Results 11 to 14 of 14
05-19-2013, 11:06 PM #11
- Join Date
- Dec 2009
- Posts
- 251
- Location
- Western Washington
- Tractor
- John Deere 3005, Kubota B7100, Kubota B2710 (Traded in the Ford 1700)
Re: B7100 Bush Hog Suggestion
referring to my previous note above, I have a front end loader on my B7100. With a front loader you DO NOT need to worry about a four foot mower on the back. It tackles more than you would imagine.
Mudfarmer.
JD 3005, Kubota B2710, Kubota B7100, 120 Acres
05-20-2013, 09:51 PM #12
- Join Date
- Oct 2010
- Posts
- 114
- Location
- East Kootenays, British Columbia
- Tractor
- 2009 Bobcat CT 235
I have to agree on the performance of the B7100. As stated previously, I had mine for 10 years and the only reason I upgraded to the Bobcat CT235 was loader performance. The loader on the B7100 was painfully slow which is the reason I finally decided to change. I must admit that little tractor did everything I asked it to. I did break it a few times, front spur gear, ujoint, but all in all a great tractor.
One thing, it was useless in two wheel drive so, 99.9% of the time it was in 4wd.
FredParkside
05-25-2013, 12:02 AM #13
- Join Date
- Dec 2009
- Posts
- 251
- Location
- Tractor
Mudfarmer.
06-02-2013, 09:03 AM #14
- Join Date
- Jun 2013
- Posts
- 5
- Location
- Somerset, Ky
- Tractor
- Kubota B7100 HST, Belarus 572, Ford 3000
One suggestion I would make though, whatever you get, is to get a slip clutch and put it on the drive shaft. I love those things. They protect your tractor. I've had them on 5ft bush hogs, to 15 foot batwings & rototillers....whatever. They will keep the tractor from stalling if you hit something. that is hard on a tractor when it happens.
Similar Threads
Rotary Cutter Bush hog 296 to be replaced by New BH series
By sawtooth in forum AttachmentsReplies: 7Last Post: 08-15-2013, 09:53 PM -
JD 4720 and 10ft bush hog
By trook in forum AttachmentsReplies: 7Last Post: 05-21-2013, 08:12 AM -
kutter king bush hog
By gridpa in forum Owning/OperatingReplies: 2Last Post: 05-04-2013, 06:05 PM -
Bush Hog SQ172 - Getting to Blades
By have_blue in forum AttachmentsReplies: 11Last Post: 04-30-2013, 09:30 PM -
Hydraulic issues: 755 With Bush Hog FEL
By hunter19707 in forum John Deere Owning/OperatingReplies: 2Last Post: 04-23-2013, 09:14 PM
