater on my M5040. I only plug it in if the temps are going to be below 20 and I rarely use it at those temps. It would probably be good to have something on the RTV900 though since it gets used every day no matter what the temp. The M5040 is a gear transmission so warming the hydraulic fluid isn't as much of an issue.
    As for equipment used for clearing roads, the book "Denison's Ice Road" mentions how they start the equipment at the beginning of the season and never shut it down: starting big dozers at -50F is near impossible.
  10. #20
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    2,277
    Canada
    B3200, L5740,
    Short answer is yes it is a good idea and it will help. Do Not use kubota's freeze plug heater. They are an incredibly stupid, poor design in that the heating element does not even protrude into the block. In fact it is encased in a steel cylinder. It reaches super hot temperatures and burns out rapidly and barley adds any heat to the block. I installed a circulating heater on mine. The unfortunate part of the lower rad hose heater is that there is virtually no circulation with it either. The thermostat stops the water from circulating.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    ZD1211
    GF1800 sold
    Kubota RTV900
    JD 850D Gator sold
    JD F935 x 2 sold
    Case 590SM-2
    JD 310D TLB sold
    Ford 555D sold
    Gehl 602 excavator sold
    JD317 sold
    JD323D
Similar Threads
  1. Help installing block heater
    By George in Spokane in forum Kioti Owning/Operating
    Last Post: 02-04-2014, 03:04 PM
  2. B7510 = installing block heater
    By Clymer in forum Kubota Owning/Operating
    Last Post: 02-25-2007, 08:18 PM
  3. Any Tips for Installing Block Heater on JD 4320?
    By Sharp_Ranch in forum John Deere Owning/Operating
    Last Post: 01-02-2006, 07:37 PM
  4. Installing Block Heater for JD 2210
    By R_a_n_d_y in forum John Deere Owning/Operating
    Last Post: 12-08-2005, 02:34 PM
  5. Installing a block heater in a B2710
    By nykyfyr in forum Kubota Owning/Operating
    Last Post: 11-24-2004, 05:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
