Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Join Date
    Jun 2004
    Posts
    2,409
    USA
    Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
    Default Re: Pallet forks
    Here's the link to the forks I have from MDS. Very well made. My John Deere dealer carries them. My favorite attachment by far.
    Rail Style Pallet Fork & Round Bale Stabber Adapters
  2. #12
    New Member
    Join Date
    Nov 2012
    Posts
    15
    raleigh, nc
    Kubota L3400
    I picked up some made by Construction Attachements for compact tractors at a local farm show. They have been great. Everything Attachements sells their brand, although the ones I have they do not have on their website. You will never regret getting pallet forks. I use mine more than I use a bucket.
  3. #13
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,755
    Branson, Mo.
    Kioti DK35se Hydrostat
    Watch this video, as he tells it like it is. I would probably order the ones in the video now. I have the construction attachments lightweight pallet forks, and they are great, but they are the ones he mentions on the sliding rod, so if you are Unloaded, and moving fast on a sidehill, they will drift downhill on you. Of course this does not happen if there is some weight on the forks, but it can be annoying if you make several trips and have to come back unloaded on an angle. You can mitigate this problem by raising your loader and curling to put more weight on the part of the fork that touches the lower bar and also slowing down your ground speed to not bounce the tractor FEL so that the forks don't bounce around. I have thought about but not implemented the placement of some welding beads on the lower bar to "catch" the forks as they try to slide on the bar.. I have noticed if you don't grease the bar as often, they don't slide as much either. All in all not a big problem, and otherwise the forks are great, and I have used the heck out of them. If you lived on flatter ground, it would never even be an issue. But SSQA forks in general are great to own, and I will never be without a set.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  4. #14
    Veteran Member MHarryE's Avatar
    Join Date
    Feb 2009
    Posts
    2,078
    Northeastern Minnesota
    Kubota M7-171, Kubota M110GX, IH 4386, IH1486, Case 301.8, Kubota L6060, plus many others
    Default
    I got a Construction Attachment set recommended by Everything Attachments after first selecting a Bradco set from their site. They recommended this set because it is built heavier. They must have known my long term plan better than me because they now switch between my L5740 for which I purchased them and my new M135GX. They really do the job.
    JD7720; KubotaM135GX; NH TS115A; JD6230; KubotaL6060
  5. #15
    Veteran Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    Those Everything Attachment and WildKat forks look nice.
    I never liked the idea of clamp on forks for the bucket, but might be a useful alternative for occasional use.
    I've modified some forklift forks to bolt onto my bucket. Right now, set narrow which seems good for my needs, but I haven't moved any pallets. And, I've just left them on the tractor for now, as long as they are more help than hindrance.
    The biggest problem with attaching forks to the bucket is you can't see a thing. Those forks with the quick release & see-through guard would be much easier to use.
  6. #16
    Gold Member scaredychicken's Avatar
    Join Date
    Jul 2012
    Posts
    296
    Salmon Arm BC, Canada
    John Deere LT160, Arctic Cat 400 ATV
    Quote Originally Posted by Notforhire View Post
    Correct!
    One reason I sold a set of forks was that they weighed about 500lbs! If the loader will only lift 1500lbs you are really limiting what you can pick up if the forks use 1/3 of your total cap. Clamp on forks also present a problem in lift cap., as they force you to have the load further out.
    Bill
    correct again
  7. #17
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,733
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by k0ua View Post
    James K0UA
    Put some hose clamps or U bolts around the rod, to keep the forks in place. For moving brush, I use a short piece of chain with the ends bolted together, around the fork and the outside of the frame. That allows some flexibility on uneven ground and will allow max dump angle.
    Pallet forks-p6190001-jpg Pallet forks-p6190004-jpg Pallet forks-p6190005-jpg Pallet forks-p6190007-jpg
    Chain on one to show the difference at max dump
    Pallet forks-p6190011-jpg
  8. #18
    Join Date
    Jun 2009
    Posts
    27,755
    Branson, Mo.
    Quote Originally Posted by Xfaxman View Post
    Well the forks on mine don't swing out like that, it is just that they will slide. The hose clamps would take more time to put on each time, and require readjustmet for each fork width than I would care to invest. This is not much of a problem, only when moving fast on hilly terrain and after you grease the rod. So it is no big deal to me. I think my vertical weld beads on the lower square tube bar Idea would work to solve the problem, but it is not enough of a problem for me to get my lazy..... out there and actually do it.
    James K0UA
    James K0UA
  9. #19
    Silver Member mudcat47537's Avatar
    Join Date
    Jul 2007
    Posts
    111
    Southern IN.
    Kioti CK30 HST, 53 Ford Jubilee
    My HLA forks weigh 270lbs at least that is what their site says.
  10. #20
    Platinum Member Katahdin's Avatar
    Join Date
    Dec 2010
    Posts
    749
    Scarborough, ME
    Yanmar LX4500, Toro z420
    I purchased the Bradco forks from Everything Attachments and I'm very happy with them. The forks were shipped to my local freight terminal where they were loaded onto my 4x8' utility trailer. To my surprise these forks are gray in color, not black, and may match the color of your Kubota's frame. I'll probably repaint them black to match my Yanmar at some point.
    Regarding EA's 1000 mile free shipping radius, I was initially charged an extra $20 just for shipping to Maine, but EA was kind enough to remove the fee when I explained the local freight depot was 50 miles within that radius. Depending where you live in NH, you may be on the border of their free shipping zone like I am and want to check the actual travel distances with google maps or some other mapping program.
Similar Threads
  1. Clamp on pallet forks or debris forks?
    By Gio in forum Attachments
    Last Post: 07-09-2013, 04:27 AM
  2. Forks Pallet Mover vs. Pallet Forks?
    By aloha in forum Attachments
    Last Post: 09-23-2004, 01:50 PM
  3. Forks Pallet Forks
    By MyOutdoors in forum Attachments
    Last Post: 10-29-2003, 09:31 PM
  4. Forks Pallet Forks vs. Utility Forks
    By rmonio in forum Attachments
    Last Post: 08-07-2003, 05:45 PM
  5. Pallet Forks vs. Utility Forks
    By rmonio in forum John Deere Buying/Pricing
    Last Post: 08-07-2003, 12:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
