Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
  1. #11
    Super Member Wagtail's Avatar
    Join Date
    Jan 2013
    Posts
    6,567
    St Helens, Tasmania, Australia
    JD 4105 / JD D110
    Default Re: Digging with FEL
    When I prepared the ground for the cement pad for my 5-bay shed I first used my 655 tiller to loosen a layer up, then scooped away with a regular FEL bucket. Fortunately there were only tree roots to contend with. The tiller made all the difference.
    Later on my 4in1 bucket was delivered and I could really get stuck-into levelling, scraping & a wee bit of digging.
  2. #12
    Super Member dragoneggs's Avatar
    Join Date
    Jun 2013
    Posts
    8,330
    Seabeck, Washington
    Kubota BX-25D, Z122RKW-42, and JD LTR166 Lawn Tractor
    New BX25D owner here and while I have a fair amount of dirt to dig, paths to cut in on sloped property, water and power lines to trench, I can't see passing up on a BH if you have much digging to do at all. My FEL won't dig any of my virgin dirt. I have a Piranha tooth bar coming in the mail to help. I see how it is a bit of a hassle to remove the BH for 3 pt hitch use but I plan to get or make a dolly. Then I don't see it as much of a big deal.
  3. #13
    Bronze Member scobrado's Avatar
    Join Date
    Dec 2012
    Posts
    82
    Wilsonville, Ore. USA
    John Deere 3038E
    I find the box blade is really handy. You should be able to move 18" of tough dirt and rocks in multiple passes with rippers. I like mine to dig ditches using the tilt. The ditch starts our shallow, but every pass make the ditch walls steeper.
    John Deere 3038E/305 FEL/Frontier RB5060 rear blade/Frontier RC2060 rotary cutter/Harbor Freight quick hitch/Titan clamp-on forks/Priefert single bottom plow/Priefert 16x16 disc plow/Priefert 6' landscape rake/Taylor Pittsburgh Carry All/Land Pride BB1572 box blade/Fimco 40 gal. 3 point sprayer/Rankin subsoiler/Bearcat chipper-shredder/, more to come ...
  4. #14
    Veteran Member sandyc's Avatar
    Join Date
    Mar 2003
    Posts
    1,395
    Steep Falls, Maine
    Kubota B3350 HSDC
    I have a BH and FEL, having said that, I used my FEL with ratchet rake to prepare the soil for a VEG garden I dug out of the sand this spring. Loosened the turf and soil in layers and scooped out the spoils using the fel to about 12 inches. The used the FEL to fill in the garden with topsoil. Something worked OK as the radishes are great and the rest of the veggies are coming along! We have sandy soil here so the digging is easy.
  5. #15
    Veteran Member PhysAssist's Avatar
    Join Date
    Aug 2011
    Posts
    2,296
    Upstate NY- see the BIG lake- look just below it...
    Kubota B2320
    Quote Originally Posted by sandyc View Post
    And while a ratchet rake is useful in clearing ground, and can no doubt really loosen soil, especially sandy soil, it is no match for a Piranha toothbar, which by the way were made expressly to increase the utility and capability of BX tractors, hence the name BXpanded.com. Search toothbar, and especially the Piranha toothbar, and you will find a ton of people using them to dig, rake, and clear with.
    Our tractor is a slightly bigger (though not much more powerful, if any) kubota B2320, and after being frustrated for over a year with the weak digging ability of my loader (as a kid I drove BIG tractors with loaders and expected something more like that kind of digging ability-and now that I think of it, they all had teeth too), we ordered a Piranha Toothbar from Harry at BXpanded
    Now when we want to move soil or rocks or turf, we just drive in and up it comes. The amount of angle of the bucket and down pressure controls the depth so with just a little practice, it doesn't bog down.
    We do use our box blade to loosen and dig up soil etc, but it is only good for moving it a short distance, else it leaks as you go (or keeps digging where you don't want it to. It is the best at spreading and smoothing whatever- soil, gravel, wood chips..., but a toothbar gets you digging a lot cheaper than either a boxblade or a backhoe.
    And before I get jumped on, I have to add that neither toothbar nor the boxblade are good substitutes for a BH, in performing its functions, but as my dealer said, unless you have tons of trenching or tree stumps to remove, it's one just one more, big, heavy, expensive thing to store, maintain, and have break down.
