Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Nov 2001
    Posts
    906
    Green Bay, WI
    Kubota F2400, Kubota F2100, Farmtrac 360, Tool Cat
    Default Block Heater for F2400
    How hard is it to install a engine block heater after the fact?
    I think I want something better than a plug-in dip stick.
    The diesel engine is very easy to access.
    Any suggestions?
    Thanks
    Yooper Dave
  2. #2
    Elite Member
    Rest in Peace
    Join Date
    Apr 2003
    Posts
    3,741
    New Hampshire
    Kubota B2710, IH TD6-62 dozer with Drott 4n1 bucket loader
    Default Re: Block Heater for F2400
    The kit from kubota is the same one that is used on the 2410/2710/2910 and probably others. The cost is around $38. You will need a 17mm allen wrench and probably a cheater bar to help unscrew the plug. Kit comes with instructions written for the F2400. Should take you only about 10 minutes, if that.
  3. #3
    Elite Member
    Rest in Peace
    Join Date
    Apr 2003
    Posts
    3,741
    New Hampshire
    BTW, the kubota part number for the block heater is 70000-73274.
  4. #4
    Join Date
    Apr 2001
    Posts
    262
    NorthEast,CT
    B2710 HST,TLB R4's
    Make a search for "B series BlockHeater Install & Pixs " that was submitted last winter. It should answer all your questions. ...Raybee
    try this
    http://www.tractorbynet.com/forums/s...D=&fpart=1
  5. #5
    Platinum Member hwp's Avatar
    Join Date
    Dec 2001
    Posts
    643
    St. Catharines, Ontario, CANADA
    Kubota F2400
    My F2400 has a block heater but I haven't had to use it yet. But I keep my tractor in my garage in the winter. Attached is a picture of the block heater on my tractor.
    Attached Images Attached Images
  6. #6
    Join Date
    Nov 2001
    Posts
    906
    Green Bay, WI
    Hi Raybee,
    I got the parts, but it did not come with any instructions.
    I found your thread very useful and informative.
    A couple of questions :
    I was going to flush and drain the radiator, and refill after the installation of the block heater. Do I just fill up the radiator, or is there some bleeding or something to do to get out any air voids?
    What kind of dope do you put on the threads to screw the heater into the engine block? Is teflon tape acceptable?
    Thanks
    Yooper Dave
  7. #7
    Join Date
    Apr 2001
    Posts
    262
    NorthEast,CT
    B2710 HST,TLB R4's
    yooperdave: ....My recollection was to drain enough coolant to bring the coolant level below block heater, saving the drained coolant to refill radiator after installation. If in doubt check the manual for your unit.
    I used ordinary pipe dope found in plumbing department of hardware store to seal the heater plug. [img]/forums/images/graemlins/smile.gif[/img] ....RayBee
  8. #8
    Elite Member
    Rest in Peace
    Join Date
    Apr 2003
    Posts
    3,741
    New Hampshire
    re: sealing the block heater
    I used teflon tape and have had no leaks.
  9. #9
    Join Date
    Aug 2002
    Posts
    7,386
    North East CT
    2003 Kubota BX-22
    Personally, I prefer pipe dope compound. The thing that I don't like about Teflon tape on new fittings is that the threads are so sharp that they cut the tape while it is being threaded into the hole. Another thing about Teflon tape is that you have to be careful not to over tighten when using it because it is so smooth going in, that you can crack the block if you aren't careful. Teflon tape was originally made for use with old pipe fittings that were worn from assembly and disassembly. Now it is common place to use it on all threads.
  10. #10
    Super Member ronjhall's Avatar
    Join Date
    Apr 2000
    Posts
    9,789
    SE Michigan
    Kubota 2910 HST
    Yooper Dave
    I installed a block heater in my B2910 last week. Dealer gave me some suggestions. I will list them below.
    1. The pipe plug in block requires a 17 mm Allen type wrench to remove.
    2. The block heater requires a 35 mm wrench. I used a 1 7/16 socket to install.
    3. Use TFE Pipe Thread Sealant. This is Teflon paste from Home Depot. Put pipe dope on heater threads before you start removing plug.
    4. Have some Fleet guard anti freeze on hand incase more antifreeze is lost than reservoir bottle can replace.
    5. Remove plug only when engine is cold. There will be a little bit of vacuum in the cooling system to hold the anti freeze in engine when it is cold.
    6. Install the heater as quick as possible after removing plug to avoid loosing to much antifreeze.
    I was able to use this procedure to install my heater. There was about 3 tablespoons of antifreeze in the drain pan when I completed the installation.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
