Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member
    Join Date
    Jan 2005
    Posts
    14
    Indiana
    Kubota BX1800
    Default BX Metal on Transmission Filter
    Here's a pic of the metal on the transmission filter. At the bottom of the used oil container, there was at least 2x as much metal. Should I be worried for my BX?
    Attached Thumbnails Attached Thumbnails BX Metal on Transmission Filter-p1010860-jpg
  2. #2
    Silver Member Kevinc2004's Avatar
    Join Date
    Nov 2010
    Posts
    114
    Gastonia,NC
    2015 B2601
    Default
    How many hours on unit? How many times has it been changed? Have any piping changes, or equipment additions?
    If a new unit, this could be shavings from the housings. That screen is on the suction of the pump. Looks like it stopped the metal from entering the pump suction.
    Sent from my iPad using TractorByNet
    B2601, 54 in MMM, QA LA434, Woods Pallet Forks & Rear Quick Hitch!
  3. #3
    Gold Member beckmurph's Avatar
    Join Date
    Jul 2005
    Posts
    474
    Home/Catlettsburg Farm/Robinson Creek, Ky
    B2650 TLB
    Default Re: BX Metal on Transmission Filter
    That does not look good. There is a larger piece to the left side of the filter that looks like part of a washer.
    On the bright side, the filter screen is doing its job.
  4. #4
    Join Date
    Mar 2005
    Posts
    211
    x
    x
    On the bright side, the screen is protecting the pump from chewing this debris into smaller pieces that travel out into the hydraulics.
    On the down side, there are bearings and gears that are bathed in this same oil without the protection of being filtered.
    I would flush the system, and after a few hours, check the suction screen again. Repeat this process until there is minimal debris found.
    It seems that there are transmissions assembled without proper care taken to be sure the castings are clean before assembly. Luckily, mine had none of this debris at the 50 or 400 hour oil changes.
  5. #5
    Veteran Member sandyc's Avatar
    Join Date
    Mar 2003
    Posts
    1,382
    Steep Falls, Maine
    Kubota B3350 HSDC
    Hate to say it but the pieces of metal appear to be normal. Many other threads talk about this.
  6. #6
    Veteran Member Deano's Avatar
    Join Date
    Oct 2008
    Posts
    1,239
    Southern Maryland
    Kubota BX24
    Looks normal to me also if tractor is new...
    Deano
    2006 BX24, 6' Modern Implements rake, Woods RB60 rear blade, Wallenstein thumb, Bro-Tek rear skid plate, home made front skid plate, W.R. Long flat tooth bar, 4' finishing mower (TPH), 4' box blade, post hole digger, New style seat!!!!!, Agri-Fab drop spreader.
  7. #7
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Since tractor is at least 10 years old I would drain a quart and add atf and run till hot then flush and fill.
    Murph
  8. #8
    New Member
    Join Date
    Jan 2005
    Posts
    14
    Indiana
    Kubota BX1800
    Thanks guys. 2nd transmission, first was replaced under warranty at 300hrs.
    This is at 740 hours.
  9. #9
    Veteran Member lawn_king's Avatar
    Join Date
    Jun 2006
    Posts
    1,619
    Hanover massachusetts
    kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
    Based on my experience of kubota tractors over the past 13 years, i thought this looked like normal wear & tear.
    We have done so much, for so long,with so little, we are now qualified to do anything with nothing!
  10. #10
    Join Date
    Feb 2001
    Posts
    127
    Slate Lick, Armstrong Co, PA
    International 300 Utility, BX2200
    Just drill chips from the manufacturing process, nothing the worry about.
Similar Threads
  1. Oil & Fuel Metal shavings on filter
    By Dgoatrider in forum Kubota Owning/Operating
    Last Post: 09-02-2013, 11:00 AM
  2. Mystery Metal Found Between Engine and Transmission
    By bsbrum in forum Massey Ferguson Owning/Operating
    Last Post: 01-11-2012, 11:39 AM
  3. Metal Shavings On Hydraulic Filter
    By kcender in forum Kubota Owning/Operating
    Last Post: 02-23-2011, 02:56 PM
  4. Metal pieces in Hydraulics filter
    By medtech40 in forum Yanmar
    Last Post: 08-24-2007, 04:10 PM
  5. Metal found during transmission fluid change
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 01-13-2001, 08:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