    My dealer talked me out of a backhoe and I am very glad he did, because for less than that money, we got a boxblade, toothbar, a combo spade (though that is the implement I like least, it does have uses), and a HF quickhitch.
    I almost forgot our ballast box which I just finished a month or so ago.
    Just my. 02 (50$ adjusted for taxes and inflation).
    Thomas
  6. #16
    Elite Member
    Join Date
    May 2005
    Posts
    2,758
    Balls Creek, NC
    New Holland Workmaster 50, Ford 4610 SU
    Get a box blade and utilize the scarfers to loosen your soil...
    Take your FEL and then remove the loosened soil for your project...
    FEL's on compacts are designed to lift and load and not necessarily dig...
    Many on here do use the FEL for digging but it does stress the loader and frame attachment points...
    The heavier the tractor the easier it is to dig with the FEL...
    I did add a tooth bar to my tractor and it digs well but it is heavier than a BX weighing in at 3300# sans loader...
    Some inexperienced operators have damaged their tractors using a FEL to dig...
    Some have not...
    Your dealer is just trying to protect you and your investment...
    When my dealer delivered my tractor and FEL he told me that it was not a bull dozer...
    I told him I didn't need it for that...
    I had a CAT D4D sitting in the pasture...
  7. #17
    Join Date
    Jun 2006
    Posts
    139
    Vermont
    Still looking...
    Hey thanks, guys for all your responses... Extremely helpful info. I appreciate it. I've considered a BH but maybe I'll pull back from that. I was planning on getting a box blade... Found a good used one for $350. I'm going to look at it tomorrow.
    Digging with FEL-p6140063-jpg
    Yes, our soil is very rocky, so I guess I won't risk digging too much with the FEL. I'll try to do as much as I can with the BB and then scoop the loose stuff. If I get into big rocks then I can rent a 3000 series TLB from a local rental place for $300/day. That's probably the way to go. Here is where I want to build the patio:
    Digging with FEL-back-jpg
    ...right to the left of the deck. We have a ton of ledge and had to blast a cellar hole, blast a trench to the well and for the septic. This whole hill is ledge - the Rock of Gibraltar. So I may not even be able to go down that deep anyway. Frost around here will move anything not set deep enough in the ground, so I want to get a good base for the patio stones with good drainage. I also want to put a crushed stone skirt around the whole house about 28" in width. I may be able to scoop down a few inches with the FEL as most of that material is sandy back-fill. Can't wait to get this tractor. We haven't done any landscaping around the house yet as we are still recovering from building expense. Having the tractor will save us the expense of hiring to do all this work. I also need to move this:
    Digging with FEL-wall-jpg
    Digging with FEL-front2-jpg
    These rocks (from a 200 year old wall) got displaced when the land was cleared I want to rebuild that wall. It's beautiful and meanders all throughout our 10.5 acres.
    Digging with FEL-dsc04205-jpg
    And I have this driveway to maintain.
    Digging with FEL-driveway-2-jpg
    Digging with FEL-driveway-3-jpg
    Lots of work to do!! I'll upload pics as it unfolds!
  8. #18
    Super Member JOHNTHOMAS's Avatar
    Join Date
    Apr 2008
    Posts
    7,177
    Somerset, Ky
    L3901HST F3080 RTV1140 BX2370-1
    I bought my first tractor about 10 years ago, a BX2200 FEL MMM, to be my lifetime mower with a high priced wheel barrow on the front. I bought 5 acres of hillside, rocky, ditches and trees to build my own home on. Had a man with a dozer come after I spent a month cutting scrub trees with a chain saw and he did in a few hours what was taking me weeks to do and cleared to my specs the treed area and dug up rocks car size and moved them to my chosen locations at the time. He wanted to bury them all.
    Any way, the more I discovered the little tractor would do the more jobs I took on until I wanted a bigger one and one with higher ground clearance so I discovered the world of trading tractors just like cars and trucks. I moved up in size to a B7800 FEL RFM and a BX1500 MMM (for mowing steep hillside). 3 years later started trading again and went up to an L3240, to big, traded back to a B3200 and then several trades after that to a BX25. Being a project kind of guy and moving trees, grasses and rocks and stuff the BX25 became my favorite kubota tractor and other than the B7800 (which I used my first lots of projects and taming the land) I used more than any of the others.
