wheel spacers for BX25?
   / wheel spacers for BX25? #31
I have included a picture of the cracked front left bevel gear case. It was originally though to be a seal issue, but after installing new seal and reassembling, the leak continued. I cannot say the brotek front axle extensions are the direct cause, however, within 2 months of installation, the leak soon developed.
It is my professional opinion as a Nuclear inspector that the added leverage combined with repetitive use of the FEL was a direct contributor to the stress related failure of the bevel gear case.
Crack is approx. 4.0" and tight in nature and seen here using a visible dye penetrant examination.
~Tol
   / wheel spacers for BX25? #32
out of curiosity, what size front spacers did you install?
~Tol
   / wheel spacers for BX25? #34
I would think adding spacers on the front and doing loader work would sure do like what it did on yours. I changed the offset of the center of the wheel so that it in turn didn't make the axle longer as bad as wheel spacers. Now center of the wheel runs in the middle of the ring of the wheel. Hope you can understand what I'm tring to say?
   / wheel spacers for BX25? #35
~Tol
Man I don't know. There are hundreds of these BX tractors out there with wheel spacers installed on them mine included that haven't had an issue. Actually yours is the only one that developed a crack that I know of and where a wheel spacer was mentioned in the same sentence. Maybe you just had a bad casting? Maybe something else? I realize that you said you don't know if the wheel spacers were a direct cause of your problem but when you mention nuclear inspector and saying the crack appeared two months later you sure are insinuating they were the cause when in actual fact you have very little evidence that the spacers had anything to do with it at all. :confused3:
I've hauled at least 12 tandem loads of heavy gravel with my BX at long distances and never had an issue. If the spacers were going to cause a crack they sure would have done it on my job. (See photos)
Now I appreciate the fact that you are a Nuclear inspector and I am a licensed vehicle inspector and in my opinion the wheel spacer had nothing to do with it.
Remember, this is someone's lively hood and good reputation here we are dealing with. I think you should have had more definitive evidence before dragging Bro-Teks good reputation through the mud.
I'm running 1.25" front and 2" rears.
   / wheel spacers for BX25? #36
I'm not anything to brag about when it comes to titles, but I do know this. The front axle PIVOTS. Widening the front foot print adds nothing to stability until the pivot stop is reached. Everything up to that point is done by the rear wheels.
Personally, I'd have no problem adding spacers to the back. They are "only" adding stress to the axle and bearing. The front, however, has all kinds of things that turn and pivot, and spacers on the front is adding a lot of load to a lot of things. Your exposing a lot of expensive components to extra stress, and not gaining one iota of stability, unless you're running around with one back tire already in the air.
   / wheel spacers for BX25? #37
You may have a point about how much stability the front spacers add... but I wouldn't claim 'nothing'.
   / wheel spacers for BX25? #38
I'll add my two cents. I discussed spacers with the service manager at my dealer. He stated he does not officially recommend them as Kubota does not supply them and they would raise a question mark if the tractor was still in warranty and had an axle problem. That is the party line answer naturally. He also stated that he has a lot of clients that use them with seemingly no problems. He goes on to say that most of the rear and front axle bearing and seal problems his shop sees are clients that use spacers, especially the 4" ones. That dealership does not sell or install after market ones for liability reasons. All that said; I have the pieces I need to fabricate my own 4" rear spacers when I get around to shop work again. 2 ford ranger rear axle shafts, some 1/2" plate, and two pieces of 3" schd. 80 pipe. After my discussion with the SM I came to the conclusion that front spacers are probably a bigger potential problem with minimal stability affect.
Ron
   / wheel spacers for BX25? #39
I posted this in an effort to make others aware of the potential failure and only stated the facts of the inspection, duration, usage, and changes made. how you interpret that is up to you. I stand behind 28 years of inspection, identifying and determining how the failure may have originated, those range from thermal fatigue, stress corrosion, fatigue, cyclic stress or inherent. Do to the nuclear safety involved it is not only imperative to identify it, but to identify the root cause.
That can be done by knowing parameters of use, temperatures, stresses, and possible inherent discontinuities with in the material, as well as various inspection techniques used to identify the indication, many times requiring a long paper trail.
While you show your tractor being used on a somewhat level grade in an urban environment, my unit is used in an undeveloped area in an effort to establish access, consisting of side hills, and uneven terrain to shuttle stones to the job sight. This reflected in uneven lateral loads being placed on the front axle assembly. Whether those stresses acted on an inherent casting flaw is anyone guess without a paper trail to identify if they where ever inspected, we can continue to assume that they where most likely not. However, the use of the extension would place additional leverage to the same area of the indication due to the bevel gear hub design.
Which takes us back to my first sentence "I posted this in an effort to make others aware of the potential failure and only stated the facts of the inspection, duration, usage, and changes made".
Much the same as one pointing out it could be a coincidence that it failed after installing the extensions..
I merely stated the facts based on my expertise, knowledge, and training.
Rich turns out quality stuff and I do not aim to discredit him, I personally performed a visual inspection on all the items I received from him, belly pan, thumb, claw for thumb, brush forks, and the extensions. The quality of craftsmanship is first rate, welds are comparable to that of what I am accustom to seeing in a power plant.
None the less, I felt it important to share with others if in deed it becomes more evident with other kubotas, or those using extensions. I don't aim nor ever have to drag ones good name through the mud, only create the speculation that it could have been and let the end user decide for themselves based from the facts stated here.
~Tol
   / wheel spacers for BX25? #40
Until the axle pivot hits it's maximum rotation, the front axle adds nothing to stability. Up until that point of contact between the axle and the limit, it's free to rotate, regardless of how far apart the wheels are.
Spacers add stress, no matter how you figure it. More stress means shorter life. It's all in how much you want to risk it. More stability VS long life. As with anything, sometimes things live very long under high stress, sometimes they don't. Just understand the potential risk of spacers vs a different potential risk of no spacers.
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2012 BIG TEX PIPE TRAILER (A50854)
2012 BIG TEX PIPE...
16 STEEL SHEETS CURVED (A50854)
16 STEEL SHEETS...
2007 CAT 904B (A47384)