    I started buying Kubota Fs for mowing so I no longer use my tractors for mowing. I currently have a B2620 FEL BH and believe I'll stop trading and keep it, for awhile. If I were to consider trading I'd go back to a BX25 because of the FEL and BH. I delayed buying a BH for years because I just couldn't justify the cost, I thought. I even posted one time here for people with BHs to tell me what they did with theirs with little to no response.
    Almost the end. I've bought 15 Kubotas in 9 years. Almost all BX and B models and one L. If I had it all to do over I'd buy a B with a FEL BH first to tame the land, have to have a B for the ground clearance at the beginning and a used BX with RFM for mowing. Then after reaching the stage of maintain and ongoing smaller projects which is basically where I am now except for the rental property with 6 septic tanks I'd buy a BX25 FEL BH. I don't think I'll ever go without a BH again nor go without a FEL. The BH is for digging. Digging everything not just the specific jobs some people have mentioned to you. Digging period. I buy trees when they go on clearance or any time I think I want another one or want to move one or my neighbors want a hole dug for a tree, grass, bush or ?? and my brother lives beside me and I dig stuff for him often. He changes his landscaping more often than I do mine.
    If your wanting to maintain your property and attack projects at your timing and not hunt for reasons not to do a change then get the BX25. If you don't think it's the right one after you buy it and use it for 2 months send me your address and I'll send you $20. If you think it is then just revive this post and tell it.
    I'm assuming your a project guy form your post and the beautiful property/home you have. BHs are for project guys.
    2017 L3901 HST FEL, 2017 BX2370-1, 2012 F3080 4WD 72" RD, 2010/2009 RTV1140CPX , 72" Woods RFM, 60" LP Grapple, J DUNN Tree Grapple, 6' LP Rotary Mower, LP25 Hydraulic PHD, LP Quick hitch, RatchetRake , Rip and Dig, LP BB, LP 50" Tiller, Snow plow, Titan SSQA Forks, Titan Hitch Mounted Ripper, Titan SSQA to 3PH adapter plate, Sickle mower .. and Horse Drawn disk 13 Toyota Tacoma Double Cab, 18 Ford Flex
  9. #19
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,951
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Quote Originally Posted by TedLaRue View Post
    Unless the soil is quite soft, your best bet at digging would be to turn the loader to full dump position and "back blade" to scrape the dirt out while backing up. You can scrape a thin layer out, and then when you get a decent pile, scoop up the loose dirt.
    That technique is a fantastic way to bend the curl cylinder rods on the FEL or blow hoses.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  10. #20
    Super Star Member daugen's Avatar
    Join Date
    Feb 2012
    Posts
    10,250
    Washington NC (Inner Banks)
    Kubota L5740HSTC, MF 2615, MF 1230, IH Super A
    Quote Originally Posted by kennyd View Post
    Kenny, what would be better? I'm a newbie FEL owner and I would do every one of these scraper options/mistakes if only to see what seemed to work better.
    Now I'm operating at lower rpm, not throwing the full weight and power of the tractor into it.
    I've leveled some heavy gravel backing up slowly and nothing seemed too unhappy. When do you know you are crossing the line, short of getting hit in the eye with hot
    hydraulic fluid?
    Personally I always go in slow, testing how things react and then try to use the least power and capacity of the tractor that will get the job done. I need to do this because I am still relatively new to my machine. I know what I don't know and it's a lot. So... what do you suggest for "back blading" with a FEL?
    don't mean to hijack a digging issue for a blading issue but I think we all want to know not only how to get the job done but how not to damage our expensive machinery.
Similar Threads
  1. Storing the FEL dumped
    By jimpen in forum Mahindra Owning/Operating
    Last Post: 06-26-2013, 01:35 AM
  2. Anyone drive T-posts with FEL?
    By C4Ranch in forum Attachments
    Last Post: 06-16-2013, 08:10 AM
  3. Yanmar 1500 FEL
    By PatrickHanna in forum Yanmar
    Last Post: 06-13-2013, 04:49 PM
  4. FEL Hyd Connections
    By Skeeter Madness in forum Hydraulics
    Last Post: 06-10-2013, 10:18 PM
  5. YM186 FEL
    By Kernopelli in forum Yanmar
    Last Post: 06-02-2013, 12:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
